Question about Jcp Home Collection Marble-Top Vanity w/ Sink
What Kind of Sinks?
What types of sinks are there? From which materials are they made out of?
    President:
  • 2,712 Answers
Sinks are made of many different materials. These include Stainless steel, Enamel over steel or cast iron, Ceramic, Plastic, Soapstone, Concrete, Terrazzo, Totianota, Wood, Stone, Copper and Glass.
Posted on Aug 27, 2008
2 Suggested Answers
  • 659 Answers
SOURCE: Paint brush solvents stained sinks
Using solvents in a Thermocast sink is a huge no no. The company will have to buy you a new one. There isn't anything you can do.
Posted on Apr 01, 2009
How do you attach the clips for a double sink composite granite sink
if what your speaking of is a sink that's made from 5 pieces of granite , id not suggest you try to use clips to hold it on the bottom of counter top , id suggest you either use Hot glue (works fast) or epoxy (2 PART) either of these would keep you from stesssin the material and it wont snap on you a bucket with shims can be used temp to set it all on (weight ) till epoxy dries
Jan 03, 2017 | Home
How to remove franke sink?
If the clips are plastic you will have to snap them off. the metal ones you might have to cut them off. With the old sinks, when the screws were broken or rusted you would have to cut the clips. NO Easy job.
Sep 04, 2014 | Home
Leaky faucet
Here's a video Miguel Gonzalez suggested as a solution to your problem from YouTube:
Kitchen Sink Faucet and leak repair
Apr 30, 2013 | Home
I'm in the North York - Toronto area, I have a blanco double compartment sink, black, it's approximately 15 years old and it has several chips in the enamel or porecelain. Is there someone who can repair...
If this is a SILGRANIT sink you will need to contact Blanco to find this out they do not reveal the material used in this sink and they may be able to help. This is the web site for Canada.
http://www.blancocanada.com/
Mar 14, 2011 | Blanco Home
My Jacuzzi kitchen sink was installed in 2004, I noticed pitting & stains within one year & reported it to the installer. He took photos & never got back to me. The sink is easily stained,...
New sink,its 2011 and its done its service to its country.Nice Kohler cast iron drop in is the way to go.Most peoples issues with sinks are abrasive cleaners ,even softscrub,it takes the finish off of all types of plumbing fixtures,cast iron- fiberglass- stainless etc.I tell people not to use anything you wouldn't use on your car finish Elkay makes some nice stainless sinks.Top of the line,let jacuzzi stick to whirlpools
Jan 26, 2011 | Jacuzzi Kitchen Iron White Finish...
Installing a vessel sink
Standard Vanity height is approx 34.5". A vessel vanity is approx 31" high. If you cannot remove the legs from your existing vanity then it will have to be replaced or cut down to the correct height. The reason a vessel vanity is lower is because your sink will be approx 3 to 6 inches higher than a standard drop in sink. This may be more work than it is worth. Vessel sinks most often will require a solid surface top, either glass, stone or another type of composite material. The standard laminate vanity top has a particle board substrate which will detiorate quickly at the drain location.
Jul 07, 2010 | Buck 31" Granite Vanity Top for Vessel...
There were no instructions to install my undermount sink. What can I do?
Most under mount sinks are installed before the counter tops go in, they are cut to fit and glued in with 2 part epoxys and secured with screws and clamps. Replacing one in an existing counter top is not an easy job. If you have a granite top, forget it. If it is wood and formica, ok, you can pull the splash off and remove the top, but it is a lot of work. You would be better off with a new top, or a new sink, rim type. Now if you are building a new house and this is new construction, then you can do it no problem. And depending on what kind of top it is, it needs to be screwed and glued. The guy here that did granite for us, would drill out little holes, about 1/4 inch dia, and 1/2 deep for these little machine inserts to go into. Epoxy them in, then clamp the sink down or up to the top with machine screws, about 10/24, 1/2 inch long. Through a clamp, and epoxy the top on, sometimes he used clear silicone. depended on the top. If it was wood, you would just screw into the wood with 1/2 inch pan heads. Hope this helps.
May 15, 2010 | Franke 34" Undermount Double Bowl...
What product to clean a franke sink
Stainless Steel use softscrub on Granite you can use soft scrub or vinegar
Oct 21, 2009 | Franke Home
We have the type of sprayer in the sink (or it
NO GLUE!!!!!!!!!  It is a threaded connection that secures it in place. It is a $5 part at Lowes or HD.
10 minutes to replace.
Apr 13, 2009 | KitchenAid Home
Apr 01, 2009 | Home
Jcp Home Collection Marble-Top Vanity w/ Sink Logo
147 people viewed this question
Top Jcp Home Collection Home Experts
john h
Tom Chichester
Are you a Jcp Home Collection Home Expert? Answer questions, earn points and help others
