Question about Advance Tabco Stainless 3 Compartment Kitchen Sink with Drainboards, Each
Stainless Steel Sink Question
Will my new stainless steel sink scratch?
  • Anonymous Mar 16, 2014
    Shine tarnished stainless steel sink
    President:
  • 2,712 Answers
S with most things, your stainless steel sink WILL scratch with use. However, over time as the sink ages, scratches will become less apparent and in fact blend into the surface. Minor scratches on the inside surfaces of the bowl may be blended into the sink by lightly rubbing a Scotchbrite pad in the direction of the finish grain. Be sure to rinse thoroughly with water and towel dry after this procedure, removing any particles left over from the Scotchbrite as you rinse.
Posted on Aug 27, 2008
Is there a stainless steel or cast iron replacement sink for Americast 7172?
I recommend an Elkay stainless steel sink. The drain is not offset the way the Americast drain is, but that shouldn't be a problem. Celebrity is the name of their basic line but it is not a cheapo sink. It comes in depths of 7", 10", and 12". The 10" and 12" deep ones are special order. They also have the Pacemaker, and the Lustertone, which is their top line sink.
I don't care for cast iron sinks as they sometimes bleed rust through the caulk, get scratched, and quickly lose ther gloss.
Jan 28, 2016 | Home
How can I remove scratches on a stainless steel sink please
if the scratches are very small, you can mix up a paste made from baking soda and vinegar,, clean with a soft cloth and rinse
Aug 29, 2011 | Moen 22218 Camelot Self-Rimming Double...
How to remove scratches from stainless steel appliances
Try this at your own risk. Step 1 Consider using a product made for stainless steel2_bing.gif such as Scratch-B-Gone or Bar Keepers Friend (see Tips).
  • Step 2 Or, try spraying an all-purpose cleaner (such as Formula 4092_bing.gif) on the scratches.
  • Step 3 Use a non-metal scouring pad (such as Scotch-Brite pads) to rub the cleaner in, always rubbing in the direction of the grain.
  • Step 4 Keep the stainless steel wet with the cleaner as you work, and rinse the pad often.
  • Step 5 Rinse the surface and wipe dry.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
    Tips & Warnings
    • Before using any treatment on your stainless cookware, sink or appliances, it is wise to call the manufacturer for advice.
    • A new product called Scratch-B-Gone is touted as the "first aid kit for stainless steel." You can find it at many home improvement stores.
    • Bar Keepers Friend is another product for stainless steel. It can be found in most grocery or home improvement stores, or at www.barkeepersfriend.com.
    • To keep stainless steel sinks from scratching, put a rubber mat in the bottom of the sink to protect it.
    • Avoid using abrasive
    Please rate 4 thumbs for the free answer
    Mar 13, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    What product to clean a franke sink
    Stainless Steel use softscrub on Granite you can use soft scrub or vinegar
    Oct 21, 2009 | Franke Home
    How to clean stainless steel
    You say your new oven...and DW have stains...I will assume (if that's OK) that you have a stainless steel oven...and are washing stainless steel in the DW...but you are having streaks and or white...spots or deposits...Sounds like hard water...you may try a localized..(just for the DW and kitchen sink area) filtration system...to reduce hardness of water...(is this well water)..if so you definitely need filtration...if you don't already have it.
    Here are some issues and or cleaning techniques for stainless steel.
    stainless steel is known for its ability to be a clean surface that resists corrosion and rust. Dirt, dust and grime, however, put stainless steel at risk for corrosion and rust. Luckily, stainless steel responds well to cleaning, never wearing out from excessive cleaning, as long as certain rules are followed. 1. Water and a cloth.
    Routine cleaning can be accomplished by using warm water and a cloth. This is the least risky option For cleaning stainless steel. Dry with a towel or cloth to prevent water spots. Wipe in the directions of the polish lines.
    2. Mild detergent, (dish washing liquid) and cloth.
    For cleaning that needs more power, mild detergent and warm water can do a great job without damaging the stainless steel. Make sure you rinse the surface thoroughly to prevent staining and spotting. Towel dry to prevent water spots which can be caused by minerals in water.
    3. Glass cleaner for fingerprints.
    Fingerprints are one of the biggest complaints about stainless steel, but can be taken care by using glass cleaner or household ammonia. Rinse thoroughly and towel dry. There are some newer types of finishes for stainless steel that resist fingerprints, a must if your pint-sized helpers leave their mark on your stainless steel appliances.
    4. stainless steel Cleaner.
    If you’ve had staining or scratching, or need to polish your stainless steel, a stainless steel cleaner may be a good option. Some of these cleaners and polishes can help minimize scratching and remove stains. They also can polish stainless steel surfaces nicely. Read the directions on the stainless steel cleaner and test in an inconspicuous spot. Be sure to rinse thoroughly and towel dry.
    If this does not help please clarify...with specific model #'s and walk me through (step by step) what the specific problem is and how you address it....Thank you and I hope this helps.............
    Good Luck...........The Fang.
    Mar 06, 2009 | GE Nautilus 24" Built-in Dishwasher
    Deep scratches on blanco granite sink
    The only way to fix scratshes and chips from a granite surface is to use a sander. You would be safer to have the company thet installed it, resurface it. They have the proper equipment.
    Feb 17, 2009 | Blanco 511-620 supreme 2 One-Piece...
    Scratched stainless steel
    there is no cure for that!
    Sep 09, 2008 | Kitchen Ranges
    SCRATCHED STAINLESS STEEL SINK
    Have you tried a really fine steel wool? I don't know if this would work. I have stainless steel farmhouse sink, front exposed all stainless steel. My contractor scratched it up horribly when he was putting it into the kichen. he fixed it amazingly with a fine steel wool pad. I don't know if your scratch is too deep for that but it couldn't hurt. The scratches on our sink were surface but very noticeable. Hope this helps.
    Feb 08, 2008 | Kitchen Ranges
    Advance Tabco Stainless 3 Compartment Kitchen Sink with Drainboards, Each Logo
    237 people viewed this question
    Top Advance Tabco Home Experts
    john h
    Tom Chichester
    Are you an Advance Tabco Home Expert? Answer questions, earn points and help others
