Question about Mbt ZTS Inc. Mini-MBT, Mini Multi-Battery Tester for More than 15 Different Bat
Tester Questions Why Use a Voltage Tester?
    President:
  • 2,712 Answers
Because safety comes first! The most important thing to remember when working with electricity is to turn off the power. It is also important to learn how to make sure the power is off, and this can be done easily using a variety of different testers.
Posted on Aug 27, 2008
How can i use my tester in installing 2 switches and 2 light?
In installation of switches and lights you can use tester by continuity or by voltage reading.In continuity reading select the tester in to ohms or diode test to check the continuity and select to AC in to voltage reading to check the voltage out.
Jul 13, 2011 | Electric Stanley Tre500 Staple Gun /...
Nesecito comprar un tester ideal No.61-076 presio y como lo actengo pleas
Tu puede comprar lo a Amazon.com:
http://www.amazon.com/Ideal-61-076-Vol-Con-Tester/dp/B000BVKUSA
Questa cincuenta y cinco dollars.
Buenas suerte!
Jan 19, 2011 | IDEAL Vol-Con Xl Voltage/Continuity Tester
I cant find where the batteries are located on my IDEAL voltage tester #61-085
The #61-085 does not have batteries. (It does not test for continuity) The #61-086 does have batteries.
1. Replace batteries when touching the leads together no longer lights the continuity LED or produces an audible sound. 2. Remove test leads from tester. 3. Loosen the encapsulated screw from the bottom of the case. 4. Remove battery cap. 5. Replace the batteries with (4) new 1.5V button-type batteries (IDEAL# 61-201, IEC #LR44, or NEOA# 1166A). 6. Replace battery cap and re-tighten the encapsulated screw.
Here is the link to the complete manual. http://www.idealindustries.com/media/pdfs/products/instructions/nd-3401-2_61-085-086_instructions.pdf
If you have any other questions, just ask. Don't forget to rate this answer.
Jan 10, 2011 | IDEAL Industries #61-085 Vol-Test Voltage...
Voltage tester shows red light on all the 3 cables(including the ground) of a 14-2 home circuit,
HOLD ON!!! The Klein 69127 is an automotive tester to be used for voltages between 6V-24V, AC or DC. The higher voltage in your home could possibly damage the unit as well as yourself. It would be safer for you to use the non contact tester to verify voltage Klien NCVT-1
Aug 03, 2010 | Klein Tools 69127, Low-Voltage Tester,
Do have a number to call? we need it to ask questions.
The HST401 is an older 'legacy' product. If you go to http://www.sperryinstruments.com/ and select the support tab and then choose 'Legacy Product' you will see a list of products. Scroll down until you see your tester model number and click on 'Manual' and an operation manual will open in a separate window.
Mar 29, 2010 | Sperry Instruments HST401 Voltage...
2002 ford focus wiring diagram
For the 2002 Ford Focus:
For the 2.0L DOHC (Dual OverHead Cam) L4 VIN "3"
Cylinders:
(back of engine)
1-----2------3------4
(front of engine)
Ignition Connections:
(back)
1...3
4...2
(front)
For the 2.0L SOHC (Single OverHead Cam) L4 VIN "P"
Cylinders:
(back of engine)
1------2-----3-----4
(front on engine)
...(back)
.....4
2.......1
....3
...(front)
Let me know if this helped, or if you have additional information or questions.
Your question was Posted under the 29500 High Low Circuit Tester to 28 Voltage...Category and not under the Car & Trucks Category, delaying repsonse from the Cars & Trucks Expert.
Mar 05, 2010 | Lisle 29500 High Low Circuit Tester to 28...
Can I test a 12v battery
My friend ... here is the answer:
Description:
  • WIGGLY VOLTAGE TESTER
  • Solenoid type tester polarity
  • indicator
  • 120/240/600 VAC; 50/60 HZ
  • Lifetime warranty
Your 12 volt battery is DC voltage as well as far below the voltage testing threshold of 120 volts.
Thank you for your interest n FixYa.com
Jan 13, 2010 | Your One Source Square D Wiggly Voltage...
Horn not working looking for fuse
First check fuse then relay. If trouble finding obtain repair manual.
Basic diagnostic method is to start at the horn(s). There should be two wires. One is negative the other positive. If connections good. You will need a voltage tester and a jumper lead. A simple 12 volt bulb can be used as a tester. Pull one of the horn wires and attach tester then attach other tester lead to negative. Test horn. If no indication repeat with other horn wire (don't confuse horn connections). If voltage present Horn defective. Next check for voltage at relay. If voltage in to relay but not out replace relay. If no voltage in to relay replace fuse. If still not found then problem is with horn switch or wires between.
Jul 02, 2009 | 1996 Chevrolet Cavalier
Usage Repair
the current reading on a tester is independent of the battery in the tester. The battery is there to provide a tiny amount of current so you can read the resistance on a circuit in ohms.
What probably happened is that the useage selector switch was in the wrong position when a measurement was made for voltage of other and being in the current position created a short and the current measurement circuit was burned out.
for more details, please follow up with questions/comments
Sincerely Loringh
Aug 27, 2008 | IDEAL Vol-Con Xl Voltage/Continuity Tester
Mbt ZTS Inc. Mini-MBT, Mini Multi-Battery Tester for More than 15 Different Bat Logo
260 people viewed this question
Top Mbt Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Mbt Measuring Tool and Sensor Expert? Answer questions, earn points and help others
