Question about Samsung DouCam VP-D5000i Mini DV Digital Camcorder
Running the camcorder continuously
I Am Using My Camcorder As A Surveillance Camera. It Runs 24/7. Is This Ok?
    Master:
  • 473 Answers
Those camcorders are not intended to be surveillance cameras. There are however, steps you can take to ensure maximum longevity. * Keep the unit dry (avoid rain, inclement weather, etc.) * Ventilate the unit, i.e. make sure there is plenty of free air around the unit for cooling. * Shield from direct sunlight if possible * Avoid extremes of temperature and humidity.
Posted on Sep 06, 2005
DV-136ZB can't take pictures to my computer.
Are you trying to transfer videos from your camcorder to the computer, or use the camcorder to create pictures directly on the computer ?
Jul 26, 2017 | Global New Beginnings DV-136ZB Camcorder
Auto power off
Link to user manual
No you can't turn off this feature
Nathan Petersen June 17th, 2005, 04:03 PM Is there away to turn the auto power off off. I dont think there is, just thought I'd ask, thanks. Don Palomaki June 17th, 2005, 08:47 PM Not on the original XL1. It will drop into STANDBY from PAUSE if there is a tape in the transport after around 5 minutes. If there is NOT a tape in the camcorder it will not not drop into STANDBY but will remain operating as a camera. Xander Christ June 17th, 2005, 09:25 PM Canon suggests that the only way to keep the XI from shutting off is to use the AC adapter as the power source, not the battery. I haven't tried it, so I don't know if it's true. Don Palomaki June 18th, 2005, 07:33 AM True - in that when using the battery, the camcorder will shut down when the battery runs out of available charge. However, using the A/C adapter does not prevent the XL1 from going into standby if a tape is in the camcorder. Nathan Petersen June 18th, 2005, 04:52 PM Canon suggests that the only way to keep the XI from shutting off is to use the AC adapter as the power source, not the battery. I haven't tried it, so I don't know if it's true.
No it still does it with the AC adapter, Im not even using the battery. It makes no sense to have the auto power off when shooting indoors while using the AC adapter, its just stupid. Don Palomaki June 19th, 2005, 05:59 AM Again, the key point is having a tape in the XL1. After about 5 minuts it goes into Standby mode (not the same as turning the power off with the dial). This is a carryover from pure consumer camcorders - to save battery and reduce damage to tape and head wear from a camcorder left in pause mode for a long time.
Pro users complained, so the XL1s had an option to disable this feature so that only the tape transport (VCR portion) is turned off after 5 minutes, the camera head continues to run. link to above thread
Dec 02, 2007 | Canon Optura Xi Mini DV Digital Camcorder
Dew light
Dew is likely to form in the following circumstances: ?When moving the camcorder from a cold place to a warm place. ?When placing the camcorder in a cold room which is then heated rapidly. ?When moving the camcorder outdoors from an air conditioned room or car. ?When placing the camcorder in the direct path of air blowing from an air conditioner. ?When placing the camcorder in a humid room. Dew will gradually form on the head drum of your camcorder and make the video tape stick to the head. This causes damage both to the head and the tape. When dew forms, recording and playback may not function properly. When ?DEW? flashes, remove the cassette,leave the cassette compartment open,and wait for a few hours to allow the camcorder to acclimatise to the surrounding temperature. To use the camcorder again, turn on the power after waiting for a few hours. Be sure that ?DEW? has disappeared. Do not insert a cassette while ?DEW? is flashing; this may result in damage to the tape.
Aug 03, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
SIR/MAM. WHEN EVER I USE MY CAMCORDER GR-DVX9
There is often a small battery inside the unit or accessed from outside that holds the memory that the device was last set. Yours is defaulting to maximum zoom. And in fact it does.
Built-in Clock's Rechargeable Lithium Battery
To store the date/time in memory, the clock's rechargeable
lithium battery is integrated in the camcorder. While the
camcorder is connected to an AC outlet using the AC
Power Adapter/Charger, or while the battery pack attached
to the camcorder continues to supply power, the clock's
rechargeable lithium battery is always charged. However,
if the camcorder is not used for approx. 3 months, the
clock's lithium battery will become discharged and the
date/time stored in memory will be lost. When this occurs,
first connect the camcorder to an AC outlet using the AC
Power Adapter/Charger for over 24 hours to charge the
clock's rechargeable lithium battery. Then perform the
date/time setting before using the camcorder.
Note that the camcorder can be used without setting the
date/time.
Your manual in English. You can use a smartphone with Google translate and the camera feature to read what is shown on the camera in Japanese and change the operating language to English.
http://www.videocamera-manual.com/manuals/jvc/JVC_GR-DVX9_MiniDV.pdf
Nov 03, 2017 | JVC GR-DVX9 Mini DV Digital Camcorder
PV-DV103 will not connect to pc via Firewire - Windows Movie makr
ur COMP. graphic is low. ur camera need capturing card on PC u can edit ur pic in movie maker
Mar 17, 2009 | Panasonic PV-DV103 Mini DV Digital...
Have downloaded video from my camcorder onto my laptop but when I play them the sound runs ok while the picture runs slow ( out of sync)
Ok...your title says camera but your post says camcorder. If it is a digital camera then nothing is wrong with you camera or laptop. Usually the video taken on a digital camera is of poor quality and vice versus with a camcorder the pictures are of poor quality. They make it seem like you can do both with exception to newer camcorder which has a 6 to 8 mp camera built in.
May 27, 2008 | Samsung Cameras
RCA cc540 VHS camcorder
Hi, Try running the camera using the AC power (charger) instead of the battery. If the viewfinder works then, it is possible that the replacement battery somehow is not suited for your particular brand/model and is not capable of supplying all the need voltages/power. Try continuously charging the battery for 16 hrs at least to see if this will correct the problem. If even in using the AC power (adapter) instead of the battery, the view finder is still off, then you have a camera fault. Normal problem for this is the thin flexible flat cable that attaches the screen to the electronics inside the camera. In some case, it is the backlight of the display that is at fault. Either which would require the services of a qualified professional. Hope this be of some help/idea to you. Good luck and kind regards.
Aug 24, 2007 | RCA CC4352 Camcorder
Samsung DouCam VP-D5000i Mini DV Digital Camcorder Logo
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
