Question about Your One Source Square D #HOM 115CP 15A SP Circuit Breaker
Circuit Breakers Test
How do I test a circuit breaker?
  • marki_1522 Feb 22, 2009
    what about the quality?
    President:
  • 1,714 Answers
First of all, is the breaker bad? How did you test it? Breakers don't usually go bad, very seldom. A simple test is to use a meter and check for voltage at the output terminal. Is it tripping or what is going on? Unhook the wire feeding off the breaker, then reset it. If it holds, it's probably fine. You can use an ohm meter and check for 0 ohms through the breaker too (with it unhooked and out of panel)
Posted on Jun 26, 2009
    President:
  • 2,712 Answers
To test a circuit breaker you should set the multimeter to "Volts AC" and touch the prongs to the breaker's terminal screw and a ground. If there is no power, the breaker is faulty and requires replacement.
Posted on Aug 27, 2008
How i do connect the CB in squential timer to run the motor
Posted on Dec 23, 2008
I have a 40 amp gfi circuit breaker for my hot tub and want to know how to test it to ensure that it is not the breaker that is faulty as they are very expensive and from my understanding they cannot be returned for a refund after purchase
Posted on Dec 01, 2008
2 Suggested Answers
muttandjeff
  • 359 Answers
SOURCE: how to fix a circuit breaker after a fuse blows
the first thing i would do is to remove the feed wire from the breaker and see if will reset if it does you have a short in the system , tell me more about the system and maybe i can advise further
Posted on Feb 01, 2009
Can not locate fuse for power windows in fuse box
Interior fuse box. It is a circuit breaker, not a fuse, #28, according to your owners manual. Not only check the circuit breaker, use a test lite and check for voltage on circuit breaker circuits. Sometimes, if faulty window motor, it may cause the circuit breaker to trip. I've seen some circuit breakers that were hot to the touch. After it cools off, it may reset?
Jul 18, 2017 | Cars & Trucks
I have bad spots on my panel. How can I fix it?
probably loose wires at the back of the board
the fix is to get an electrician in to do the job
Aug 26, 2016 | Square D Qo 200 Amp 40 Circuit Indoor...
Outlets do not work, circuit tester says Hot/ground reverse but all connections appear correct, circuit is on an arc arrest breaker.
Move wires to different breaker with same amp rating?
Try different tester?
Test wiring box-by-box to locate the reversed connection.
http://waterheatertimer.org/Basic-house-wiring.html#loose-wire
Check each box for Hot and neutral:
http://waterheatertimer.org/Basic-house-wiring.html#test
Gene
Nov 11, 2014 | Electrical Supplies
The prcblem i have is i have no power in one bedroom, but there are no curcuit breakers that are tripped. so how can you test a breaker other than resetting the breaker. also we have no gfi outlets or gfi...
I don't know how technical you are so here are a few easy tests you can try:
plug a known, working lamp into each plug of the receptacle (top and bottom). This minimizes other potential issues.
Switch each circuit breaker FULLY off and then, Fully on. Yes, it is tedious but sometimes, breakers trip and it doesn't always show.
Still not working? Open up the cover plate and look at the contacts. You should have a black wire going to a gold colored screw and a white wire going to the other side, silver colored screw.
The best test you can conduct is using a simple voltmeter (AC) to test if you are getting voltage to the outlet. No AC Voltage? Try going to the known circuit breaker and measure the voltage coming from the known breaker while the other lead is on your neutral bus. Of course, if you aren't experienced with electricity, I recommend you get a licensed electrician to troubleshoot the issue.
As well, I know you mentioned that you tried resetting breakers but with a load on the circuit and someone else verifying it for you, you may just get lucky. More than likely, you will either encounter a faulty outlet, faulty wiring or a faulty breaker.
Apr 12, 2011 | Electrical Supplies
Is there a way to safely load test a breaker to make sure it will trip correctly
Short of using expensive load test equipment about all one can do is purposely overload the circuit. Usually 2 heavy loads will do it for a 20 amp circuit, such as 2 microwaves or a toaster oven. Turn both on at the same time and it won't take long for the breaker to trip. If the breaker trips on overload it will trip on short circuit, so, DO NOT purposely short circuit the breaker as that is a lot of unneccessary wear and tear on the breaker.
Dec 14, 2010 | Hammering
Cutler Hammer 20 Arc Fault breaker for bedroom outlets will not reset after activating test switch.
The circuit breaker must be turned to the "off" position first from the middle position, and then to the "on" position. The cutler hammer arc breakers carry a lifetime warranty so if it will not reset you may want to contact the manufacture.
Oct 24, 2010 | Cutler Hammer BR120AF BREAKER CIRCUIT BR 1...
The garbage disposal & overhead sink fixture run to the same Square D Qob120 1pole 15amp 120v Circuit Breaker . After a week of consistentlu tripping, the breaker won't allow itself to reset. ...
I would start by replacing the breaker. If a new one trips then check ground and wiring. If it still trips then there must be a problem with the garbage disposal. let us know
Sep 21, 2010 | Square D Qob120 1pole 20amp 120v Circuit...
Bathtub pump totally dead, pump ran dry for 10 sec, is there circuit breakers on pump motors, switch or is it the motor shot. any way to test motor with removing it?
Normally pump motors are connected on a separate
circuit with its own circuit breaker. At your house there is always a electrical control panel housing several circuit breakers for lights, power outlets, range, aircon, motors, etc...Find a tripped off breaker and reset it. To reset the circuit breaker is to switch it to off position and back to on position. Better still you may reset all the circuit breakers except the main
circuit breaker (biggest amp rating).
After resetting the circuit breakers, try to switch your
bathtub pump on, (to test it, if it is still okey). Other-
wise, your motor is damaged and you got to have the
motor rewinded, to be operational.
Dec 09, 2009 | Plumbing
I just bought a new Sperry circuit breaker finder and I can test the transmitter& receiver, but it doesn't respond to the breakers in any way. I tried different outlets, I may be doing something wrong...
Hello
Is there a battery in the scanner? It takes times to clear out the breakers and find the right one. Be patient. It could be defective? Start on the top of the breakers on either side and vertically slide it down to the bottom then up the other side. Make sure it touches the breakers just to the left or right of the switches on each breaker. Again, it takes up to a minute to find the right. Once in awhile it chooses the wrong one.
John
John
Sep 05, 2009 | RTO A.w. Sperry Cs500a Circuit Breaker...
Your One Source Square D #HOM 115CP 15A SP Circuit Breaker Logo
1,067 people viewed this question
Top Your One Source Electrical Supplies Experts
Steve
Lisa
Lisa
ray gallant
Are you a Your One Source Electrical Supply Expert? Answer questions, earn points and help others
