Question about Coleman Powermate Medium Generator Cover PA0659771
Usage Question If I was to keep the tie between ground and neutral in the generator during standby use, would I have to break the neutral tie coming into home from grid?
I have a McCulloch 11HP FG6000MC Generator. Upon starting it will run well for about 10 seconds . Then it start to chock down then pick back up. It repeats this same process for about 2 minutes. Then it will even out after load is applied again about 2 minutes into the run cycle. Any ideas what may be causing this to happen?
Posted on Sep 17, 2008
  • 30 Answers
Never disconnect the neutral line as it enters your house. It is held very well at ground potential. Each transformer is grounded, and every home supplies ground as well. The neutral coming in is the reference to both live lines, and without it, anything connected to either live line could see up to 240VAC depending on what is across the other side. Install a proper transfer panel, and the neutral issue will be taken care of.
Posted on Aug 27, 2008
How do I disconnect neutral bond on a dewalt generator
Please be careful, you need a neutral bond for the GFI outlets to work when you are using the generator as a mobile unit and grounding the generator with a ground rod or building. When you are merging with a building with a grounded system, simply remove the two neutral wires (White) at the generators internal terminals from the generator frame but keep them connected together and terminate connection.
Bonding on a generator questions
Q. If I was to keep the tie between ground and neutral in the generator during standby use, would I have to break the neutral tie coming into home from grid?
A. Never disconnect the neutral line as it enters your house. It is held very well at ground potential. Each transformer is grounded, and every home supplies ground as well. The neutral coming in is the reference to both live lines, and without it, anything connected to either live line could see up to 240VAC depending on what is across the other side. Install a proper transfer panel, and the neutral issue will be taken care of.
Q. Where would I ground the generator at this time in this situation?
A. The generator will be grounded through the extension cord plugging into the transfer panel. Your home should have one ground connection only, adding a ground rod at the generator could create other unwanted safety issues.
Q. At this time is it safe to run an extension cord off generator direct to power a drill for example?
A. Yes. The transfer panel will take care of any neutral and ground bonding issues, provided things are wired correctly.
Q. If I was to lift the neutral to ground in generator and tag generator as floating neutral, then would I leave neutral unbroken in service panel?
A. Yes. The common point for neutral and ground will be provided in the main electrical panel.
Q. Could I use the 15 amp outlets on generator safely in this position to run a drill outside? I see generators with floating neutral have a 15 amp duplex outlet on cabinet also. In this situation would I install a ground at the generator?
A. If you were connected to the house with the four conductor extension cord nothing else will be needed.
Q. If you have a floating neutral generator and use it in a stand alone mode, nothing to do with a home, do you place a ground rod down? What happens with the neutral and ground connections? What about a generator on a truck or trailer?
A. In stand alone use, you should connect to a ground rod. Neutral and ground should also be bonded in the generator. The easiest way to take care of this is with a dummy plug inserted into one of the duplex outlets or the twistlock outlet. Jumper ground and neutral in the plug. A generator on a truck or trailer will follow the same rules for neutral and ground bonding, ground rods, etc.
Q. If the generator is a grounded neutral type and you only run the two live lines to the house in an illegal back feed situation where main disconnect is off but neutral still connected will I have 120 volts available in house between each hot leg and the utility grid system neutral? Would someone get shocked if standing next to generator at that time and touched it creating a path from ground to the generator?
A. The only time I would consider backfeeding a house is if the main lines were torn down and laying on the ground. I did this once after Hurricane Juan caused a tree to tear the lines off a neighbors house. The lines were still connected at the pole and were live once commercial power was restored, but there was no possibility of the generator backfeeding to the street. It took almost two weeks before the power company could get them reconnected. We still turned off the main breaker and installed a padlock to prevent it from being turned back on. The house was totally isolated from the grid so I felt it safe to connect in this manner. The generator connected via a 20 amp two pole breaker in the main panel, and there was power available for everything in the house - well pump, electric stove, all lights, etc. Generator neutral was floating as described above. Power supply was limited, they were careful not to overload and trip the generator breaker.
Q. At the same time I went to a friends home and after killing the main breaker and all 240 breakers ran a 3 wire cord from the generator 240 volt outlet direct to his pump, now isolated from the house panel using both 120 volt lines and ground. I then ran a 12 gauge 20 amp extension cord from the generator duplex outlet to a double male pig tail and back fed a kitchen outlet so he could have lights in the house. 1/2 the house to be exact. This was also a grounded neutral generator but we didn't have a problem. I did however drive a ground rod at the generator.
A. I think you were lucky this time. Electricity can be potentially dangerous and can kill and burn if not used correctly. Double male plugs should never be used as invariably there is exposed 120V on one end. If you miswire one end you can send 120V onto the neutral. At best this will trip a circuit breaker, but not knowing what else is done, could easily create a lethal voltage on the chassis of certain equipment. It gets back to doing something properly or not doing it at all. Why run the risk of personal injury or death?
Jul 09, 2014 | Dewalt DG6000 Heavy Duty 6000 Watt Gas...
Why my Buzz arround XL stops or drags when in neutral.
to push start a motor bike you have to use a higher gear like third gear but if you are only pushing it from one place to another then it is better in neutral or out of gear
Jul 04, 2014 | Golden Technologies Health & Beauty
How to float the neutral on a YDG 3800E and YDG 5500E?"
