Question about Kohler Bathroom Accessory Set with Classic Design, Memoirs by
How to Install Towel Ring
How do I install a towel ring?
    President:
  • 2,712 Answers
Place the mounting bracket against the wall and trace around the inside of the two ovals on the bracket. Gently drill a hole into the center of the traced oval. If you hit a stud, you will not need the anchor. Carefully tap the drywall anchors into the holes. Screw the bracket onto the wall, using the screws provided, into the two anchor points. Make sure the set screw is backed out far enough to set the escutcheon over the mounting bracket. Place the escutcheon over the mounting bracket, top first. Tighten the set screw with the Allen Wrench provided.
Posted on Aug 27, 2008
Towel ring won't stay tight
Try Straightening The Bracket Inside Then Re Fit The Towel Ring
Jan 26, 2013 | Moen YB8086 Mason Towel Ring Bathroom...
My hand towel ring is loose. The wall mount is secure but the ball that holds the towel ring and connects to the wall mount is loose and looks like it could fall off.
Usually there is a set screw in the side of the wall mount. If there is loosen that and take the towel ring down. There maybe a second nut or fastener you can tighten up the ball with. If not just buy another one. Some just get worn out over time its normal.
Feb 02, 2012 | Home
3 red lights
Red Ring of Death, Contact microsoft, theres nothing you can do. they will fix or replace it for you. thats if you have the warranty. you could try the towel trick just type in red ring of death towel trick into youtube
May 09, 2011 | Microsoft Xbox 360 Console
Locating fuel pressure regulator
Fuel Pressure Regulator Removal & Installation 2.2L Engine To Remove:
  1. Relieve the pressure in the fuel system.
  2. Disconnect the negative battery cable.
  3. Disconnect the vacuum hose from the fuel pressure regulator.
  4. Remove the pressure regulator mounting screw.
  5. Remove the fuel pressure regulator assembly with O-ring. Inspect filter screen for contamination. If contaminated, remove and discard.
Fuel pressure regulator removal/installation (2.2L SFI engine) gm-05-22-619.gif
To Install:
  1. Apply clean engine oil to the new pressure regulator O-ring and install the O-ring on the regulator.
  2. Install the regulator on the fuel rail. Apply thread-locker to the mounting screw.
    • Tighten the screw to 106 lb in (12Nm).
  3. Connect the negative battery cable.
  4. Use the following procedure to pressurize the fuel system and check for leaks;
  5. Turn the ignition ON for 2 seconds.
  6. Turn the ignition OFF for 10 seconds.
  7. Turn the ignition switch back ON to run the fuel pump again and pressurize the fuel system.
  8. Check the fuel rail assembly for fuel leaks.
4.3L Engine RPO L35 To Remove:
4.3L (RPO L35) Fuel meter body assembly gm_trk_sil15_02-04_43_fuel_metr_body_assy.gif
  1. Before servicing the vehicle, refer to the Cautions and Warnings in the beginning of this section
  2. Remove or disconnect the following:
    • Upper intake manifold (See: Upper Intake Manifold)
    • Fuel pressure regulator retainer clip (M) and discard the clip
    • Regulator (N) from the housing by twisting and pulling the fuel pressure regulator (N) and using a shop towel to catch any spilled fuel
    • Regulator seal O-ring (R) and discard the O-ring seal
    • Regulator filter (Q) and discard the filter
    • Regulator seal O-ring (P) and discard the O-ring seal
    • Backup ring (O) and discard the ring
  3. Cover the fuel pressure regulator housing to prevent contamination from entering the fuel system
To Install:
  1. Lubricate the NEW O-ring seals with clean engine oil
  2. Assemble the following new parts to the fuel pressure regulator:
    • Backup ring (O)
  3. Install or connect the following:
    • Fuel pressure regulator with the vacuum tube pointing down
    • Upper manifold
  4. Test drive the vehicle to confirm the repairs
RPO LU3 To Remove:
4.3L (RPO LU3) Fuel meter body assembly gm_trk_sil15_02-04_43_rpolu3_fuel_metr_body_assy.gif
    • Fuel pressure regulator retainer clip (E)
    • Regulator (F) from the housing by twisting and pulling the fuel pressure regulator (F) while using a shop towel to catch any spilled fuel
    • Regulator seal O-ring (J) and discard the O-ring seal
    • Regulator filter (I) and discard the filter
    • Regulator seal O-ring (H) and discard the seal
    • Backup ring (G) and discard the backup ring
To Install:
  1. Lubricate the NEW O-ring seals with clean engine oil.
    • Backup ring (G)
    • Fuel pressure regulator (F) with the vacuum tube pointing down
Aug 05, 2010 | 2001 Chevrolet Blazer
Pegasus Estates 861 360L towel ring installation?
there is a groove on the top of rhe towel ring that the mount has an indentation that this groove sits in. The tiny screw pulls the groove into the mount in turn, holding the ring in place
Jul 14, 2009 | Waterstone 4055-ORB Oil Rubbed Bronze...
Printerhead is not installed.
What you will need to keep in mind is that the ink cartridge contains liquid ink, once opened, can and will evaporate. First, wash you hands with soap and water to remove excess finger/hand oils. Use a clean, moist, paper towel, make sure you ring out the excess water from the paper towel before you begin. Remove cartridge, gently wipe the towel over the contact's pad, and the nozzel tip. Use a dry towel, and patt dry, reinstall. and run an alignment pattern test.
Note: If you do not see an ink trail on the paper towel, The Ink has dried up, and you will need to but a new cartridge.
Note: do not touch the Cartridge GOLD contacts, with your fingers, finger OIL will clog the jet pours, and cause them to corrode.
May 07, 2009 | Canon PIXMA MP610 InkJet Printer
Four red rings on my xbox
my xbox 360 has four red rings
May 01, 2009 | Microsoft Xbox 360 Console
I got the red ring of death and did the towel tirck and now my xbox freezes up
The tower trick is only a temporary fix, you will need to replace the xclamp or modify it to fix it for good. See pictures and replacement kit on the following site.
xbox 360 repair kit
Oct 01, 2008 | Microsoft Xbox 360 Console
Xbox 360 Red ring of death
If it still under warranty, contact Microsoft for a replacement.
There is no permanent fix for the Red Ring of Death.
Sep 01, 2008 | Video Game Consoles & Games
Kohler Bathroom Accessory Set with Classic Design, Memoirs by Logo
1,448 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
