Question about Danze Fairmont Double Handle Roman Tub Faucet with Valve and Lever Handles
Kitchen faucet Remove
How do I remove my old faucet?
  • ken l Nov 30, 2008
    I have a Grohe Europlus II kitchen faucet, model 33939. There's a leak in the water supply that I've isolated as originating from the handle. I imagine this is a defect that I can't fix. I'm trying to figure out how to remove the unit rom the sink. On the underside, I see a metal horseshoe nut that's attached to the pipe threads. There's also a plastic cover that has a triangular shape that is putting pressue on the underside of the sink. I'm guessing I need to use a screwdriver and hammer to tap the horseshoe shaped nut loose?
  • Anonymous Mar 18, 2014
    need to know how to remove the cartridge
    President:
  • 2,712 Answers
Start by turning off the water supply, either by shutting off the main water supply to your house (probably located close to your water meter), or by closing the shutoff valves on the water supply lines to your faucet. Then, open the tap to allow the water to drain out of the lines and remove any water pressure. Next, use your adjustable wrench and disconnect the hot and cold water supply lines running to the faucet. If you're going to replace the lines, disconnect them at the shutoff valve, but if you're going to reuse the existing lines, do your disconnects at the base of the faucet itself. ow it's time to actually remove that old faucet. Faucets are attached in one of two ways. Bottom mounted faucets are removed from the top of the sink. To remove a bottom mount faucet, you need to take off the faucet handles and escutcheon to get to the nuts holding the faucet. Once the nuts are exposed, use your wrench to take them off. Top mounted faucets, unfortunately, are held in place by nuts located on the underside of the sink. You'll need to get under the sink to remove them, and space may be at a premium. If you're lucky, you'll be able to use your slip joint or locking pliers to loosen the nuts. However, if pipes are in the way, you'll need to use a basin wrench (a wrench specially designed to work in tight spaces where you don't have room to use an ordinary wrench or pliers). Once you've removed the nuts holding the faucet, just lift it up off the sink. If there is some caulking holding the base to the sink, slide the blade of a utility knife carefully around the faucet base to cut it loose. You'll need to remove any old caulking or "grunge" that may have built up around the old faucet. You can get silicon remover at your home store, and a mixture of vinegar and water or an orange cleaner will remove the grunge.
Posted on Aug 27, 2008
  • 171 Answers
SOURCE: kitchen spout leaks
Hi buffy9,
I'm Harvet the Master Plumber.
Your question is: You have an American Standard two faucet in my kitchen and the base of the spout leaks at the base. How do you remove it and replace the washers?
Are we talking about an American Standard two HANDLE faucet or one of the single handle models?
Thank you,
Harvey your Master Plumber
Posted on Oct 17, 2008
manhandy
  • 146 Answers
SOURCE: american standard kitchen faucet leaking
soak down with WD40 and try again use a bigger wrench they all come off i have not found any that i have not been able remove!
Posted on Jul 08, 2009
  • 3 Answers
SOURCE: Single lever kitchen faucet with pull out sprayer is leaking.
same here..some duct tape should do the trick or you can pay for a repairman
Posted on Jan 01, 2010
  • 25 Answers
SOURCE: how do I remove the handle from a Fairfax(R)
U have to get a handle puller from a plumbing supply store. My husband is a plumber. he says that's all u need to do!
Posted on Jan 04, 2010
  • 122 Answers
SOURCE: How do I remove the aerator on a moen pull out
It should just unscrew. You might need some needle nose pliers as the aerator may be slightly recessed.
Posted on Jan 28, 2010
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Removing an old kitchen faucet
    Some faucets are secured by large nuts threaded onto water supply inlets. There will be no brackets in this case. FYI all securing should be from below. Good luck
    Apr 01, 2015 | Plumbing
    Do I have to remove the entire Delta kitchen faucet in order to replace the pullout faucet hose? If not, can you give me step by step instructions on how to replace it? Thanks.
    Should be able to turn water supply off to faucet and trace the line connecting the pull-out faucet. Remove weight in center on hose line this weight helps retract the faucet head in with the line. Remove it and disconnect the line connection and remove the old one.
    Feb 14, 2011 | Delta Faucet 470-DST Signature Diamond...
    The fucet will no longer move from side to side
    Take the handle off and remove the retainer cup remove the the spout clean and lube. If the faucet is very old I would go ahead and get a rebuild kit and do it all at one time.
    Feb 06, 2011 | Rohl R3830-APC de Lux Pull Out Kitchen...
    Delta Faucet Company 467-SSSD-DST Palo Diamond Seal Technology Pull-out Kitchen Faucet, Stainless, 3 years old and is beginning to drip unless we position the handle just right. Is there a washer? I've...
    I hope this will help please go to this web site for a downloadable parts link. If it is leaking from the spout replace the seats and springs to correct the problem. Turn water off and remove handle with a 1/8" allen wrench and remove retaining collar to access the ball assembly to remove the seats and springs.
    The parts page on this link will give you a break down and hope this will help.
    http://www.deltafaucet.com/kitchen/details/467-SSSD-DST.html
    Dec 30, 2010 | Delta Faucet Delta 467-SSSD-DST Palo...
    Im tryin to remove the ball stem #212 off my faucet?
    Remove handle and on top it has a cap that has to be removed to access the ball it will require maybe a strap wrench or chanel locks with something on teeth to keep it from damaging top cap.
    Remove cap and it will give you access to ball turn .
    Mar 27, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
    American standard kitchen faucet leaking
    Jul 04, 2009 | American Standard Kitchen Faucet 6310 020...
    All faucets have a hot and cold line input. The single handle units have a mixing valve within the handle. Aside from removing the water lines there is usually some type of connecting bolts for the base plate as well that will need to be removed prior to removing the faucet. Do not forget to turn the shut off valves off at the wall before you remove the water lines.
    Good Luck
    Dec 03, 2008 | Plumbing
    Faucet/sprayer coordination
    If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)(this is not your faucet but works the same)
    Here are the instructions:
    1. Turn off water to faucet.
    2. Remove handle.
    3. Remove top cap.
    4. Turning spout back and forth gently lift and remove.
    5. Remove and replace diverter.
    Hope this helps and please remember to rate this!
    Nov 15, 2008 | Delta 2402 Classic Single Handle Kitchen...
    Danze Fairmont Double Handle Roman Tub Faucet with Valve and Lever Handles Logo
    1,989 people viewed this question
    Top Danze Plumbing Experts
    john h
    Andrew Bugbee
    Are you a Danze Plumbing Expert? Answer questions, earn points and help others
