Question about Panasonic SC-AK320 Shelf System
No Audio on SA-AK320
I have a unit here which operates correctly execpt for the fact that there is no sound coming out of the speaker ports. i dnt have the original speakers for it tho the ones i am using are in fine working order. any ideas on were to start?? my guess is the speaker terminal circuit but what lines, componets etc... hell am hoping someone else has had to fix one of theses faults before save some time of stuffin round with bare minimal tools.
cheers
  • Panasonic Master
  • 19,396 Answers
Start checking audio aoutput settings.
Posted on Aug 27, 2008
  • Ginko
    Ginko Aug 27, 2008
    If the system has more than one oudio out, check that audio output is not set on a different value.
    More likely you will have to take apart the unit, inspect wiring to audio out RCA connectors, and test them for continuity.
    It is rather unlikely that both channels go at the same time, check the earphones audio jack socket on your stereo , if this is bed this will also mute the system.
    If it is not a connector/wiring problem, check that the stereo is working ang just not giving output( ensure is powering etc.)
    When you have no audio you quickly check the contols, and then pass to amp testing on main pcb, see if you find a faulty component testing onboard with a multimeter.
    To test the amp final it is better to follow directions on service manual.
    You can buy service manual here and follow diagrams that will give you directions on what components to test when you have no audio.
    You will also need a Multimeter.
I have a Technics audio receiver, model SA-GX650. The front speakers work correctly, but the back and center speakers do not work correctly, i.e. no volume comes out of them. Would you please let me know...
Some receivers have adjustments you can make during set up to direct sound in various ways. There also may be configuration selections you can make using the remote. For example, enabling surround sound or selecting simulated stereo. The instruction manual should explain the various options.
Nov 23, 2014 | Technics Audio Players & Recorders
I have a sa-ak320 stereo that was left at my gf's
The 6 ohm speaker would make it slightly louder but won't solve the problem, you are right the stereo has bad audio output ic, and there is trouble with the cd player. I would use it until it goes, and get a brand new unit, not cost effective to repair.
Apr 15, 2012 | Panasonic Audio Players & Recorders
My speaker wont work when i play anytin on internet wit sound i dnt hear a sound from my speakers
1: check the speaker wire. it should connect to a green port at the back of the computer.
2. In control panel open realtek audio device manager. it will tell you where its connected
3. try to configure the speaker from audio device manager on the system tray volume icon
still doesnt work then uninstall the driver for sound card from device manger
restart the computer
Apr 01, 2011 | Computers & Internet
When I turn on unit, a message "overload" appears.
Check the speakers and the power supply for any signs of shorting.
This is due to the fact that the safety circuit works to switch off the set preventing a high damage.
So check the output for short or the presection .
Sep 28, 2010 | Technics SA-DX940
No sound listening to music and audio stopped
Tape monitor is it on? Muting? How old is this unit? Does speaker relay click on secoinds after unit powers on? If relay does not click probably output problem. Try disconnecting speaker wires to see if relay will click. If it does click the suspect bad wire or speaker if not bad amp. The first step to diag is to diconnect everything and simplify the citems needed to get sound. 1 Known good signal source and cable, Minimum affects, check speaker switch, Known good wire and 1 speaker to front l or r terminal. iIf still know sound seek serv.
Aug 29, 2009 | Teac AG-V8060 Receiver
Technics SA-DX930 Sound cutting in and out
try rehooking up speaker wires. make sure no bare wire is showing and positive and negative are aligned correctly
May 19, 2009 | Technics SA-DX930 Receiver
Technics SA-DX950
sounds like the speaker protection relay is operating probably from a dc condition appearing on power amplifiers outputs. probable cause is dry solder joints to the output stages. will need some reworking of the PA stage soldering to fix.
Dec 10, 2007 | Technics SA-DX950 Receiver
Would it be possible to attach various speakers/subs.
i suggest that you can connect a subwoofer through a Pionner's like power amp and adjust it only with lowpass filter... you need a battery and a charger. and that's it.
Jul 10, 2007 | Panasonic SC-AK320 Shelf System
Panasonic SC-AK320 Shelf System Logo
244 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
