Question about Taylor Pneumatic: 31 Pcs. Sanding Prep. Kit
Die Grinder usage
Can I use the die grinder for other tasks?
I use router bits in die grinders and carve wood. Very handy, and you don't have to worry about kinking anything like you wood with a Foredom tool.
Posted on Apr 04, 2009
    President:
  • 2,712 Answers
These tools are handy for any finishing or grinder that needs to be done in a small spot.
Posted on Aug 27, 2008
How do you reset a makita gd0600 die grinder?
How much wear has it had. The carbon brushes could have worn out and need replacing.
Jan 28, 2012 | Makita Gd0600 Die Grinder
Plug in makita die grinder, turn on, runs for 2 to 3 seconds and pops breaker. It is a variable speed grinder
does it run freely?as in not seem to be lugging from bad bearings in the motor shaft,then check the speed control board for a shorted triac/scr transistor
Mar 25, 2011 | Makita 14" Die Grinder
The Dewalt DW888 Die Grinder does not come with a guard. Is is permissable to operate it without one?
on a die grinder like this one yes you can, make sure that you do wear safety glasses though
Jan 18, 2011 | Dewalt DW888 Die Grinder
The worm gear broke
Time to buy a new air grinder!!
Aug 27, 2009 | Viking Die Grinders: 1/4" Mini Die...
Cannot figure how to get the point onto the die grinder.
Here is a link with illustrations on installing grinder points. Scroll about 1/4 of the way down and you'll see two links for "Operators Manual" Click the one that matches your model.
http://www.milwaukeetool.com/PartsAndService/DownloadManuals/All.aspx?ProductId=5192
Hope this helps you out.
May 31, 2009 | Milwaukee Tool Milwaukee 5192 4.5 Amp Die...
I can't find a 1'4" collet for a Milwaukee DG14-50-Q die grinder. The removable collet chuck came with 6mm & 8mm collets. The collet Id No is 48-66 0965 but is no longer made. Does anyone know of an...
The 48-66-0970 has ribs on the outside and fits the old 5195 die grinder. If this is accurate let me know and I will try further to locate it for you. Where are you located as this might help
May 15, 2009 | Milwaukee Tool 48 66 0975 Collet 1/4" Die...
Safety Machanism Question
Most die grinder throttles feature a spring-loaded "kickstand" mechanism between the throttle lever and the body of the grinder, which prevents the throttle from opening (being pressed down towards the body of the grinder) without operator intervention. This prevents the die grinder from accidentally activating.
Aug 27, 2008 | Taylor Pneumatic: 1/4" Extended Die...
Regular grinder and die grinder difference
Die grinders are specialty handheld power tools designed to shape and polish the insides of cylindrical objects. They have long thin spindles and shafts that allow them to reach deep inside the work piece. Die grinders are usually used in machine and metal working operations to port and polish the insides of piping and plumbing systems and joints
Aug 27, 2008 | Taylor Pneumatic: Three In One Kit
Motor Speed Question
The RPM rating of the die grinder is the deciding factor in the tool’s usage. A die grinder with a lower RPM is best used for fine grinding and finishing work. Speeds lower than 10,000 RPM are best for this function. A die grinder with an RPM between 10,000 and 20,000 is great for creating rough finishes and minor buffing jobs. If the die grinder will be used to remove metal burrs or to cut metal, it must have an RPM rating of over 20,000 and a no-load speed of at least 30,000 depending on the RPM rating.
Aug 27, 2008 | Viking Die Grinders: 1/4" Heavy Duty Die...
Taylor Pneumatic: 31 Pcs. Sanding Prep. Kit Logo
400 people viewed this question
Top Taylor Grinders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
Are you a Taylor Grinder Expert? Answer questions, earn points and help others
