Question about Dewalt 7,000 Watt 13 Hp Portable Generator With Electric Start #DG7000E
Product Specs What is included with the generator?
    Problem Solver:
  • 4 Answers
It is important to find out what does and does not come with the generator you are purchasing e.g. Transfer switch, composite pad (if not, cement slab may need to be poured, which may require a building permit being pulled), battery etc.
Posted on Aug 27, 2008
Buffalo tools 7000 watt 13hp ohv 4 stroke valve clearance
if you cannot get the specs from on line or from a service agent , generally the following apply:-
water cooled engines
inlet hot .010"--exhaust hot .012"
for air cooled engines inlet hot .012"-- exhaust hot .014"
Aug 30, 2015 | Buffalo Tools Electrical Supplies
Charger ipod model a1199
http://www.everymac.com/systems/apple/ipod/specs/ipod-2nd-generation-nano-specs.html
USB Support:
Sync & Charge
Firewire Support:
Charge Only
Details:
The second generation iPod nano models are capable of charging and syncing by USB via the dock connector. It also can charge, but not sync via Firewire "400".
Connectivity:
USB
Ports:
Dock, Headphone*
Details:
Apple reports that this model provides "USB through dock connector."
*Ports include the "dock connector [and] stereo minijack".
http://www.bing.com/images/search?q=images+of+apple+ipod+usb+chargers+&qpvt=images+of+apple+ipod+usb+chargers+&FORM=IGRE - view=detail&id=9C41186E7131E6658B9324CCA
Aug 05, 2013 | Computers & Internet
5VSB IS MISSINIG FROM MOTHERBOARD CONECTOR . COMPUTER WILL NOT BOOT WHEN POWER SWITCH ON FRONT PANEL IDEPRESSED . NEED A SCHEMATIC AND COMPONENT DIAGRAM FOR THIS UNIT .
specs are here
http://www.antec.com/specs/SP500_spe.html
This includes 5VSB
There is more info here
http://www.newegg.com/Product/Product.aspx?Item=N82E16817103937
the ATX spec and 20+4 connector pinout (wich locates 5VSB got you) can be found in the Wikipedia article (section 3 in http://en.wikipedia.org/wiki/ATX#ATX_power_supply_revisions has pin out details for ATX rev 2.1).
If your psu is missing 5VSB it is defective and should be returned to manufacturer or retailer if within warranty period. See testing psu articles also.
Jan 19, 2011 | Antec SmartPower SP-500 (ASKU37152)...
I need to know what ram this mcp61sm-am motherboard will accept cant find specs and ecs nor acer show this board,computer is an acer T180-ud401a
I believe the motherboard is actually manufactured by Foxconn. You can check here to see if it is the same. Full specs are also included.
http://www.foxconnchannel.com/product/Motherboards/detail_spec.aspx?ID=en-us0000223
Jul 30, 2010 | Acer Aspire™ T180 PC Desktop
I need the name of the motherboard used in the Compaq Presario SR1410NX so I can look at the manual.
HP lists the Motherboard as an Asus P4GV-LA.
Here is the support page for your computer:
SR1410NX Support
Click on Product Information to get the specs for it, including motherboard info.
Unfortunately Asus does not list this version on their support site but HP has quite a bit of info on the link listed below.
P4GV-LA Specs
Thanks for using Fixya.
May 20, 2009 | Compaq Computers & Internet
My NorthStar 5500 generator head no longer produces any electrici
Specs do not mention a maximum safe rpm but the recommended shaft speed is 3600rpm. Even though it isn't a premium product I can't imagine the manufacturer would be so foolish as to design it so it breaks if that speed is exceeded by a reasonable amount for a short amount of time. The big question is what is a reasonable amount - I reckon a safety margin of 25% would be reasonable for a budget priced product and up to 40% for a premium product.
Over-revving is unlikely to do very much damage to the stator but the armature is at risk of damage and being brushless or self-energising, unless there is visible damage it is a difficult item to test without dedicated equipment.
