Question about Leviton 8371419W Lamp Cord Dimmer
How does it work?
How does the dimmer work?
    President:
  • 2,712 Answers
By decreasing or increasing the RMS voltage and hence the mean power to the lamp it is possible to vary the intensity of the light output. Although variable-voltage devices are used for various purposes, the term dimmer is generally reserved for those intended to control lighting.
Posted on Aug 27, 2008
I have a dimmer switch installed and it wont work with the celing fan
Your question has two switches and 1 dimmer.
The fan switch works.
The light switch works.
The dimmer does not. What is the dimmer connected to?
Dimmers typically will not control fan speed unless they are rated to do that.
Do you have a 3-way switching where two switches control same light, and you installed the dimmer in place of 3-way switch?
Sep 06, 2012 | Westinghouse Contempra Trio 42" Ceiling...
I am replacing a Lightolier 3-way Dimmer switch with a Leviton IPI06-1LX Dimmer switch. When I install the dimmer switch it works fine. But the on/off regular wall switch won't turn the light on or...
It depends. Some dimmers are considered "smart dimmers," where the control on the other end of the 3-way has to be intelligent enough to send a signal back to the dimmer. If the Lightolier dimmer was a smart dimmer, then chances are that the 3-way control was designed to talk only to that specific dimmer. The Leviton product you replaced it with is a simple, basic dimmer - it should work in conjunction with a simple, basic 3-way switch.
If the 3-way control already IS a simple, basic 3-way switch - then I would simply re-check the wiring of the dimmer you replaced.
Sep 11, 2011 | Electrical Supplies
I am wondering if a defective dimmer could be the cause of my kitchen lights being dimmer than usual
1) Electronics inside dimmer can go bad, and lights will not work as before.
Simply replace dimmer.
I buy new dimmers at Home Depot.
2) Lutron shows a wide variety of dimmers:
Use pictures from page to identify type of dimmer you want, and then google search: For example search for 'skylark dimmer' or 'rotary dimmer'
http://www.lutron.com/Products/StandAloneControls/Dimmers-Switches/Pages/DimmersSwitches.aspx
3) Add a comment for more free help. For example how to install new dimmer without calling electrician.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on dimmer, or any do-it-yourself project.
Jan 12, 2011 | Leviton #R00-6684-000 LGTD 3W Rotary...
I AM REPLACING A 3 WAY WITH A LEVITON TRUE TOUCH 3WAY DIMMER. IT APPEARS AS THOUGH THE OTHER 3WAY IS ACTING AS A SWITCH FOR THE DIMMER. IF THE OTHER SWITH IS "ON" THEN THE DIMMER WORKES FINE...
The other switch should only be changing from one wire being hot when it is in the up position to a second wire being hot when it is in the down position. Then the new dimmer should be hot on one terminal when the other switch is up and on a different terminal when it is down.
I'm not sure how the Leviton dimmer works, though.
Gary
Jan 05, 2011 | Lutron + Leviton Dimmers Leviton Decora...
My Lutron dimmer/lights suddenly will not turn on. all electricity works throughout the house. The green light that usually is lit on the panel is not on either. any suggestions?
Indicator light is OFF.
Either dimmer stopped working or power to dimmer is off.
Check if electricity is present inside box.
Check nearby electrical plug to see if everything nearby has power.
Swap dimmer with regular switch and see if lights turn ON.
Check dimmer wires: if wires to dimmer are pushed into 'quick connect' holes on back of dimmer, these wires can get loose.
If dimmer is connected by wire nut, sometimes a wire can pull loose.
If no electricity is inside the box, and breaker is ON, then there is a loose wire inside one of the boxes on that circuit and electrician has to track back until loose wire is discovered.
Replacement parts for in-wall devices are not made.
If new dimmer is necessary, consider lighting factors:
Total wattage of lights. New dimmer has watt rating.
Type of lights. Dimmers specify florescent or tungsten (incandescent) or both.
Single-pole and 3-way. If two dimmers control same lights, one is control dimmer, other is companion dimmer.
Nov 15, 2010 | Lutron #MA-LFQHW-WH 300W White SP Light...
The on-off switch for the dimmer is "loose" and does not turn the light on anymore.
There are no repair parts for in-wall electrical devices.
When they go dad you buy another.
