Question about Grohe 20 151 000 Spout Bath Sink
Toilet Sink Question
Is the water from the toilet sink clean?
    President:
  • 2,712 Answers
Yes, the water comes directly form the water supply line (not the tank or bowl). It is no different than the water from your faucet.
Posted on Aug 27, 2008
What is a galley holding tank?
The galley holding tank holds the grey water from the galley.
May 24, 2017 | RVs
Toilet and shower runs great for a year> just had a sink hooked up and now toilet and shower back-up> was the sink hooked up wrong? to a vent or wrong pipe>
Nah, that doesn't sound like the toilet or sink were hooked up wrong, your sewage tank is probably full, you can have it pumped out for $100 or so. They fill up every so often for w/e reason.
May 01, 2016 | Saniflo 002/005/007 Saniplus Toilet with...
What's wrong with macerating toilet?
What is most likely the case is that the toilet is not properly vented by waste plumbing standards. Not all jurisdictions require macerating toilets to be vented, but by not doing so causes pressure in the drain lines as well as some suction which can pull water from sink traps, allowing odors and insects to get into the home.
Oct 23, 2015 | Home
I have a uberhaus dual flush toilet. I turned off the water supply in the house to work on a sink and when I turned it back on the toilet won't fill anymore. If I fill the tank or the bowl it will flush...
You will have to disassemble the fill valve and clean it. When you shut the water off and on to work on the sink it dislodged dirt and scale in the water piping which clogged the toilet fill valve. Check your lavatory sink areators too they may also be partially plugged. Hope this helps.
Bob
Jun 09, 2014 | Home
Air in water pipes
Check the toilet flapper, if the toilet is running it is because the flapper is not sealing properly. Change the flapper or entire flush valve.
Mar 10, 2014 | Plumbing
My Sanilflo system is fed by a toilet and a sink. When the sink fills it to operating the grinder runs for about 5 seconds and switches off. When the toilet is flushed (no solids) the grinder runs for...
The amount of time that the pump operates is determined by the amount of water that is drained into the unit. If the amount of water from the sink is less them the amount flushed then the pump will run accordingly.
Mar 06, 2011 | Saniflo SANIBEST Pump Macerator Grinder...
My saniflo plus is making a humming noise but not draining any water away the sink has filled with water and so has the toilet and shower tray help
My saniflo-plus system is about 12 years old..recently it stopped draining the toilet, etc. I pulled the cover off the pump and checked for blockage and spun the cutter blades...The motor just hums....do I need to replace the entire encased pump assembly?? Help
Jul 07, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
The cold water in the sink and toilet is brown.
This is usually from three things.1. The outside mains water supply pipes have fractured underground and soil etc is contaminating the water. 2. The existing pipework is steel and not copper which is corroding. 3. You have a tank supplying the outlets and this requires cleaning. You dont state if these are the only outlets doing this .
May 20, 2010 | Home
My new EZ-33 cloggs easily with small amount of waste to flush.
you have to take the whole toilet out. you need to check the opening of the down pipe. most likely the wax ring is blocking the soilds. shunt off the water drain out the toilet, unbolt the floor bolts and left it up. clean out the down pipe and replace a new wax ring.
Jun 04, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
Grohe 20 151 000 Spout Bath Sink Logo
Top Grohe Home Experts
Mike
Oloyede Monsuru
Are you a Grohe Home Expert? Answer questions, earn points and help others
