Question about SHOWHOUSE Rough Wall Mount Faucet Valve
Installation Cost I want to install sink shutoff valves on my sink. How much does that thing cost?
    Problem Solver:
  • 4 Answers
Standard compression valves cost about $7 each.
Posted on Aug 27, 2008
My panasonic projection tv 60'' has a power but auto shutoff after 5 seconds then blink red light 3 times
Dead power supply. I recommend a new tv rather than throw good money after this old thing. A new power supply will cost $200 or so plus installation. Sometimes dead power supplies take other components with them as the voltage surges.
Aug 18, 2014 | Panasonic Televison & Video
No hot water pressure in kitchen, low cold pressure
sounds like a bad faucet//only if you had good pressure before it was installed..to cheaply test..take the hot water off from the shutoff valve and spray it into a milk jug to see if theres good flow..then replace the faucet assmbly..dont forget to turn off the shutoff valve first..or you will get a watery surprise!
Jan 08, 2014 | Home
LG LRSC21934 ice maker/water dispenser doesn't work
If your house water supply to the refrigerator is poor it is most likely the cause of the water dispenser and ice maker not working. If you hear the water valve humming when the water dispenser is depressed and no water is dispensed it is most likely poor or restricted water flow to the refrigerator.
If you live in an older home the water supply shutoff valve to the refrigerator is usually in the basement or under the kitchen sink. Many shutoff valves are called a saddle valve and the valve is secured onto a cold water pipe and as the valve is turned clockwise a pin punctures the water pipe allowing water to flow. Saddle valves often become clogged with minerals and can completely block water flow to the refrigerator,. If the valve is corroded on the outside it should be replaced. Ice maker installation kits are available at most hardware stores. Copper water line kits are preferred. Cost is under $25.00. If the Saddle valve is in good shape they can be taken apart and cleaned. Be sure to shut off the main house water and drain pipes before attempting to clean.
Newer homes may have a water box in the wall behind the refrigerator. Sometimes these can become clogged with mineral deposits as well.
Hope this helps.
Mike
Oct 30, 2017 | LG LRSC21934 Side by Side Refrigerator
My shower water temperature is way too hot. How do I reduce it?
go to the hot water heater and turn it down 1\2 way a start from there
Jul 19, 2011 | Heating & Cooling
Trying to take out part number 1224 in a series 9400 m-pact valve 2 handle faucet. I have water dripping out of the stem of the faucet and I think that my o-ring may have been damaged during the...
If it's new and the valve was soldered in, the installer may have left the stems in the valve while installing. Damaged O rings and plastic parts do occur. Contact Moen and see if they will ship out the part. Give them the info they need and it will probably not cost you anything under warranty. http://www.moen.com/
Apr 23, 2011 | Moen T6530/9400 Two Handle Wall-Mount...
Whirlpool gold dishwasher is leaving a white milky film on the dishes. My old maytag cleaned fine, so water temp and pressure is not an issue.
Water is the issue.
Replace the water supply valve under the sink and water supply line to dishwasher.
Over time as you can see minerals deposit in the valve and restrict the water flow to the dishwasher.
This is especially inportant on todays water saving units.
Many people replace an old dishwasher and hate the new unit due to a white film left on dishes.
Although you may have paid for a professional installation a new shut off valve is almost never replaced even though the waterline may have been at an additional cost to you..
Jan 09, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Unit doesn't clean well. Is it normal to find water underneath the round unit at the bottom under the wire mesh filter?
Yes some water is normal.
Over time minerals deposit in the valve and restrict the water flow to the dishwasher.
Jan 09, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwasher will not fill to capacity for a wash
Replace the water supply valve under the sink and water supply line to dishwasher. (See attached picture)
Jan 09, 2010 | Dishwashers
Asko d1776 dishwasher not filling
Make sure the water to it is turned on. Next, disconnect the water hoses from underneath and clean the filters or push into tha fittings to pop the seals loose.
Sep 16, 2009 | Asko D1776 Built-in Dishwasher
Hot water not working - no shutoff valve in line, and hotwater works at sink.
From what you've described, it's got to be a block between the main supply line and the shower head.
If you have never used this shower after its installation, it's possible that the temperature limit stop is set too low.
Otherwise, either the hot water valve or the balance spool need maintenance. The instructions on pages 4-6 of the link below should be helpful for correcting the problem.
http://www.moen.com/shared/pdf/instruction_sheets/INS162E.pdf
Sep 15, 2009 | Moen 3175 Legend One Handle Shower Faucet...
SHOWHOUSE Rough Wall Mount Faucet Valve Logo
Top ShowHouse Plumbing Experts
Donni Steen
Tom Chichester
Are you a ShowHouse Plumbing Expert? Answer questions, earn points and help others
