Question about Gen Tran 12-Circuit Hard-Wired Transfer Switch
Installation How To
How do I replace a light switch?
  • onebarber1 Sep 18, 2008
    i need a diagram on how to hook it up
  • Anonymous Nov 29, 2008
    hi are the red wires the hot ones or the black
    President:
  • 2,712 Answers
Installing the new switch is fairly simple. Connect the two hot (black) wires to the two brass terminals on the new switch. Gently push the new switch back into the box. Fasten the switch to the box with the two long screws at the top and bottom of the switch.
Posted on Aug 27, 2008
Replace brake light switch on 1995 lincoln continental and how long to replace
Remove the under dash panel.
Locate the brake light switch assembly near the top of the brake pedal and disconnect the switch from the brake pedal by removing the retaining clip.
Use a small screwdriver to unlock the electrical connector, then unplug the connector from the brake light switch.
Reverse for installation. Should take an hour or less to complete.
Mar 28, 2015 | 1995 Lincoln Continental
Tip
Flashlight Battery and Bulb Installation and...
FLASHLIGHT
BATTERY INSTALLATION FOR TORCH:
Open the Torch Battery Door located on the bottom of the Torch.
Insert 4 “A A” (1 .5V UM-3) (not included) batteries (alkaline
batteries are recommended) into the torch compartment. Be sure
the polarity (+ and
-) matches, as marked inside the battery
compartment.
FLASHLIGHT:
Slide the Torch Function Switch to the “FLASH” position, the Torch will light. To turn off, slide the Torch Function Switch to the “OFF’ position.
FLASH/BLINK FUNCTION:
Slide the Torch Function Switch to “FLASH/BLINK” position, tha Torch will light and thc bulbs on both sides of Torch will blink.
BULB REPLACEMENT:
Rotate the Torch Cover anticlockwise to hear “click”
then p
ull out the cover, remove the old bulb. Then pull
out the torch cup, remove the blinker’s
old bulbs and
reinstall new bulbs. Replace the torch cup, then reinstall
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
Refrigerator light not working,alreadyreplaced switch
Did you check the bulb? Those filaments do wear out and open necessitating the installation of another smaller appliance bulb. If a new working bulb also does not work, confirm that the socket is receiving power from the light switch you replaced..
Mar 20, 2015 | GE Refrigerators
How to fit dimmer switch
The dimmer switch you select will depend on the type of bulbs you will be using. The 'original type ' of dimmer works with regular incandescent bulbs and halogen bulbs only. They cost around $15.00. Then there are dimmers for compact florescent (cfl) bulbs and LED lights that are dimmable, as well for regular light bulbs. These types of dimmers are more expensive, ranging in price form around $40.00 upwards.
Light Switches Dimmers
If you are replacing a single pole switch ( just one switch that operates lights) you'll need a single pole dimmer. If you are replacing a 3-way switch ( two switches that operate the same light) you'll need a 3-way dimmer.
Installing the dimmer is pretty straight forward. All dimmers come with installation instructions. Make sure you turn off the circuit breaker for the particular switch you are replacing.
May 29, 2013 | Electrical Supplies
Fan switch for fan light combo
Unfortunately, there is no standard color coding for ceiling fan wiring. You note in your video that the replacement switch has an L(ine) terminal and there should be 1, 2, and 3 terminals as well for controlling fan speed. Check the switch you are replacing for similar marking. If you are in luck, you can replace by L and numbers rather than colors. I checked my entire file of fan installation information and nothing more explicit is provided
May 24, 2013 | Photography
Should light be on after installation trvgfw
What type product (switch?) do you have?
What type of device did you replace? Single-pole, 3-way, 4-way switch? Timer? Fan-light switch? Multi-purpose switch?
What type voltage, and what wires are you working with?
What does instruction sheet say about load rating? For example, some devices do not work with CFL, while others have minimum watt rating. All devices have load ratings, including maximum wattage.
Copy following links for wiring switches.
http://waterheatertimer.org/How-to-wire-switches.html
http://waterheatertimer.org/How-to-wire-GFCI.html
Jul 27, 2012 | Electrical Supplies
I have a leviton 6214 programmable light switch - it lights up inside but it does not turn lights on outside.
Is this a new installation? New installation then wiring might be bad.
Or older installation that has stopped working? Timer might be bad.
The Leviton 6124 is rated for incandescent light bulbs up to 1200 watts, and does not appear to be rated for CFL, but could possibly work with CFL and LED.
Change bulb to incandescent.
Copy following link to identify timer, and correct wiring.
http://waterheatertimer.org/pdf/6124-manual.pdf
http://waterheatertimer.org/Programmable.html#wire
Nov 27, 2011 | Electrical Supplies
My 1995 Chevy Tahoe brake light switch wont stay in position and the brake lights stay on. I replaced the switch and had the same problem.
Brake Light Switch REMOVAL & INSTALLATION
  1. Disconnect the negative battery cable.
  2. Disable the SIR system (if equipped).
  3. Remove the clip (R/V Series) or unclip the switch (C/K Series) and unplug the electrical connector from the brake light switch.
  4. Remove the switch.
  5. Installation is the reverse of removal.
Oct 07, 2010 | 1995 Chevrolet Tahoe
Location of brake switch on 1988 cheve pickup 2500
Aug 31, 2010 | 1988 Chevrolet Silverado 2500
Gen Tran 12-Circuit Hard-Wired Transfer Switch Logo
338 people viewed this question
Top Gen Tran Electrical Supplies Experts
Steve
Gene Haynes
Are you a Gen Tran Electrical Supply Expert? Answer questions, earn points and help others
