Question about RCA F32650 32" TV
RCA F32650 TV changes channels by itself
I have an RCA F32650 TV that keeps changing channels by itself. The only way to stop it is to pull the plug. Please let me know if it can be fixed and if so where can I get the parts. thanks for any help you can give.
  • LRover6868 Sep 15, 2008
    I have the same problem with rca F32649, where is the tuner area???
Problem is common to RCA models. The issue is bad solder joints in the tuner area. Resolder the entire tuner section of the board and the problem will be resolved. No parts are necessary.
Posted on Aug 29, 2008
The tv keeps changing channels. It's not the remote because I took out the batteries and it kept changing channels. I think it's the remote that is built into the tv. If there's anyway I can...
The problem is the tact switches on the front panel board inside the set. The entire "keyboard" can be ordered and installed. Have your model number ready. Just call Encompass Parts 1-800-638-3328 for information. If you are not registered as a repair center you will be charged retail price.
Jun 10, 2011 | RCA F32650 32" TV
The Television keeps changing channels on its own and won't stop.
See if the buttons on tv are correct or if one of them is not how it should be. if the problem is to the next channel button, then you have to open the tv and replace the broken button with a new one.
Oct 10, 2009 | RCA F32650 32" TV
TV won't come on.
I Have this same problem, Open the box on the top of your tv and unplug the wire with the white plug. The tv will switch on but u can't change channel. Hope u have receiver to change channel. If u have solution for the volume, tell me please. Ty
Oct 06, 2009 | RCA F32650 32" TV
The buttons on top of mt tv go crazy the flip channels automatically and turn volume up and down automatically
I have had this problem on this same model (F32650) and I discovered that what is happening is that dust and debris are causing the microswitches in the panel to short, therefore the channel starts changing and wont stop or the volume changes etc...
Get some electronic switch cleaner and (with the power off of course!) spray into the crevaces around each button and press each button a few times and then power the unit back on and it should be fine.
May 08, 2009 | RCA F32650 32" TV
RCA P52929 changes channel non stop
try unplugging it from the electric wall outlet for an hour then plug back in, this should reset your tv back to factory default, you will have to adjust your setings if you changed them
Jan 25, 2009 | RCA P52929 52" Rear Projection Television
Trobleshoot RCA F32650 32inch tv
I think that something has gone wrong on the power supply board. If you can check this for yourself otherwise find a competant technician. Hope this helps.
May 11, 2008 | RCA F32650 32" TV
Keeps changing channels/volume by itself
One or more of the front switches are likely leaky.  They are less than $3 apiece and I just change them all to save future problems.  You might be able to push all of the buttons on the front of the set a few times such as volume up and down and channel up and down and temporarly cure the problem but the switches will likely need to be changed.
Oct 16, 2007 | RCA F32650 32" TV
Help me...
1)pull chassis-solder any/all bad connects. 2)Replace shorted horiz o/p xistor #237470 and IHVT #257805 or Asti 2078
Sep 02, 2007 | RCA F32650 32" TV
RCA F32650
I let it go and she corrected by herself. What do you think?
Aug 14, 2006 | RCA F32650 32" TV
RCA F32650 32" TV Logo
401 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
