Question about Xantrex Technology DC to Dual-Outlet AC Power Inverter
Usage inquiry How far can I keep my inverter from my batteries?
  • Anonymous Nov 17, 2008
    what size wire do i need running it 20 foot
    Novelist:
    Champion:
  • 277 Answers
Keep the cables between your inverter and batteries as short as possible. This will help your batteries perform their best and keep the inverter's signal clean. The cables that come with the inverter are "rated" or good for up to six ft. If you plan on going over six ft., drop down to a larger gauge cable. Please call us if you are still unsure. This is pretty important stuff that should NOT be overlooked. If the cables between your battery and inverter get hot while under heavy load, then you should use heavier cables.
Posted on Aug 27, 2008
    Guru:
  • 290 Answers
I will advice you to make it 1-2 meters
Posted on Apr 22, 2010
Battery connections
? I'm at a lost on why you need 8 battery's for 96 volts? make it 9 and you have 108 in volts?
not my problem, You hook up positive from bat 1 to Neg on battery 2 pos on battery 2 to neg on battery 3, and keep going till you only have 1 positive and i negative and when those are used you will have 96 volts,. OR you could just use the inverter and 1 battery for 110 volts?
Jul 02, 2014 | Inverter Aims Pure Sine Wave Power...
I have a camper trailer with 100amp battery and was wondering up to what size inverter i can run iwill be using 60ltr fridge (not running it overnight) a tv and computor
Before you get too carried away, are you aware that no matter what size inverter you are running, you need enough battery capacity to convert to AC (hydro) . 1 x 100 amp battery will not last very long under that load. Do you have plans, or storage space for a few more batteries? How/what are your plans for charging those batteries after usage, such as plugging the trailer in or an external charger, or perhaps solar panels?All that needs to be considered. Look at appliances you plan on running and get the watts, or amps required reading of tags, then it will be easier to calculate for you, and recommend possible solutions.
Aug 05, 2011 | Electronics - Others
Hi. I have a 5000 watt inverter in my truck. The alternator in the truck is a 150? amp alternator. I also have 3 deep cycle batteries (about 150 ah each) to run the inverter. Is this overkill for my...
A 5000 wat inverter is very large. Your alternator could not supply it alone without the batteries. The moderate to low usage is the key. Calculate the wattage of the load you want to connect. Depending on what else you're doing with the truck, lights, heater, air condition etc, you could probably draw somewhere between 1,0000-1500 watts on that alternator. Rember even if your alternator is rated for 150amps (large alt) it is not a 100% duty cycle. Alternators are usually around 50% duty cycle, so figure about 75amps continuous, or around 900 watts. That's considerably less than your 5,000 watt inverter. Buy a generator.
Jul 01, 2010 | Inverter Aims Pure Sine Wave Power...
I need to install my inverter 18 feet from my battery
a very thick one,,,like a baby battery lead on your car,,,its a very bad idear to have it so far away from the battery point, you would be far better off finding a closer place to put it as the volts drop off would have a big drop in out put on the inverter,,,also thats one big mother of a fridge to use 3000 watts????
you need a small power station to run it,,and if it do use 3000 watts your inverter is far to small to do the job, read the out put plate on the inverter,,it says 3000 watts max? not all the time,,,,thats about 2000 watts realy running contently and the whire to feed the inverter will need to carry about 30 amps so your car battery is say 90 amp hours plus the volts drop off, you would be lucky to have the inverter running for 3-4 hours before your battery go's is very flat on you!
Mar 28, 2010 | Inverter Aims Pure Sine Wave Power...
Why does the power inverter keep beeping when i plug up my laptop
If your not getting enough voltage to the inverter it will beep to let you know you don't have enough power. Most common cause is a lose connection thru your cigarette lighter. Also if you turn your key off it might be shutting down power to your plug.
Make sure you have a good connection with your battery or plug adapter. You also need a good battery so you don't go into a low voltage condition which will make your inverter beep.
Oct 29, 2009 | Black & Decker Power Inverter PI400AB
Inverter fan kicks on after turning on a light bulb
the inverter fan just kicks on to keep the system from overheating. Its perfectly normal.
Jul 24, 2009 | RoadPro RPPI-2500W Inverter
Tatronic inverter problem
Tightened up battery connections
Sep 24, 2008 | Inverter Electronics - Others
Power Supply How To
Because inverters operate from a DC (Direct Current) power source, usually a battery bank (one or more batteries), the battery source will have to be recharged at some point. (Remember that a battery discharged more than 50% is probably close to being dead.) Most cars and trucks recharge their batteries from an onboard alternator. Depending on the inverter load and runtime required, most power use applications will be covered by the charged battery, augmented by the operating alternator supplying a continuous charge to the battery. If the load is large (air conditioner, large draw power tools, large microwave, food freezer, ice cream machine, etc.), the user should verify that the installed vehicle alternator is of large enough capacity to operate the vehicle's power requirement as well as to fulfill the capacity of the inverter load. If it’s not, a motor throttle installation may be required to carry a small load, a larger alternator may be required, or a larger alternator, battery isolator and additional onboard battery bank may be required in order to meet the power requirement of the large load. Remember: it takes 12 DC Amps (at 12 VDC) to run 1 AC Amp (at 120 VAC single-phase) of power because there are voltage and efficiency factors to take into consideration.
Aug 27, 2008 | Xantrex Technology Xantrex Freedom Xmic...
Safety Inquiry
Improper use of a power inverter could result in personal injury. The inverter should not be installed in the vehicle’s engine compartment. Keep the inverter free from moisture as liquids conduct electricity, which may lead to serious damage or injury! Do not use the inverter near flammable materials or where fumes or gases may accumulate. The AC Output (neutral) wire should be vonded to ground, except in special applications. See owner’s manual for more details.
Aug 27, 2008 | Lenmar N-Verter 250 watt Maximum, 200 watt...
Inverter Question
Where can I download Instruction manual for Fuji FVR-E7S?
Aug 27, 2008 | Xantrex Technology Ags Harness Cable...
Xantrex Technology DC to Dual-Outlet AC Power Inverter Logo
281 people viewed this question
Top Xantrex Technology Electronics - Others Experts
EE Eddie
Jay Plesset
Are you a Xantrex Technology Electronics - Other Expert? Answer questions, earn points and help others
