Question about Jcp Home Collection Devonshire Vanity Sink
How To Remove Ceramic Sink
I have a ceramic sink which I want to remove - how do I remove it without damaging the area?
    President:
  • 2,712 Answers
Your sink is likely to be glued into place, in which case you will need to carefully extract it from its surround. Begin by disconneting your water supply and removing all the plumbing connections. You probably wont need to remove the actual taps, but t wont hurt. Be very careful about using hammers as ceramic sinks do not tend to react well to them!
Posted on Aug 27, 2008
I am descaling my Keurig for the 2nd time, it fills 2 cups w/vinegar and stops and won' start again, tells me its ready, help
A. Prepare
Step 1: Make sure you have 48 ounces of white vinegar on hand. You will also need an empty sink and a ceramic mug (Do not use a paper cup.)
Step 2: Empty the water in the water reservoir
B. Fill and Clean
Step 1: Pour the vinegar into the water reservoir and fill it to the top edge of the clear viewing area.
Step 2: Place a ceramic cup in the drip tray and run a brew cycle. DO NOT USE A K-CUP...just press the large cup button. Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the water reservoir is empty, pouring the contents of the cup into the sink after each cycle. Remember to open and close the lid between each cycle.
Step 4: Now fill the reservoir with fresh water and let the brewer stand for 4-hours while it is still on.
C. Rinse
Step 1: Ensure the water reservoir is filled with fresh water.
Step 2: Place a ceramic cup on the drip tray and run a regular brew cycle. Once again, DO NOT USE A K-CUP...Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the water reservoir is empty.
Step 4: You may need to perform additional brew cycles if you notice any residual taste.
Jun 01, 2014 | Keurig Platinum B70 Coffee Maker
Tip
Keurig Home Brewer instructions for de-scaling with white Vinegar
A. PREPARE
Step 1. Make sure you have 48 ounces of white vinegar on hand. You will also need an empty sink and a ceramic mug ( do not use a paer cup).
Step 2. Empty the water in the water Reservoir.
B. FILL AND CLEAN
Step 1. Pour the vinegar into the water reservoir and fill it to the top edge of clear viewing area.
Step 2. Place a ceramic cup in the Drip Tray and run a brew cycle. DO NOT USE A K-KUP … just press the Large Cup Button. Pour the contents of the cup into sink.
Step 3. Repeat the brew process until the Water Reservoir is empty, pouring the contents of the cup into the sink after each cycle. Remember to open and close the lid between each cycle.
Step 4. Now fill reservoir with fresh water and let the brewer stand for 4 hours while still on.
C. RINCE
Step 1. Ensure the Water reservoir is filled with fresh water.
Step 2. Place a ceramic cup on the drip Tray and run a regular brew cycle. Pour the contents of the cup into the sink.
Step 3. Repeat the brew process until the Water Reservoir is empty.
Step 4. You may need to perform additional brew cycles if you notice any residual taste.
on Aug 10, 2010 | Coffee Makers & Espresso Machines
Remove the logo from under-mount ceramic sink
I would say if you use heat use a heat gun. Better heat but be careful, they are much hotter than you think and you do not want to damage the finish.
Nov 21, 2013 | American Standard Home
How do you take care of ceramic teapots that are very delicate and often painted?
Wash your ceramic pots in a sink of warm water. Do not expose them to sudden temperature changes. Use mild dish soap to clean it out and be very careful drying it as it can easily get chipped.
Feb 27, 2013 | Home
The descale light keeps blinking, what should I do?
The 'Descale' light that turns on indicates that it is time to de-scale the machine.
Scale - or mineral deposits- form from the water you run through your Keurig coffee machine. If not cleaned regularly, the buildup can clog the lines in your machine and ruin the heating element. The manufacturer recommends you descale Keurig coffee makers once every six months for normal water conditions and once every three months if you live in an area with hard water.
You will need :
  • Keurig coffee maker
  • 48 oz. white distilled vinegar
  • Water
  • Large ceramic cup
  • Sink
Instructions :
  • 1 Unplug the coffee machine and remove the cup.
