Question about Danze D316440RBT Fairmont Two Handle Wall Mount Bathroom Faucet with Valve
Kitchen faucet Installation
How do I install a kitchen faucet?
    President:
  • 2,712 Answers
Many new faucets require some assembly before mounting to the sink; if that is the case, follow the manufacturer's directions. With most pullout sprayer faucets, the sprayer needs to be threaded through the faucet body first. Insert the rubber gasket between the base plate of the faucet and the sink top to create a watertight seal. If no gasket is provided, pack the cavity of the faucet with plumber's putty, then insert the faucet body through the holes in the sink top. Thread the mounting nuts provided onto the faucet shafts, then center the threaded shafts in the sink's holes and tighten the nuts firmly. Many manufacturers include a special long socket specifically to aid in tightening the mounting nuts. A hole in the socket accepts the shank of a screwdriver, guiding it as you tighten the nuts. If you're mounting the faucet on an installed sink, use this method. If you're installing a pullout sprayer faucet--or a faucet with a separate sprayer--now is the time to connect the sprayer to the faucet body. Check the manufacturer's directions to see if using pipe-wrap tape for this connection is recommended. Use an adjustable wrench to tighten the connection. Most pullout sprayer faucets and faucets with separate sprayers come with a counterweight that attaches to the sprayer hose. This weight helps retract the hose back in to the sink cabinet after you've used the sprayer. Follow the manufacturer's directions on where to secure the weight, and take care not to crimp the hose as you attach the weight. Hook up the faucet's hot and cold supply lines to the water supply shutoff valves under the sink. If necessary, gently bend the copper tubes coming out of the faucet for better access and connect flexible supply tubes to them. Simply wrap a couple of turns of pipe-wrap tape around the threaded nipples on the valves and connect the tubes. Tighten the nuts with an adjustable wrench.
Posted on Aug 27, 2008
  • Anonymous Mar 13, 2012
    detailed install led faucet
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Am installing a new American Standard faucet. Does it need to be lubed prior to installation?
    I think American Standard probably is correct, especially if there is a history of swivel faucets seizing over time.
    Dec 11, 2013 | American Standard 4205.104.075 Reliant...
    How do you remove the tri handle?
    You just pull the handles straight off the faucet. There are no screws or bolts holding the handles. Only a friction guide attached to the faucet stem. You can see this guide in the Grohe Classic Kitchen/Bar Faucet 31.057.000 installation instructions.
    Dec 12, 2010 | Grohe Classic Kitchen/Bar Faucet ...
    Hansgrohe faucet part-no. 92730000 faucet cartrige installation instructions
    Please contact me at the below number or email and I can supply you with a copy of the installation instructions.
    Regards,
    Chris
    Christopher Scott
    Technical Support Specialist
    Hansgrohe Inc.
    1492 Bluegrass Lakes Parkway
    Alpharetta,Ga 30004
    Tel:1-800-334-0455
    Fax:678-762-7042
    Email:Christopher.Scott@hansgrohe.com
    Nov 28, 2010 | Hansgrohe 06649860 Solaris Single Hole...
    My danze kitchen faucet is loose and wobbly i cannot seem to tighten it i no longer have my installation insructions. please help. how do i do it?
    You can see the installation manual here:
    http://www.ajmadison.com/ajmadison/itemdocs/D403412-chrome_manual[1].pdf
    Hope this helps! Remember to rate me, thanks.
    May 26, 2010 | Danze D403412 Melrose Single Handle...
    I have a new Moen 87530 kitchen faucet and the water pressure is greatly decreased. Is there an adjustment. It is not the valves which are fully open.
    Try unscrewing the aerator at the end of the faucet and cleaning it. It may have gotten some trash in it during installation.
    Jul 09, 2009 | Moen 87530 Touch Control Single Handle...
    Instructions for the installation of a Delta 470
    Here is the owners manual and installation instructions for your particular faucet:
    Delta 470
    Hope this helps and please remember to rate this!
    Dec 09, 2008 | Delta Model 470: Signature Kitchen...
    Danze D316440RBT Fairmont Two Handle Wall Mount Bathroom Faucet with Valve Logo
    631 people viewed this question
    Top Danze Plumbing Experts
    john h
    Andrew Bugbee
    Are you a Danze Plumbing Expert? Answer questions, earn points and help others
