Question about Lutron TT-300NLH-BL Black Manual Lamp Dimmer
What Kind of Dimmer?
What kind of dimmer should be used to control low voltage lighting?
  • stevess1960 Jan 05, 2009
    can you use an incandesent dimmer to control a low voltage electronic load? transformer manufacturers say no problem, dimmer manufacturers not so, ie lv electronic requires lv electronic dimmer... what is the real deal
    President:
  • 2,712 Answers
If the low voltage lighting system uses an electronic transformer, then a dimmer designed for this type of transformer should be used. Likewise, if the low voltage lighting system uses a magnetic transformer, then a dimmer designed for this type of transformer should be used.
Posted on Aug 27, 2008
2005 cavalier dash lights not working. all fuses are goood. replaced cluster, dimmer switch, multifunction switch
Back lighting or warning lights ? check engine , ABS , air bags , seat belt , oil light etc... ?
Interior Lamps Dimming
The second group includes lamps which may be dimmed. This group may use a combination of vacuum fluorescent (VF) illumination and incandescent lamps.
• Power window switches
• HVAC control head assembly
• Radio
• The instrument panel cluster (IPC)
When the ignition switch is turned to the ON position, the vacuum fluorescent (VF) display (radio) turns on at maximum brightness. When the park lamps are ON all incandescent back lighting turn ON at the dimming level indicated by the IP dimmer switch. At the same time all vacuum fluorescent (VF) displays dim to match the indicated dimming level. When the headlamp switch is placed in the PARK position, the park lamp supply voltage circuit provides an input to the body control module (BCM). The BCM then supplies voltage to the instrument panel dimmer switch through the instrument panel dimming lamps control circuit. The setting of the instrument panel dimmer switch determines the amount of voltage that the instrument panel dimmer switch supplies to the BCM through the instrument panel dimming lamps low reference circuit. The BCM then sends a pulse width modulated (PWM) voltage to all the interior lamps. All the vacuum florescent (VF) and incandescent back lighting lamps are provided a specific voltage and are then grounded. When the headlight switch is turned to the PARK or HEADLAMP position, all incandescent back lighting turn on at the dimming level indicated by the IP dimmer switch. When the IP dimmer switch is moved from MIN to MAX, all vacuum fluorescent (VF) displays, as well as all incandescent back lighting respond from Minimum intensity to maximum brightness in response to the IP dimmer switch.
I would have it checked for DTC'S - diagnostic trouble codes stored in the BCM !
DTC B2624 Display Dimming Input Range/Performance
The body control module (BCM) supplies voltage to the instrument panel dimmer switch through the instrument panel dimmer switch signal circuit. The dimmer switch varies the voltage and returns the new voltage to the BCM through the dimmer switch signal return circuit. The BCM uses this voltage to determine the illumination level of the instrument panel lamps.
DTC B2625 Display Dimming Pulse Width Modulation (PWM) Output Circuit Range/Performance
The body control module (BCM) receives a variable voltage from the instrument panel (I/P) lamp dimmer switch. The BCM uses this signal in order to vary the illumination level of the I/P lamps. The I/P dimming lamps output from the BCM is a pulse width modulated voltage supply used to light the I/P lamps. If a malfunction occurs in the I/P dimming lamps output circuit, this DTC is set.
DTC B2662 Park Lamp Switch Circuit Malfunction
The park lamps are controlled by the turn/headlamp switch. Positive battery voltage is supplied to the switch through the EXT LP fuse. When the turn/headlamp switch is placed in the park or head position, battery voltage is supplied to the park lamps. The body control module (BCM) is also connected to the park lamp circuit to sense whether or not the park lamps turn ON when the low beam or high beam headlamps are turned ON. The BCM also uses the parklamp battery positive voltage to power the instrument panel (I/P) dimmer output circuit. If the BCM senses that the low beam or high beam headlamps are ON and the park lamp input is not active, DTC B2662 sets.
Do the park lamps work ?
Jun 11, 2017 | Cars & Trucks
I have a self-installed Leviton TTI06-1LM dimmer (600w capacity) that controls a halogen light that uses 12x 12v/20w (140w total) halogen lights. The dimmer works fine, but once a day, or perhaps every...
Your issue is that the dimmer is not rated to handle the type of fixture/lamps its controlling.
From a lighting control standpoint, the 12V-lamps classify as "low-voltage halogen" and, somewhere in that circuit, have a transformer(s) converting the 120V~ down to 12V~. Using incandescent dimmers (like the one you are using) can cause compatibility issues with those transformers. What I suspect is happening is that the incompatibily is either throwing voltage spikes or current spikes on the line which are causing the dimmer to enter some sort of "safety" mode to shut everything down before any problems occur.
My recommendation is to first figure out what type of transformer it is: Either magnetic low-voltage, or electronic low-voltage. Ideally you would contact the transformer manufacturer (or look up their specs online) to figure that out. Other rules of thumb: if the transformer's big & bulky, it's probably magnetic - conversely if its lightweight, it's probably electronic. If its only one transformer controlling all of the lamps together, it's probably magnetic - conversely if its one of those transformers where the transformer and light bulb come togheter as one assembled unit and then snap into the track, it's probably electronic.
