This problem should be removed because:
Problem with Silver Jeans Codelocks 4010 Medium Duty Electronic Keyless Door Lock Backset: Commercial
Power supply Problem
What if the batteries go dead in an electronic lock?
Solutions (3)
Best Solution
99.9% of all keyless locks do have a key tumbler, so in the event of a loss of battery power, you can still open and lock the lockset with a standard key. Most all key-less locks will indicate that the battery is getting low and needs to be changed, if you don't change the batery is time, the only way to open/close the lock defaults back to the actual key.
There is usually an access panel on the inside side of the lock that is opened by either sliding up or down on the panel, or removing the screw holding the cover in place or prying off the cover plate so you can get to the battery.
Remember the reason for having installed a "key-less" lock is to allow authorized access (family, friends, employees, etc.) to something without having to have duplicate keys that can be lost or stolen and to prevent having to re-key locks everytime something changes.
how do you open the keyless lock so I can change the light or battery
The procedure for recharging the lock varies depending on the lock, but ALL of our electronic locks can be recharged from the outside, thus preventing a lockout.
Suggested Solution (1)
There is only a one year warranty on the electronics. Check the installation manual for a reset procedure and double-check the battery installation & electrical connections. Most manufacturers do not sell the electronic parts separately, ans it might actually cost more to repair an electronic lock than replace it.
I have lost my pin and backup keys + battery dead!
I have replaced the battery's in the safe and the code i set has been enabled, how do I reset a new code to open the safe? I have a...
Batteries dead how to open?
Batteries dead how do we open? Small Gordon Elec safe
The wrong number was input and now we can't...
The wrong number was input and now we can't get into the safe, we don't have a key for it, and the batteries seem to be flat. What...
Dead battery! CANNOT OPEN SAFE
Electronic push button safe GXB0709. Looks like the battery is dead and I cannot open. Can anyone help me? URGENT!
I have a dead battery. How can I open the safe?
I have a dead battery. How can I open the safe? It is a Sisco Digital #1073
Add Your Solution
All problems have been solved!
Fix-O-Meter
748
748 people viewed this problem
- 1 person found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Silver Jeans Electronic Keyless Lock Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
