Question about Leviton Acenti Natural 1000W Incandescent/Magnetic Low-Voltage DImmer -
Dimmer Usage questions
Can dimmers save electricity and increase lamp life?
  • 1 more comment
  • Anonymous Mar 13, 2014
    dimmers supplied by wicks
    standard 400w dimmer controlling 6 60w candle lamps, when lamp gives up it causes short circuit and blows dimmer i am now on my 3rd dimmer can you help
    President:
  • 2,712 Answers
Yes. The use of dimmers can reduce the use of electricity and, thereby, save money and help conserve the environment. Dimmer use can also increase the life of the lamps (light bulbs) being controlled.
Posted on Aug 27, 2008
Dimmers can and will save on your bill seeing the lamp(s) are using less voltage. By diming your dimmer 10% your lamps lifes span goes up by 70%
Posted on May 05, 2012
Only puts out 9 volts
electrical - When I turn down the dimmer switch on my lights ...
diy.stackexchange.com/.../when-i-turn-down-the-dimmer-switch-on-my-...
Jan 26, 2012 - My wife and I have several lights on dimmer switches throughout our ... 8,210951107 ... As Power = Voltage² / Resistance, and Voltage is always 230V (or.... As you see, not only will you save electricity but your lamps will last longer. ... down to the lowest setting, the dimmer is putting out 1000W of heat?
electrical - Why am I measuring 16 volts on a wire that ...
diy.stackexchange.com/.../why-am-i-measuring-16-volts-on-a-wire-that-...
Tester101?. 77.7k28154316. asked Jul 7 '13 at 1:20. Philip. 179129 ... @Tester101, it was a standard snap switch, but I put a dimmer on it now. .... I ended up using the red wire with 16V on it, and it controls my incandescent light just fine.
Dec 15, 2015 | Electrical Supplies
My led lights start to strobe when I turn on exterior light that is fed from the same line circuit. Solution?
There are two things coming into play here; the lamps and the dimmer(s).
First; LED and CFL type lamps that are to be used on a dimmer switch - must be identified for that use. Looks for the word dimmable on the packaging or bulb itself. These lamps are generally a little more expensive than their non-dimmable counterparts. If it does not indicate it is dimmable, then it isn't - and should not be installed on a circuit controlled by a dimmer switch.
Second; a dimmer switch that will be used to control LED and CFL bulbs (that are identified for use with a dimmer) must also be identified for use with dimmable LED and CFL bulbs. Again, these dimmer switches will be identified for this use and will cost more than those that work with standard filament type bulbs.
Lutron has dimmers for your circuit called a "C•L™ Dimmer" and supports Incandescent / Halogen, Dimmable Compact Fluorescent (CFL) and Dimmable Light Emitting Diodes (LED) type lamps. have a look here:
Lutron Maestro Dimmer and Switch Models
Also, be wary of the total load (wattage) of the lamps being controlled. If you have multiple dimmers in the same box, derating of the switch's wattage capacity (due to increased heat) will be required.
Dec 03, 2015 | Maestro Electrical Supplies
Dashboard lights will go out randomly. It has done it for short periods before but it did it for 200 miles on hwy in dark.
The sensor is usually located on the top of your dashboard. You might see it if you look into your vehicle through your windshield at your dash.
I have seen( one time ) that a gps was bright enough that it caused the dash lights not to come on because the sensor thought it was light outside.
Or you could have gotten a bad sensor.
Oct 23, 2015 | 2010 Chevrolet Equinox
Led christmas lights too bright
Usually if you plug a lamp dimmer in, you can dim LEDs. The problem is that you may be using a switch-mode power supply which will give feedback and automatically increase the voltage. The manufacturer is probably the only safe way to get information as to whether this can be done.
Dec 12, 2013 | Electrical Supplies
Instrument Panel Lights
Daytime headlight issue ? No , no sensor behind the front bumper . No Daytime time head lamp issue , doesn't turn on the instrument panel light's . This is more then likely a remote dimmer module problem .
Interior Lights Dimming Circuit Description (Pontiac)
When the park lights are on, battery positive voltage (B+) is applied via CKT 32 (YEL) to the remote dimmer module. The interior dimming switch in the lamp dimmer switch is a variable resistor which applies the dimming input via CKT 44 (DK GRN) to the remote dimmer module. The potentiometer in the lamp dimmer switch cannot provide enough current in order to operate the incandescent lights. The remote dimmer module amplifies the current, applying a variable voltage to the incandescent lights. As the amount of current increases, the lamps become brighter. As the amount of current decreases, the lamps become dimmer.
The radio, heater and A/C control assembly, instrument cluster, and passenger climate control each has a vacuum fluorescent (VF) display. When each module receives an input that the ignition switch is turned to the RUN position, each module activates the VF display at the full intensity. When the park lights are on, the radio receives the dimming level from an input on CKT 8 (GRY). The radio then relays this information to any other modules with VF displays. All modules with VF displays then adjust the dimming level of their VF display in order to match the level of the incandescent lamps.
May 16, 2017 | 1998 Pontiac Bonneville
How to do energy saver dimming ?
Most modern dimmers provide normal energy savings. They reduce the total amount of watts consumed on the circuit. Many years ago, dimmers only reduced the watts consumed as light - making up the difference as heat in the dimmer switch. A 100W light turned down to 1/2 wattage at a dimmer switch resulted in 50 watts of light at the bulb, but 50 watts of heat was created in the switch. That was zero energy savings. The newer electronic dimmers will still let 50 watts be used as light, but only a few watts as heat in the switch.
To maximized energy savings, use of new cold cathode technology lights such as CFL (compact fluorescent lamp), LED (Light Emitting Diode), etc. types are suggested. You can use these lamps on a dimmer to furrther reduce the amount of energy used - but only if the lamp indicates that it is dimmable.
If the lamp or fixture does not specifically state it can be used on a dimmer, don't. This includes powering a light through a dimmer that is set to maximum brightness. Use a standard non-dimming switch instead.
I hope this helps & good luck!
Apr 14, 2012 | Electrical Supplies
I just replaced my bulbs on my ceiling fan light fixture with the compact flourescent bulbs 13 watt to replace the regular 60 watt bulbs but they are flickering now. Could there be a problem with wiring...
Your remote control I would assume includes a dimmer for the light. CFL bulbs are not compatible with dimmers. If it has a dimmer, you must use incandescent bulbs.
Feb 14, 2011 | Hampton Bay 52 In. White Redington...
New installation of Luton tg603pg dimmer - lights are considerably less bright at full brightness setting than previous switch. bad switch, or other problem?
No problem, merely a misunderstanding. That's actually the point of that product (the 'g' in the model number was the clue). This is their "eco-dim" line of products, and its specifically designed to not let the lights go over 85% light level. Its a means of using the dimmer to help guarantee energy savings and lamp life extension.
If this bothers you, then I would return it and grab one that doesn't have the "g" in the model number.
Feb 04, 2011 | Lutron ELECTRONICS CO. Q-603PH-WH "QUOTO"...
How does it work?
By decreasing or increasing the RMS voltage and hence the mean power to the lamp it is possible to vary the intensity of the light output. Although variable-voltage devices are used for various purposes, the term dimmer is generally reserved for those intended to control lighting.
Aug 27, 2008 | Leviton 8371419W Lamp Cord Dimmer
Leviton Acenti Natural 1000W Incandescent/Magnetic Low-Voltage DImmer -  Logo
158 people viewed this question
Top Leviton Electrical Supplies Experts
 Kenneth
Kenneth
Steve
Hippy_dd
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
