Question about Danze D316440DNT Fairmont Two Handle Wall Mount Bathroom Faucet with Valve
Faucet Repair My faucet is making noise. Is there a way to repair it?
  • Jeff Sumner Sep 16, 2008
    im having the same problem of noise...its as if the water is surging and it shakes the sink like a thud sound...the sound comes quicker if the handles are turned all the way open and slower the opposite...is this the same?
  • jon3550 Oct 08, 2008
    The kitchen faucet is making a shuddering noise and the hand spray has stopped altogether
    President:
  • 2,712 Answers
A noisy washer-type faucet is usually caused by a loose seat washer. To stop the noise, first turn off the water and take the faucet apart as described previously. If the washer is loose, tighten it or replace it. After threading the stem back into the faucet body, try moving it up and down. If it moves, the stem is worn and the entire faucet must be replaced. Some faucets are noisy due to poor design and construction. The only way to solve this problem is to replace the faucet with a quality one.
Posted on Aug 27, 2008
Barhroom Faucet repair questions
The make and model of the faucet is necessary, most faucet stems are brass and that metal is soft. The handles are held on with a machine screw.
Feb 24, 2017 | Plumbing
How do I repair a bathtub faucet?
If you really want to know, go to YouTube.com and type on " how to repair a bathroom faucet. "
Aug 03, 2014 | Home
How do you repair a leaky centerset Kohler forte fauset
That faucet has a lifetime warranty. Call Kohler (1-800-4-Kohler) and tell them you need a new cartridge for a K-10270 faucet.
May 01, 2014 | Kohler Forte Two Handle Centerset Lavatory...
Peerless faucet sometimes won't turn on
It sounds to me like the rubber o-rings are getting old. Try posting your concerns on the Peerless Customer Support webpage. They can help you identify the model of your faucet and what repair kit to purchase. (Repair is fairly easy, the faucet is repaired in-place).
Customer Support Peerless Faucet
Apr 16, 2014 | Peerless Industries Peerless& Single...
Yesterday I was washinh some dishes in the sink when the hot water just turned off while running. I pushed the handle to off and then back on and the cold water works fine but no hot water! I cchecked the...
Depending on what brand of faucet you have you may need to replace the cartridge,moen and clones, or stem/cartridge on delta and similar. I would not replace the faucet until I was sure that you had hot water to the kitchen faucet and the faucet was going to cost more to repair then replace.
If you have supply valves for kitchen faucet I would shut them off and try to take faucet apart to determine where the hot water is stopping. Do not try to force things to much or you may make the faucet totally useless.
If you know what name brand your faucet is you can find several sites on u-tube that show good repair procedures.
I hope this helps you. Thank you.
Jan 12, 2011 | Home
Water does not shut off in shower, what can I do
There are a number of reasons your faucet may not be shutting off. If you have an old type of faucet, the problem may be due to a worn out washer, or the faucet may have a damaged seat. In which case, there is a tool that can be purchased in your neighborhood hardware store. You will have to disassemble the faucet and examine the seat to verify the damage. In older faucets, it is sometimes better to replace the faucet than make the repairs, as the repairs and the search for parts to repair the faucet may be almost impossible to find.
Or you may have a washerless faucet which actually has a different type of spring loaded washer, and will wear over a period of time as well.
The shut off valve may even be somewhat loose and require tightening. In most cases, this can be verified if the handle turns 360 degrees and never tightens completely.
I hope this helps you solve your problem
Oct 08, 2010 | Home
How to repair facet stem for glacier bay products kitchen sink
Theres not much you can do to repair the stem except replacing the small O-ring up inside. You can call Glacier Bay and ask for a new stem ( the faucet has a limited lifetime warranty. You can also use Delta faucet repair parts in your Glacier Bay kitchen faucet; they come from the same mold. Heres a link to Glacier Bay 2 handle kitchen faucet repair. Heres one to the Glacier Bay faucet manual for your faucet.
Sep 16, 2010 | Globe Union Glacier Bay 8 In Double Handle...
Greetings! My Kohler kitchen faucet model K-10416 with sprayer (16 months in use) is making noise when water is turned on in both hot and cold positions. Also, when sprayer is used water flow is not being...
Begin by shutting off the water to the faucet. Then, on the back of the handle you will find a small button. remove it with a small knife blade and underneath you will see a 1/8" set screw. Use a 1/8" inch allen wrench to remove the set screw. You can then unscrew the bonnet and remove the diverter. Take the diverter to a hardware store or plumbing supply to purchase the appropriate repair kit. goodluck.
Jan 20, 2009 | Plumbing
Danze D316440DNT Fairmont Two Handle Wall Mount Bathroom Faucet with Valve Logo
966 people viewed this question
Top Danze Plumbing Experts
john h
Andrew Bugbee
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
