Question about Hitachi G10SR3 4" Angle Grinder 6 Amp
Grinders power question
What amp do I need?
    President:
  • 2,712 Answers
Consider a high amp motor if you want enough power (torque) for heavy use without stalling or slowing
Posted on Aug 27, 2008
What is wrong when bench grinder stalls out when sharping mower blades. Not too much pressure used. Grinder not equipped with a belt
since this is a vague comment, I have to say that some small grinders just do not do well with blade sharpening. I have one that does the same thing when sharpening a blade. It is just too small, horsepower wise, to handle the job.
Sep 29, 2017 | Bench Grinders
Fixing bad motors in dewalt angle grinders power tools
it would be much better if you bought a new one because it would be cheaper
Jul 04, 2014 | Dewalt DW824 5" Electric Angle Grinder
WHAT ARE THE MOST COMMON PROBLEMS WITH RIDGID GRINDERS?
Most common problems with small grinders in general (all brands) fall into two main catagories. Low power situation and lack of lubrication /debris or maintainance. Electric power tools are used with an extension cord. If too long of cord or improper gauge wire is used, the tool will heat up and burn the brushes, switch or copper winding (lower life of tool). If you feel the tool getting hot either let it cool or check power supply. Tools such as grinders generate lots of dust/debris that enters the tool. Abrasive dust entering tool prevents proper cooling and eats varnish off winding / wears carbon brushs and commutator. Grinders/polishers get packed inside with fluff coming off bonnets preventing cooling. All this overheating prevents grease from properly lubricating gears. Check gearcase for good lubrication and keep inside of the grinder clean. Good luck
Jul 13, 2011 | Ridgid 23983 Grinder 412" Angle
Helllllpppp
Be careful when using the grinder. This tool is made up of a variable speed motor and a switch.
Oct 20, 2010 | Grinders
Do you have a basic training course and knowledge assessment for 115mm and 230mm angle grinders
Hi, a good place is youtube, there are videos on most tools and some very good tips.
Oct 01, 2010 | Clarke Power Products 7 in 9 in Angle...
What are the power source requirements for a DeWalt #756 Grinder?
My experience of bench grinders suggest 15 amp will be enough, certainly at 240 volts . If you are 110 then I think it will still be enough but you dont make clear what the wattage of your machine is.
Jun 06, 2010 | Dewalt 6" 5/8 Hp Heavy Duty Bench Grinder
Unit has rt & lft threaded tapered (point) shafts & seems to have ability to ''chuck'' bits.---this is my first encounter w/ this system and to my dismay and chagrin i can't use it --have all specs...
Some grinders have tapered, threaded shafts that allow the use of soft buffing or metal polishing wheels, could that also apply to yours?
May 17, 2009 | Baldor Grinders
Grinder Types
Bench grinders are perfect for sharpening cutters, bits, blades and hand tools. Any piece that needs smoothing, shaping, or polishing can be done at the bench grinder. Straight grinders or angle grinders are portable, handheld tools with wheels that range from 4 to 9 inches. They are the best grinders for working on pieces that may be too large to fit at a bench.
Aug 27, 2008 | kawasaki 7" or 9" Angle Grinder
Hitachi G10SR3 4" Angle Grinder 6 Amp Logo
348 people viewed this question
Top Hitachi Saws Experts
John Trevino
JOHN LAPIER
Are you a Hitachi Saw Expert? Answer questions, earn points and help others
