Question about DG Gold / Brass 98 Biometric Keyless Electronic Digital Door Lock RH
KeyCard Types What types of keycards are out there?
    President:
  • 2,712 Answers
There are several popular type of keycards in use and include the mechanical holecard, bar code, magnetic stripe, smart card (embedded with a read/write electronic microchip), and RFID proximity cards. The keycard is used by presenting it to a card reader; swiping or inserting of mag stripe cards, or in the case of RFID cards, merely being brought into close proximity to a sensor.
Posted on Aug 27, 2008
I have recently had to have a new keycard done for my 55 plate Renault Megane as the central locking on my keycard stopped working and I couldn't access the vehicle, now I have two keycards that both
change batteries if this is not the fault. twist key slightly while trying to lock/unlock if key works transponder terminals have broken off the board
Oct 06, 2014 | 2005 Renault Megane 1.4
2005 renault scenic with keycard. keycard is worjking ok but immobiliser light on and car wont start
do you have the emergency four digits if so follow instructions in the website or you may have a loose solder in the transmitter which can happen when inserted into a back pocket.
http://www.bba-reman.com/content.aspx?content=Test_for_Renault_Key_Immobiliser_failures_emergency_recode
Aug 04, 2013 | Cars & Trucks
Hi, 2004 renault grand scenic. The keycard won't open, or start the car. The opening is not a major problem. Several months ago the key started being temperamental when trying to start the car. It...
if the keycard battery is failing you may(dependant on model and market) be able to get replacements.if, like some, for the european market are sealed, guess what........new keycard.......s..(2) renault dont tell you this when you but the cars........
Aug 13, 2010 | Renault 181 Cars & Trucks
Renault keycard repair
Hi there is one in london that you could send it to www.keycardrepairservice.co.uk they fixed mine while i waited.
Jan 22, 2010 | 2003 Renault 181
Hi, I just bought a blaupunkt Sydney RCM 126. After connecting the unit to my car, the display says ''wrong KC''. It has been working ok with the previous owner. Obviously after being disconnected for a...
Wrong KC means wrong keycard (smartcard)
This radio requires a Keycard (Smartcard) in order to operate.
See explanation here
http://www.bluespot.co.uk/keycard.asp
Nov 10, 2009 | Car Audio & Video
One of my Grand Scenic keycards has stopped working, I changed the battery but this has not helped. Do I have to go to Renault to get it recoded or can I do this myself using my one still working keycard?
sorry, a trip to your renault dealer is required here, it could of lost its code but more likely if it was working but then stopped is that the keycards buggered, half hour labour to programme a keycard
Sep 22, 2009 | 2004 Renault Sportwagon
Hi the warning light on my renanult magne comes up battery low have had it checked and its fine any ideas
if its a keycard its probably talking about the keycard battery, not the car battery, especially if its a handsfree model
Sep 18, 2009 | Renault Sport Cars & Trucks
Keycard fault
Hi ,
you will probably find the electric steering column lock solenoid is faulty.this needs to be replaced by the dealer.
Jul 16, 2009 | 2005 Renault R5
How to lock doors on renault laguna estate 53 plate
think only way is to use your main keycard.should have a cover that pulls off with a master key inside.this locks passenger door not drivers.think there is a cover or something on passenger door handle that this key fits in.this door can then be locked.you may have to get into car.lock drivers door from inside then use the master key to lock passenger door.you can only get back in car though passenger door.try new battery in keycard.coommon fault .switch on keycard breaks off inside keycard.can be soldered back on.think there are replacement switch kits on ebay with instructions how to fix otherwise new card from renault .has to be programed by them.
Jan 03, 2009 | 2000 Renault 181
DG Gold / Brass 98 Biometric Keyless Electronic Digital Door Lock RH Logo
205 people viewed this question
Top DG Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a DG Lock and Locksmithing Expert? Answer questions, earn points and help others
