Question about IDEAL Vol-Con Xl Voltage/Continuity Tester
Usage Repair My tester read the current wrong. Why? How can I fix that?
    Novelist:
  • 185 Answers
The current reading on a tester is independent of the battery in the tester. The battery is there to provide a tiny amount of current so you can read the resistance on a circuit in ohms.
What probably happened is that the useage selector switch was in the wrong position when a measurement was made for voltage of other and being in the current position created a short and the current measurement circuit was burned out.
for more details, please follow up with questions/comments
Sincerely Loringh
Posted on Oct 14, 2008
    Master:
  • 683 Answers
    President:
  • 2,712 Answers
If batteries fail, it may appear that current is dead even if it is not. Note: always test the voltage-tester before using it.
Posted on Aug 27, 2008
My easy touch meter is reading way to high how do I fix it?
How do you know it is reading watch too high is my first question..MAKE SURE IT IS NOT YOUR GLUCOSE THAT IS READING HIGH..the tester should have a small bottle of testing accuracy with it..there are number scales on the side of the strip container and on the test bottle use a strip and test it..if it reads on or between the numbers the strips and tester is ok..if it does not, try another from another strip from different container..if it still reads wrong..your tester is faulty..good luck..
Apr 23, 2014 | Easy Touch No Coding Glucose Monitoring...
How do u know if your ryobi charger is burnt out
Checked the output supply of the charger using tester, in using tester you must need to know the output supply if it is in dc(direct current) or AC(alternating current), then select it from the selector of the tester if there is a reading then that good,make sure to know the supply of your ryobi charger by checking it from the specs of charger itself.. If the reading is accurate then the charger is good if not then the charger is defective then replace a new one. Hope this simple solution could help you to solve your problem. Mam/ Sir don't forget me to rate me up I really appreciate what Ratings you have given to me. Thanks a lot and God Bless.
Jun 21, 2011 | Drills
Air conditioner isn't cooling the room
hi there,
insufficient cooling have several reason,most common factor is low freon charging due to service factor,defective thermostat control,dirty evaporator and condenser fin,try to check the current rating using ammeter clamp tester if the rated current read in tester below the rated current on tag(compressor)
you need to charge freon,if the fin and evaporator is dirty need to ve clean,if the thermostat is not functioning replace thermostat.
also consider the main defective if the aircon is running chck the compressor if it is running by touching the tip of screw driver to the top body of compressor you can feeel vibration,if compressor is not running yo don't have cooling effect only blowing of air.on repairing this this should be done by a certified aircon technician,have a nice day fix my rate,thank you very much.
May 14, 2010 | Fujitsu 24C1 Air Conditioner
Nicad battery for makita want charge
For NiCd and NiMH batteries - check the battery voltage (for a good battery it is ~ 19, V); each battery contains 15 units 1.2 V each; you can test each unit after disassembling the battery case (my have 4 screws each, and the case has bottom and top parts). First charge the batteries; second, disassemble cases and check each unit voltage (shouldn't be less than 1.2 V); then take any battery tester (for AA, AAA and other batteries and accus for home usage), attach 2 long (~10 inches) wires to tester's testing contacts, and test each 1.2V unit for current - if it is in "yellow" or "red" zone - the unit is dead and needs replacement
Feb 16, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
My cirgerette lighter in my 1988 cutlass ciera oldmobile doesnt work i was looking to fix it myself but i dont know what is wrong with it...what are some things i can do to try and fix it??
The lighter has a resistance coil similar to electric room heaters. There is a coil of wire which gets red hot when current is made to flow through it. First ensure that current is available in the lighter receptacle by a line tester or a simple bulb tester. If the bulb lights up, means either the push button for the assembly are not getting the leads contact point which could be deposition of salts and cleaning it should suffice. The other thing that that is critical is the coil itself. If the coil is not continuous, i.e. has a break, then replace the coil ..........................sodeep
Aug 03, 2009 | 1988 Oldsmobile Cutlass Ciera
Daewoo racer 1995, petrol gauge
the easiest fix is to change the sending unit
Mar 09, 2009 | RTO Fuel Pump Carburetor Transmission...
Usage How To
To measure the voltage at an electrical outlet requires the use of a multimeter. Always test your test equipment for proper operation before use. Set the multimeter to AC voltage. The markings may appear as VAC, AC V, or a V beneath a wavy line. Choose the AC voltage closest to the voltage you will measure. Standard current in home and businesses in the USA is in the range of 110 to 120 volts. Some circuits used for equipment such as dryers, air conditioners, electric stoves, ovens and other large equipment may use voltage in the range of 220 to 240 volts. These heavy-duty circuits can be identified by their non-standard outlet plugs. While grasping the insulated portion of the probes (never touch the metal conductor during testing) place one probe into each of the two terminals. The multimeter will display the voltage. Carefully remove the probes, being careful not to touch the metal part of the probes to anything or each other. The voltage should typically test in the range of 108 to 121 volts for most circuits. If voltage is higher or lower, professional electrical service may be required.
Aug 27, 2008 | IDEAL Powr-Glo Audible Voltage Tester
PTAC UNIT QUIT WORKING
If you have a clamp tester, operate the unit with the clamp tester and check the current reading. If the current reading is normal but the reset button is tipped then there is something wrong withe power plug reset button. But if the current reading is higher than the name plate rating then there is something wrong with the unit.
Mar 09, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Saftey cord
For 2-3 three minutes of running does it run normally? No abnormal noise the air out of unit is cool, if you have clamp tester you can check if the current reading of unit is normal, if everything is normal then there is something wrong with your circuit breaker, it needs replacement or your circuit breaker is under rated.
May 23, 2007 | Samsung AW0693L Air Conditioner
IDEAL Vol-Con Xl Voltage/Continuity Tester Logo
408 people viewed this question
Top IDEAL Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an IDEAL Measuring Tool and Sensor Expert? Answer questions, earn points and help others
