Question about Xantrex Technology Xantrex Freedom Xmic 1000 - Electrical - Inverters
Power Supply How To
How do I charge the battery for my inverter?
  • mashedtea Feb 28, 2009
    how much power does a 150w inverter unit actualy use its self whilst working ?
    Problem Solver:
  • 5 Answers
Because inverters operate from a DC (Direct Current) power source, usually a battery bank (one or more batteries), the battery source will have to be recharged at some point. (Remember that a battery discharged more than 50% is probably close to being dead.) Most cars and trucks recharge their batteries from an onboard alternator. Depending on the inverter load and runtime required, most power use applications will be covered by the charged battery, augmented by the operating alternator supplying a continuous charge to the battery. If the load is large (air conditioner, large draw power tools, large microwave, food freezer, ice cream machine, etc.), the user should verify that the installed vehicle alternator is of large enough capacity to operate the vehicle's power requirement as well as to fulfill the capacity of the inverter load. If it’s not, a motor throttle installation may be required to carry a small load, a larger alternator may be required, or a larger alternator, battery isolator and additional onboard battery bank may be required in order to meet the power requirement of the large load. Remember: it takes 12 DC Amps (at 12 VDC) to run 1 AC Amp (at 120 VAC single-phase) of power because there are voltage and efficiency factors to take into consideration.
Posted on Aug 27, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,001 Answers
Chornic Big Capacity Solar Charger, Portable 15000mAh Solar Power Bank with LED Flashlight Lighting Functionfor iPhone, iPad, iPod, Cell Phone, Tablet,Camera Chornic Big Capacity Solar Charger Portable 15000mAh Solar Power Bank with...
Posted on Dec 01, 2016
  • 3 Answers
I use solar panels and a solar controller
Posted on Aug 05, 2009
  • 3 Answers
How much power does a 150w inverter unit actualy use its self whilst working ?
Most will be about 10% in this size.
And then there is stand-by power usage.
Posted on May 14, 2009
Car adapter do have it?
please let me know
Posted on Oct 07, 2008
Batteries go dead when you drive with the inverter on?
It appears that you are drawing more power when driving and using the inverter than the charging system can supply.
Sep 19, 2014 | Electronics - Others
Tip
UNINTERRUPTIBLE POWER SUPPLY
UPS – UNINTERRUPTIBLE POWER SUPPLY
Uninterruptible power supplies provide protection against mains power faults to computer equipment.
These faults include voltage spikes/interference, over voltage and under voltage, mains supply interruptions and surge protection etc.
These faults can cause computer and electronic equipment that are connected to an unprotected mains supply to malfunction and/or sometimes fail.
A common problem, when burning Cds, DVDs etc. any slight power interruptions to the burning process will halt the recording process and rendered the disc useless.
There two type of Uninterruptible Power Supplies
The lower powered and cheaper type UPS are switch-over types, when the mains supply fails, the UPS switches over to the batteries and inverter in milli-seconds which then supplies mains power to the computer and peripherals. A faulty inverter circuit and or flat batteries won’t deliver standby power when the mains supply fails.
NOTE : The mains waveform from these UPS is a pseudo sine wave (i.e. not a true sine wave).
The true UPS types are usually the higher KVA units (over 1500 VA) that supply continuous mains power. The mains power is connected to a charger which charges the batteries and then the inverter draws power from these batteries and converts it to true sine wave mains power to the computer equipment, therefore there is no switch over time lag when the mains supply fails.
on Dec 06, 2009 | Computers & Internet
Tip
UPS - Battery Fault
UNINTERRUPTABLE POWER SUPPLY
Batteries in the UPS typically last 3 to 5 years and it depends upon several factors. Including the number of times the unit must go on battery power and environmental conditions. There are usually several batteries in the UPS and while the battery voltage may show 13 volts, this may only be a float charge/voltage and a true indication of the battery voltage and condition requires the batteries to be tested under a load. If one battery is faulty in a set of batteries it will causes the whole battery system to fail and indicate a battery fault. A faulty charging circuit will not charge the batteries and will also cause a fault condition.
Lower powered and cheaper type UPS are switch over types, when the mains supply fails, the UPS switches over to the battery and inverter in milli-seconds which then supplies mains power to the computer and peripherals. A faulty inverter circuit and or flat batteries won’t deliver standby power when the mains supply fails.
NOTE the power waveform from these UPS is a pseudo sine wave (i.e. not a true sine wave).
The true UPS types are usually the higher KVA units (over 1500 VA) that supply continuous mains power. The mains power is connected to a charger which charges the batteries and the inverter draws power from these batteries and converts it to true sine wave mains power to the computer equipment, therefore there is no switch over time lag when the mains supply fails.
on Dec 02, 2009 | Computers & Internet
Inverter battery charging
Probably batteries have developed high internal resistance.
Replace with new batteries.
Dec 24, 2013 | Computers & Internet
Fault Light/ inverter failure
the current from the 12volt supply is not sufficient try a fully charged car battery instead, your inverter needs 30 amps and above of current from 12 volt power supply
Jul 20, 2013 | Televison & Video
In my home using 100AH battery for inverter , want to know wht happens if the baterry is not connected to inverter ? Is battery life decreases..? or WHAT ELSE WILL HAPPENS TO BATTERY ..? plz give an...
It depends upon the type of UPS.
A true UPS requires a battery to be connected to the inverter at all times. Mains power is used to charge the battery constantly and battery is required to continually supply power to the inverter which then converts the voltage to mains supply voltage.
A lower powered and cheaper type UPS areswitch-over types, when the mains supply fails, the UPS switches over to thebatteries and the inverter in milli-seconds which then supplies mains power to thecomputer and peripherals.
This type UPS may operate without a battery, but it depends upon the design of the UPS and the battery error detection system In most cases I doubt it can operate without a battery. You can try the UPS without a battery, make sure the battery terminals do not short against each other.
Dec 21, 2011 | Televison & Video
Wont charge
Inverters convert dc voltage to AC voltage - they don't charge.
If you have a remote/emergency power supply, it has a separate battery charger circuit - apart from the inverter... and it probably has an internal cartrige fuse. If blown, replace and retry.
Dec 24, 2009 | Electronics - Others
Why does the power inverter keep beeping when i plug up my laptop
If your not getting enough voltage to the inverter it will beep to let you know you don't have enough power. Most common cause is a lose connection thru your cigarette lighter. Also if you turn your key off it might be shutting down power to your plug.
Make sure you have a good connection with your battery or plug adapter. You also need a good battery so you don't go into a low voltage condition which will make your inverter beep.
Oct 29, 2009 | Black & Decker Power Inverter PI400AB
Dead appearing ups/inverter
keep on your main switch. off all the lights fan and other electrical items, let that inverter get charge first
Jun 18, 2009 | APC Back-UPS CS 500VA UPS System
Inverter Question
Where can I download Instruction manual for Fuji FVR-E7S?
Aug 27, 2008 | Xantrex Technology Ags Harness Cable...
Xantrex Technology Xantrex Freedom Xmic 1000 - Electrical - Inverters Logo
799 people viewed this question
Top Xantrex Technology Electronics - Others Experts
Craig Butler
Craig Butler
Jimmer_9
Level 1 Expert
richie46
Are you a Xantrex Technology Electronics - Other Expert? Answer questions, earn points and help others