  • 2 Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
  • 3 Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
  • 4 Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
  • 5 Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
  • Good luck ;)
    Dec 14, 2011 | Keurig Elite B40 Coffee Maker
    Keurig Coffeemaker says to descale. How do I do that?
    Hi, unplug the coffee machine and remove the cup.
    Unplug the machine and dump the water into the sink.
    Fill up the reservoir with fresh, clean water and plug it in. Place the ceramic cup back on the drip tray and run multiple brews in order to rinse the machine of any remaining vinegar residue.
    Apr 28, 2011 | Microwave Ovens
    The coffemaker won't brew and showed a descale message. What does that mean?
    Scale---or mineral deposits---form from the water you run through your Keurig coffee machine. If not cleaned regularly, the buildup can clog the lines in your machine and ruin the heating element. The manufacturer recommends you descale Keurig coffee makers once every six months for normal water conditions and once every three months if you live in an area with hard water
    1.Unplug the coffee machine and remove the cup.
    2.Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
    3.Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
    4.Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
    5.Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
    6.Unplug the machine and dump the water into the sink.
    7.Fill up the reservoir with fresh, clean water and plug it in. Place the ceramic cup back on the drip tray and run multiple brews in order to rinse the machine of any remaining vinegar residue
    Dec 10, 2010 | Keurig B70 Coffee Maker
    How do you replace a seal on a Sta-Rite pool pump? How do you remove the old seal? Ceramic and graphite.
    Replacing a shaft seal requires some good mechanical ability.
    first, always make sure power is off at the breaker before you work.
    You'll have to remove the band holding the wet end to the seal plate. Then remove the diffuser covering the impeller. Remove the cover on the back of the motor. You either need a 7/16 open end wrench or a armature tool to hold the motor shaft while you unthread the impeller (if the impeller has a screw in the middle, you will have to remove it by turning clockwise, left hand threads) counterclockwise. You can then pull the carbon part of the seal off of the impeller, make sure to remove all of it including the metal sleeve. You will then have to remove the seal plate and push the ceramic part out from the back. You can then clean and lube the seal plate and install the new ceramic part of the seal, try not to touch the ceramic with your hands if possible. You can then lightly lube the impeller shaft and slide the carbon part of the seal with the carbon facing toward the ceramic as you thread it on. If the seal plate had a copper heat sink, you can either replace it or use a different size seal. (I believe it's a PS-201) Re-install the seal plate, impeller (and screw if applicable) and diffuser. You should now be ready to mate the seal plate to the wet end. Make sure you fill the pump before you try starting it up, especially with a new (dry) seal.
    Aug 14, 2010 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
    I have a white Franke fireclay sink. We also have very hard water despite using an undersink filter. The sink is part of a new remodel and despite little use so far and lots of wiping, the water spots seem...
    The best product I have found to remove water spots is a product called A-maz water stain remover in a 14 oz tub. There is no magic "wipe on,wipe off" product that I have found. Initially it is a little labor intensive but this is amazing stuff and can return your sink to its original luster.
    This company also make a sealer but I have not tried it. A couple of alternatives might be Rain-X or Maguires auto wax. The concept here is to put a barrier down that will seal the pores of the sink and make it easier next time to remove the spots. My favorite is Maguires about every 3 months. I have provided a link below to the A-maz web site where you can find a distributor nearest you.
    http://www.a-maz.com/
    May 10, 2010 | Franke Double Undermount Fireclay Sink -...
    Cannot remove Kohler ceramic valve
    is this a single handle faucet. If not the part goes in under the handle
    Nov 02, 2017 | Kohler Model 10433: Fort® Single-control...
    Jcp Home Collection Devonshire Vanity Sink Logo
    240 people viewed this question
    Top Jcp Home Collection Home Experts
    john h
    Tom Chichester
    Are you a Jcp Home Collection Home Expert? Answer questions, earn points and help others
