Question about Whistler Power Inverter
Tech Question What is the difference between Automotive and Deep Cycle batteries?
  • Bonnie Jun 27, 2012
    Automotive batteries are designed for short, high amp loads (such as when you start your vehicle, it requires a high amount of amps). Once the vehicle is running, the alternator will recharge it.
    A deep cycle battery is designed to be discharged down to as much as 80%
    President:
  • 2,712 Answers
Automotive batteries are usually adequate for small inverters, (< 500 Watts). When used in a car, we suggest you run the vehicle of your engine occasionally while operating your inverter. If you use the inverter while the engine is off, you should start the engine regularly and let it run to charge the battery. Deep Cycle (marine) batteries are best for larger inverters as they are designed for several hundred charge/discharge cycles. (Automotive batteries wear out much more quickly after heavy discharge).
Posted on Aug 27, 2008
What color is the liquid in a deep cycle marine battery supposed to be
To the best of my knowledge and experience the fluid should be clear, like water. The liquid is dilute sulphuric acid just as any lead-acid battery contains.
The deep cycle battery differs not in the electrolyte but in the construction, using different separators, thicker plates and deeper sediment trays.
If the fluid is discoloured (varying from light grey to black) it is likely to indicate a charge rate that is too high, over charging or physical vibration has disturbed sediment from the trays or from the plates or perhaps the battery has been tilted. Sometimes lightly discoloured fluid is of little detriment and will settle in time if left undisturbed. Sometimes it is a sign of a failing battery. Certainly it would be wise to check the charging system for the correct operation.
Apr 12, 2016 | Boating
Can i replace the AGM batteries in my Bombardier class e, with deep cycle batteries?
A deep cycle battery for personal mobility equipment would be how to look into this. The AGM is a type of deep cycle battery. A gel battery is what was more common before AGM came along. Gel batteries tend to hold up a touch more than AGM.
Oct 12, 2014 | Health & Beauty
How do I know what battery to buy and how do I hook it up to my gulfstream coach
Above all, buy the best battery you can afford. You can't have too much battery! A standard sealed lead-acid battery is okay for the engine, but I would suggest an AGM battery for the coach. AGMs are longer lasting, charge quicker and can stand abuse. Make sure it is a deep cycle battery for a RV, NOT A MARINE TYPE DEEP CYCLE. Marine type deep-cycle batteries are designed to start engines along with their deep-cycle capabilities. They WILL NOT last in an RV.
Make sure the replacement is the same design i.e. + post on left (or whichever). Compare to original battery. Switch breaker off for coach. Replace battery. Hook up the RED cable to + FIRST, then black cable to ground. Switch power back on. You can charge it if you want to, but I never noticed any need.
Sep 29, 2014 | RVs
Is a deep cycle battery the same as an RV/marine battery?
Deep cycle is typically for long duration loads like lights or a troling motor but not very high starting currents. Unless marked, an RV battery is a combination starting running battery. It may have a higher starting current than the deep cycle, but not as long of a run time.
Sep 21, 2014 | Boating
Rascal scooter
Battery Voltage is usually always 12, Amperage can vary slightly with no major problems. 35 Amp is standard and will not present any problems.
Jan 28, 2014 | Health & Beauty
I HAVE A 2008 COACHMAN SPIRIT OF AMERICA 29RKS. IM HAVING ELECTRICAL PROBLEMS. THE MICROWAVE WORKS AND SOME POWER OUTLETS IN THE KITCHEN AND BATHROOM WORK. THE LIGHTS, AND SUPERSLIDE DO NOT WORK.
Lights and slide are 12 volts ... check your battery ... and your battery charger ... DO NOT TRY TO OPERATE your trailer on a dead or battery-less unit. You need a good battery for things to work properly ... deep cycle not automotive.
Good luck with our repair.
Sep 24, 2013 | Coachmen 2008 Spirit Of America SuperSlide...
Can I over charge my mobility scooter batteries with a pihsiang charger the green light wont go solid
Take the batteries to a battery shop or a Battery plus store have them load test the batteries. Deep cycle batteries are different from normal batteries. Normal batteries are design for max output for short periods of time, Deep cycle batteries are designed for a modest output for long periods of time. My batteries are rated at 35 amp/hr.. Basically a load tester places a load in amps [cranking amps] on the battery. How many cranking amps depends on if there is a voltage drop when you apply the load. I can apply 480 cranking amps before my voltage drops. What i do is load test a new battery of the same type to find out the cranking amps. You will not find a cranking amp rating for aq deep cycle battery but retail places have load testers that read in cranking amps. Use only deep cycle batteries in scooters, garden tracker batteries will not last. If the batteries are ok test the charger. A CHARGER KNOWS THE CHARGE OF THE BATTERY BY BATTERY RESISTANCE. As a battery charges its resistance get bigger. Once the battery reaches a preset resistance the light goes solid. You can have the charger checked by a battery shop. To properly charge a battery a charger will put out 27volts @ 4amps, they can easily test for voltage. Now if the charger is built in there is going to be an external fuse find it, check it. hope this helps
Jun 07, 2012 | Health & Beauty
General inverter question. Running off of a car battery do I keep the car running or just juice the battery every now and then to keep the battery from dying:
Automotive batteries are designed for a quick draw of amperage (when starting) and then get constantly recharged using the alternator when driving. If you are using an auto battery for inversion, it will drain much quicker. Depending on how/where you are using it, you could charge the battery when a meter shows a voltage drop. Better recommendation would be to use a marine battery, which is a deep cycle battery. Deep cycle batteries last much longer between charges, as they are designed to have a constant draw (trolling motors, etc.).
Aug 27, 2011 | Garden
Just purchased 1985 pace motor home it has one deep cycle battery and one regular side post battery. I charged the deep cycle and the motor barely turns over, wondering if I am supposed to have two deep...
Hi, the deep cycle battery is for the home part and should charge through the external connector port. The regular battery is for the engine. Is the regular battery charged up too?
Jan 01, 2011 | Chrysler E-Class Cars & Trucks
Whistler Power Inverter Logo
523 people viewed this question
Top Whistler Electronics - Others Experts
Are you a Whistler Electronics - Other Expert? Answer questions, earn points and help others