Why would you isolate the N and G? If you are using it to supply a home then they should be, if tied in permanently. But only on a 2 pole ATS. The gen ground and building ground must be common, or you will loose the fault path. I would NOT recommend you use this generator in that way.
Sep 22, 2013 | Yanmar Generators Yanmar YDG 5500 Diesel...
Honda generator eb4000x gfic tripping
if you are using a lead that has a active , a neutral and a ground wire in the lead , there is no real reason to ground the gen set itself
the neutral will not be bonded to the frame as that would create a possible short during operation
the circuit is simple --active is the power wire --neutral is the return wire from the applications and the ground wire is for dead shorts and to prevent electrocution
Sep 09, 2017 | Honda Electrical Supplies
I BOUGHT A REFRIGERATOR, IS IT NECESSARY TO EARTHED THE APPLIANCE? WHAT IF I DID NOT EARTHED IT, WHAT WOULD HAPPEN?
All the neutral and ground (or "earth") wires in a building are tied (or "connected") together at the incoming service main breaker panel - and that is the only place they should ever be tied together - because it is "upstream" of all the fuses and/or circuit breakers which are there to protect the hot (or "live") wires for the various circuits installed in the building.
In the absence of an earth wire (= ground wire in US/Canadian English), if the appliance suffered some damage that caused a short circuit between the high voltage "hot" lead and the case of the appliance, the damage would make the case live and it would cause an electrical shock to anyone who touched it.
If the case is earthed by using a ground wire (= earth wire in British English), if that same damage occurred the hot lead would immediately be shorted to ground and in theory cause the fuse to blow or circuit breaker to open, thus eliminating the danger of a live case.The ground or "earth" wire is a circuit's safety protective wire that normally carries no current.
It is there to force a fuse to blow or a circuit breaker or GFCI to trip if a fault condition occurs in any appliances, their flexible cords or plugs that are connected into the circuit.
By carrying away the excess current in a fault condition - which should cause the protecting fuse to blow or circuit breaker to trip - the "ground" or "earth" wire protects the building and its occupants because the power should be cut off before anyone gets electrocuted or any overloaded circuit wiring or appliances catch on fire.
The neutral is the normal "return" wire: in systems where the load is supplied from only one hot (or "live") wire, the neutral completes the circuit and carries current back from the load to the power station.
All the neutral and ground (or "earth") wires in a building are tied or linked together at the incoming service main breaker panel. This is the only place they should ever be tied together because it is "upstream" of all the fuses and/or circuit breakers protecting the hot (or "live") wires for the various circuits installed in the building.
Warning: we must never assume that a neutral is safe to touch: it has to be checked with a voltmeter or a voltage indicator to be sure it is not "live". This is because a neutral wire is designed to carry current under normal circumstances.
So, if a neutral wire going back to the incoming main breaker panel has not been properly connected - or suffers a deliberate disconnection or some accidental damage which causes it to break - then it and any neutral wires connected to it further downstream will go live up to the break because of being connected to the downstream loads which still have hot feeds coming into them!
That is why we should never use a neutral as a substitute for a proper, separate, ground or "earth" wire.
Aug 01, 2011 | Refrigerators
I got to move a dual light switch how do i wire it the breaker keeps triping
Are you talking about a stack switch with two different lights, with two different feeds or, a single switch with two different lights, or something else?A stack swich can handle two different circuits with two different feeds, or two different lights with the same feed. If you have two lights with the same feeds you want to put your power source on the side with black terminal and your switch leg on the other side and, tie your neutral in with the other neutrals, ground in with other grounds.. If you are moving the switch to a bathroom and have tied your neutral into a GFI circuit, this could be causing your problem. For two separate feeds, you would break tab joining the two black terminals on feed side of switch, and hook your two feeds on both terminals of switch, then you will have to break tab on switch side and do the same. This sounds like a neutral or a ground problem or, if when you put your switch in the box, you may have a bare ground touching the feed terminal on switch, if breaker pops right away, or, ground may be touching switch leg side of switch, if it pops when you turn switch on. Let me know if your dealing with a bathroom situation, if you are moving your switch into another existing box, or if you added a box. Try to explain to me how you provided, your power and how you got your switch leg to a new box if that is what you did.
May 03, 2011 | Hammering
I have a yamaha 3000isb generator. checking
That sucks! Maybe it's because your a fireman! LOL
May 08, 2010 | Yamaha EF2400iS Portable Generator
Microwave wont work on generator power!
PLEASE CHECK THE POWER CONSUMPTION ON THE APPLIANCE i think it might be a lot more than ur gen set can supply
Jul 08, 2009 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Stops and starts
Most home standby generators are setup to run once a week so as to keep the engine lubed up and the generator windings dry. So if yours is comming on once a week at about the same time and running for something like 15 minutes, that's what is going on.
On the other hand, if your generator is starting and the switch is transferring somewhat randomly, you could have a problem with the neutral connection in your system, the power could really be going out and coming back on, and/or the control board in your generator could be broken.
Regards,
Carl
Mar 12, 2009 | Briggs & Stratton 15,000 Watt Home Standby...
Coleman Powermate Medium Generator Cover PA0659771 Logo
200 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