Lowes and Home Depot carry inexpensive dimmers.
Look for 3 things:
1) Wattage: most off-the-shelf dimmers are 500-1000Watts. Add up total wattage.
2) If you are dimming incandescent bulbs, dimmer package will say tungsten or incandescent.
Package will say florescent if dimmer also works for florescent bulbs.
3) If dimmer is 3-way, with a dimmer on either end of a room, many times the dimmers are sold as a package of 2 dimmers with 1 dimmer that controls the other dimmer.
Lutron dimmers
Leviton dimmers
http://www.leviton.com/OA_HTML/ibeCCtpSctDspRte.jsp?section=15265&minisite=10025
Nov 15, 2010 | Lutron #DVW-603PGH-WH 600W White Single...
I only need a single pole dimmer switch. Which product do i buy. I bought the smart dimmer system remote, but it doesn't seem to be right.
The photo shows the master 'smart' dimmer, but you purchased the remote 'smart' dimmer that is slave to the master dimmer.
So you are correct, that is not the correct dimmer for a single-pole application.
Cooper brand Aspire dimmers are available in 'Smart' dimmer and just plain old dimmer.
Smarthome has a plain old aspire dimmer
http://www.smarthome.com/21530S/Aspire-9530DS-600w-Slide-Dimmer-Desert-Sand/p.aspx
Google products also shows the Lutro Maestro dimmer
http://www.google.com/products/catalog?q=maestro+dimmer
Lowes and Home Depot have ordinary dimmers also.
Both the dimmer linked to above will work for your single pole application. Keep in mind, they also work for 3-way applications so there will be an extra wire.
Since you know the phrase 'single pole' I suspect the wiring for you will be a cinch.
If you need assistance with the new dimmer, add a comment and I will answer.
Oct 30, 2010 | Master Heaters Aspire Design System Smart...
I just purchased 2 of these dimmers from ebay but they do not have the instructions. Both are exactly alike and have 2 wires. How do they install?
You posted under Pass and Seymour rotary dimmer that has two wires.
If your dimmer is like other rotary dimmers, it has a black and red wire.
Or it has 2 black wires.
If your switch has 3 wires, then the dimmer will not work.
If your switch has 2 wires:
Probably both switch wires are black.
One of these wires goes to Load (lights)
The other wire is Hot from breaker box
If dimmer has 2 black wires, they connect to either wire from switch.
If dimmer has black and red wires,
> dimmer-black connects to Hot from breaker
> dimmer red connects to Load
> green (if available) goes to bare copper wire
Recommendation:
If you do not know which wire is Hot from breaker, simply hook up dimmer and see if it works.
If it doesn't, then reverse the wires.
If this information does not fit your specific dimmer, please answer back with more details and we'll get it working.
Oct 23, 2010 | Pass & Seymour #R600PLAV 600W Almond SP...
On/off works but dimmers do not. leviton toggle
If each pendant has an individual transformer that is about the size of a hotwheel then you need a dimmer specifically for ELECTRONIC LOW VOLTAGE. A lot of electricians don't know that the different types of lights require different dimmers. Most store bought dimmers are for incandescent lights only, and some nicer dimmers like the Lutron Maestro's are rated for incandescent or MAGNETIC Low Voltage which require a different Sin wave interuption. I don't know that leviton makes a dimmer in that style for Electronic Low Voltage. You could install a Lutron DVELV300P-Wh, but that is a Decora opening. http://www.lutron.com/CMS400/WorkArea/downloadasset.aspx?id=25437
Here is a link to explain the difference in how the dimmer needs to work. Good luck!
Mar 03, 2010 | Leviton Toggle Touch Dimmer - TGI06-1LB -...
Lutron Dimmer Not Dimming But On/Off Works
What is the dimmer rated for? Your load on the track appears to be 200 watts. A standard dimmer will burn out, you need to look on the dimmer to see what it is rated for. Did it run hot with the dimmer before you had this problem? They make dimmers for higher wattage that will do the job for you.
Feb 05, 2009 | Lutron ELECTRONICS S-1000H-LA SKYLARK...
Leviton 8371419W Lamp Cord Dimmer Logo
257 people viewed this question
Top Leviton Electrical Supplies Experts
 Kenneth
Kenneth
Steve
Hippy_dd
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