I suggest you recheck all plugs, connections and cables and if no faults are found contact the manufacturer or dealer for advice, costs, etc...
May 08, 2017 | Northstar Belt Driven Generator Head 5500...
Can't find the voltage specs for terk 9330 tower fm antenna
Product Specs: General: Product Type Radio antenna Recommended Use Indoor Width 3 in Depth 16.9 in Height 3.5 in Color Black Localization English Antenna: Wave Band AM, FM / FM: 87.5 - 108 MHz, 540 - 1700 kHz Impedance 75 Ohm Gain Level 42 dB Amplifier Built-in Included Accessories Connector coupler, impedance transformer Connections: Connector Type 1 x FM antenna ¦ 1 x AM antenna Power: Power Device Power adapter - external Manufacturer Warranty: Service & Support 1 year warranty Service & Support Details Limited warranty - 1 yearlet me know how this works out for u
Jan 31, 2009 | Audio Players & Recorders
Hi i jus need box and speaker specs for the dual 2 ohm 10pw3
General Information Manufacturer: Eaton Corporation
Manufacturer Part Number: 103004248-5592
Manufacturer Website Address: www.eaton.com/EatonCom/Markets/NorthAmerica
Brand Name: Eaton
Product Series: PW3105
Product Model: PW3105 700
Product Name: Powerware PW3105 700VA Tower UPS
Product Type: Standby UPS
Technical Information Plug/Connector Type: NEMA 5-15P
Receptacles: 4 x NEMA 5-15R - Battery Backup System
Switching Time:
  • 6 ms
  • 6 ms
Dataline Protection: RJ-45 Internet
Power Description Load Capacity: 700VA/420W
Input Voltage: 110V AC
Input Voltage Range: 0V AC to 160V AC
Output Voltage: 115V AC
Frequency:
  • 50Hz
  • 60Hz
Management Overload Protection: Circuit Breaker
Interfaces/Ports Interfaces/Ports: 1 x USB
Battery Information Batteries: Maintenance Free Sealed Lead-acid
Backup/Run Time: 3 Minute 420W Full-load
Physical Characteristics Form Factor: Tower
Dimensions:
  • 4.4" Height x 11" Width x 7" Depth
Weight: 9.7 lb
Miscellaneous Certifications & Standards:
  • Safety: UL 1778 3rd Edtion/CSAC22.2 No107.3, Designed to meet UL497A
  • EMI: FCC Class B
  • Software Included: Powerware LanSafe Software
    Green Compliance: Yes
    Green Compliance Certificate/Authority: RoHS
    Jan 22, 2009 | Powerware PW3105 700 (103004248-5501)...
    I have the logitech mm50 portable speakers; the on/off button is flashing red and the 3D-sound button is flashing amber; the battery is fully charged; it's been like thise for days; i've tried holidng all,...
    Here's what is going on - the mm50 speakers were made in 2005, before iPod decided to release third generation, fourth generation, and fifth generation players. The product specs for the mm50 might have said it was compatible with an "iPod classic" or an iPod "Nano" - but they were referring to an earlier generation of player. These Logitech speakers/dock just isn't compatible with 2006-2008 iPods.
    Reset the ipod and run the Recovery Tool like the user manual suggests - the full manual is available at Apple's website.
    If it is still possible, return the Logitech speakers.
    Jul 06, 2008 | Audio Players & Recorders
    TOUGHBOOK MPN CF-18KHZBBN
    I did not have a problem with this unit. I wanted to know if you had any information on this product as to the specs that are included with it .
    Problem solved by Panasonic Canada.
    Thanks anyway
    Feb 13, 2008 | Panasonic Toughbook 18 Convertible Tablet...
    Dewalt 7,000 Watt 13 Hp Portable Generator With Electric Start #DG7000E Logo
    98 people viewed this question
    Top Dewalt Electrical Supplies Experts
    JOHN LAPIER
    Jay Plesset
    Are you a Dewalt Electrical Supply Expert? Answer questions, earn points and help others
