Question about Intermatic EI220 Electronic Auto Shutoff Timers
How much does it Cost?
How much will a simple light timer costs?
    President:
  • 2,712 Answers
Almost any store sells timers for like 7 bucks, just look in the bulb section, its a little square with a dial in the middle you plug in a outlet.
Posted on Aug 27, 2008
Microwave lights up doesn't turn on
The part of the oven called the "magnetron" (this part is what creates/generates the microwave energy that heats the food or liquid) is burned out, the cost to repair is more this part is more than the cost to replace with the cost of Microwaves so depressed by the stagnant economy.
Jan 31, 2012 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
My intermatic switch won't turn off the outdoor lights. It covers the original light switch. It has a plastic cover with a extention that press smaller button underneath that says no op see inst. Please...
I answer questions for free.
I specialize in timers.
According to Intermatic, they no longer make the light switch timer.
I cannot find the instruction manual on Intermatic.
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
From my experience, I suspect that the timer is old and does not function any more.
If this is not correct, add a comment and I will answer
Hammacher makes a wall switch timer. $40
http://www.hammacher.com/Product/78709?promo=Electronics-Safety-Security&catid=106
Intermatic also makes another timer that is simple to operate.
It is called the EJ351 but it has to be wired into the wall.
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers/ej351c.aspx
be3a610.jpgEJ351 cost $25 http://www.nextag.com/intermatic-timer-ej351/stores-html
Nov 01, 2010 | Hardware & Accessories
Whirlpool Ultimate Care II, can't find model#. In order of operation. Will only fill and wash on Hot/Warm wash settings. Spins, drains, won't fill for Warm/Cold rinse, cycle stops . Manually advance...
The timer control unit is defective and might need a replacement. Unless you are going to manage with the manual mode this control unit has to be replaced. Therre can be no repair if the contacts are not functioning as the timer advances.
Now the main issue is the cost and the replacement with all the multiple connections on it. You will have to take great care to see that each wires is removed and put into the correct slot.
Make a note of all the wiring lines inthe contact with the sire colour before you start the job.
Finally the cost of the timer must be estimated. make sure that it is reasonable to do this or manage ffor the time being till a new machine can be thought of.
Just a final word try using a contact cleaner/a good degreaser with power off and manually moving it.
Sep 16, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will not advance to the next setting. Does not drain properlly and have to drain manually from trap area
Your timer is shot! Replace the timer. BUT BE CAREFUL! Timers are pricey!! Look at the cost of the timer against the age of the machine. Is it cost effective?
Mar 05, 2010 | Washing Machines
Washer will not go on spin cycle
Hello there:
It sounds like to me that the timer switch is faulty and needs to be replaced cost about 50-75 dollars and fairly simple to replace ok?
best regards michael
Oct 01, 2009 | LG WM2487H Front Load Washer
1999 buick regal odometer light fading
1999 buick custom century odometer light has gone out. what is the cost to repair? is there a simple way to repair or replace the lighting?
Aug 06, 2009 | 1999 Buick Century
GREEN FLASHING TIMER LIGHT
The problem is the digital module is not booting up. It will have be pulled and repaired. We do this job in the home and depending on where you live the repair cost is between $200 - $300. That set is well worth the repair cost.
Jun 11, 2009 | Televison & Video
My jenn air dual oven timer, temp lights are going out
Sounds like another control board failure, common on this type oven. It appears that a capacitor (#C3 on board) overheats and goes bad. Replacement of cap is a simple soldering job but the caps can be hard to find, try electronics parts houses and explain you need a high temp replacement. Should cost you about a buck. See post by Briangem back in may of 2008, who turned me on to the target cap. Its a 35Volt 86mF.
Apr 29, 2009 | Jenn-Air JJW9830D Electric Double Oven
Replacement Cost
For a pretty simple work it should cost something like 200 dollars. For a more complicated work it can get to around 500-600 dollar.
Aug 27, 2008 | Intermatic EI200 Electronic Auto Shutoff...
Intermatic EI220 Electronic Auto Shutoff Timers Logo
81 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
