Toshiba 27AF41 27" TV
Problem for Toshiba 27AF41 27" TV
Toshiba TV 27AF41, ch TAC0114 Won't Turn On
By M0nica L - usenet poster
    I have a Toshiba TV  27AF41, ch TAC0114 (mfg 12/01) (Photofact 4577)
in my shop.  I don't have SM.   When you try to turn on the TV, it goes on for
a fraction of a second then off.  Then the front panel LED starts blinking.
I was able to see (scope) a flyback pulse briefly (used a loop around FBT
core), but I didn't have a good view of the pulse condition.  I plugged the TV
into a 90 VAC source, but the results were the same.  Note: My customer said
this problem wasn't caused by a storm.  He said, "the TV was turned off, then
the next time someone tried to turn it on, it wouldn't go on."
   Did you have the same type of problem with this model TV?
                Thanks in advance,   Brad
  Before you type your password, credit card number, etc.,
 be sure there is no active key logger (spyware) in your PC.
Solution #1
posted on Aug 07, 2005
Not Rated)
Green1
Rank: Apprentice
Rating: 0%, 0 votes
Does the tv use an SMPS supply?  If yes, it does not matter what VAC you
plug the tv into.  If the SMPS has lost regulation due to a storm damaged
component in the feedback circuit, the tv still is probably going into
protect shutdown.
Just use standard power supply and deflection troubleshooting techniques for
a tv set.
Was this helpful?
Yes
No
Popular Solutions for Toshiba 27AF41 27" TV
Questions and Unsolved Problems for Toshiba 27AF41 27" TV
Do you recommend Toshiba 27AF41 27" TV?
Answer
Answer
Tv was givin to me with no power button and a remote, I told giver that I I have comcast remote.... (More)
Answer
My television keeps having a flashing red light when I try to tun it on. Is there anyway to turn it... (More)
Answer
The tv won't turn on when I press the poswer button. The red light blinks, but won't turn off when I... (More)
Answer
The tv won't turn on when I press the power button. The red light blinks, but won't turn off when I... (More)
Answer
cant gat my older rca direct tv remote to operate my toshiba model 27af41 tv
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repairmen
in , CA
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