Then make sure the dimmer is rated for magnetic low-voltage, or electronic low-voltage (depending upon what the transformer is).
Feb 11, 2011 | Leviton Decora Light Dimmer Switch
Hi, I have a leviton slide dimmer controlling 4 pot lights with gu10 bulbs. There is also 6 receptacles on this 15 amp circuit. I had a regular 2 pole switch on there, with no problems. When I converted...
You said they are 50 watt GU10's, so I would assume they are 120V halogens, and you must simply have gotten a bad dimmer. But if these GU10's are 50 watt equivalent (LED's or CFL's) then the bulbs will have their own transformers built into them, and would be incompatible with a dimmer switch. It also might be the case that you have low voltage halogens which would use a transformer, shared or individual, and these would also be incompatible with a dimmer. (I don't know offhand if GU10's are available with low voltage halogens.)
Sep 17, 2010 | Leviton WHT SLIDE DIMMER
I need to install a diva low voltage electronic dimmer. An incandesent dimmer was previously installed. lights flickered. There are 4 wires on the dimmer. (green black whate and yellow) I know what to do...
The dimmer connections should go like this.
Black from dimmer to black Constant Power In Wall
White from dimmer to Neutral (Whites) in wall
Yellow from dimmer to wire out to light (usually black)
Green from dimmer to BARE GROUND WIRE
May 08, 2010 | Lutron Diva Electronic Low Voltage 3-Way...
Changed battery now clock blinks when lights are on''
it may be the very expensive lighting control module. $250 from tascafordparts.com.
It is under the dash just above the brake pedal behind the sound panel.
couple of tests for you.
A15 CHECK DIMMER SWITCH OPERATION
  • Using a voltmeter connected to a known good ground, check for voltage to Circuit 1036 (BR/W) from headlamp switch.
  • Operate dimmer switch to LOW setting.
  • Operate dimmer switch to HI setting.
  • Using a voltmeter, check for voltage to Circuit 1035 (O/R) from headlamp switch.
  • Is voltage present on both circuits?
ssa~us~en~file=arrow.gif~gen~ref.gifYes
GO to A16 .
ssa~us~en~file=arrow.gif~gen~ref.gifNo
If ground circuit to headlamp switch is good, REPLACE open headlamp dimmer switch. RESTORE vehicle. RETEST system.
A16 CHECK FOR DIMMER INPUT TO LCM
  • While operating dimmer switch, connect a voltmeter to ground and alternately to Pin B16, Circuit 1035 (O/R) and Pin B15, Circuit 1036 (BR/W).
  • Is voltage present alternately at both circuits?
REPLACE lighting control module (LCM). RESTORE vehicle. RETEST system.
SERVICE circuit(s) in question for open/shorted circuit(s). RESTORE vehicle. RETEST system.
Mar 12, 2009 | 1995 Lincoln Town Car
LUTRON DIMMER
The Lutron Maestro dimmer isn't rated or designed to operate low voltage lighting as it is a 120 V-AC rated electronic dimmer. You should either install a standard low voltage ON/OFF switch on this installation or obtain a dimmer rated for use on low voltage lights.
You need special low voltage dimmer designed for use on the low voltage pucks lights you have installed. Usually the low voltage is either 12, 24, or 36 volts, depending on the manufacturer of your particular light set. Once the correct dimmer is in place, the problem with the flickering and pulsing of the lights, should cease.
If you still are having this problem and you can't find a low voltage dimmer, you can contact the maker of your low voltage light kit and they can provide you with an acceptable dimmer option for your lights.
Most Home Depot and Lowe's carry the low voltage puck light kits, and usually have accessories for these lights, including dimmer switches that will work with them.
Hope you find this Very Helpful and best regards!
PS: I found this old, unanswered question and wanted to provide a solution to close out the problem and clear the question from the site.
Feb 10, 2009 | Lutron Electronic Low-Voltage...
Lutron Dimmer Not Dimming But On/Off Works
What is the dimmer rated for? Your load on the track appears to be 200 watts. A standard dimmer will burn out, you need to look on the dimmer to see what it is rated for. Did it run hot with the dimmer before you had this problem? They make dimmers for higher wattage that will do the job for you.
Feb 05, 2009 | Lutron ELECTRONICS S-1000H-LA SKYLARK...
Dimmer Usage questions
Yes. The use of dimmers can reduce the use of electricity and, thereby, save money and help conserve the environment. Dimmer use can also increase the life of the lamps (light bulbs) being controlled.
Aug 27, 2008 | Leviton Acenti Natural 1000W...
How many dimmers types?
Certain dimmers can control standard incandescent lamps that use 120 volts while other dimmers can control low voltage xenon or halogen light sources that use 12 or 24 volts.
Aug 27, 2008 | Lutron Electronic Low-Voltage...
Lutron TT-300NLH-BL Black Manual Lamp Dimmer Logo
347 people viewed this question
Top Lutron Electrical Supplies Experts
Steve
jdthefixer
berniekruege
Level 1 Expert
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
