When i install windows 98 and take the instalation disk out i get a error sayingNTLDR is missing. could you help please. thanks HAROLD
  • 813 Answers
Its 98 or xp
Posted on Aug 27, 2008
Installed windows 7 and now its giving error that disk is full and runs very slow
If you have an old copy of windows 98 or 95,I have in the past installed one of these and it repaired the disk while installing,then installed windows 7,you could also try a low levell format but would need an external enclosure or a live disk to run from or go to and do a checkdisk scan(do this at night may take all night and sometimes never finishes)the last one wont require reinstalling windows.
Mar 16, 2014 | Gateway Computers & Internet
Boot problems and their possible causes & resolutions
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Corrupt Master Boot Record (MBR)
Boot into Recovery Console and run "fixmbr" to repair the MBR
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Corrupt boot sector
Boot into Recovery Console and run "fixboot" to repair the boot sector
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
"Windows could not start not start because the following file is missing or corrupt:
Corrupt/missing system hive
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Check the boot volume is accessible
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Hi. Problem with windows 98. My computer went into safe mode, and the only way that I could get it back was to run the WINDOWS 98 disk that I had when it was new. I now find that I am not able to change...
You need to install a video driver for your video card. Do you know what video card is installed? Do you have the original install disks for the video card? For a machine that old, it may be hard to locate a driver.
I usually use Unknown Device Identifier ( to tell what drivers are missing, but I don't know if it works with Windows 98.
Mar 23, 2011 | Computers & Internet
Message says that there is insuffient memory when trying to install or run Windoes 98Se on machine with 2MB Ram
Minimum hardware requirements for Windows 98:
1. 486DX 66 megahertz (MHz) or faster processor (Pentium central processing unit recommended).
2. 16 megabytes (MB) of memory (24 MB recommended).
3. Hard disk space may range from between 120 MB and 295 MB, depending on your computer configuration and the options that you choose to install.
4. A full install of Windows 98 on a FAT16 drive requires 225 MB of free hard disk space, but may range from between 165 MB and 355 MB, depending on your computer configuration and that options that you choose to install.
5. A full install of Windows 98 on a FAT32 drive requires 175 MB of free hard disk space, but may range from between 140 MB and 255 MB, depending on your computer configuration and the options that you choose to install.
6. One 3.5-inch high-density floppy disk drive.
7. VGA or higher resolution (16-bit or 24-bit color SVGA recommended).
If your PC does not meet the above minimium requirements, you are bound to get errors popup installing or running software.
Hope it helps.
Oct 30, 2010 | Microsoft Windows 98 for PC
Windows 98 on dell inspirion d600 install problem
Installing Windows 98, is you need a start-up disk (floppy disk) first before you can use the Windows 98 cd. The start-up disk will perform the partitioning and formatting of the HD...doing this, you have to boot from floppy drive first---after partitioning and formatting, you have change again the boot sequence to boot from cd then you can start the installation of Windows 98.
Jun 07, 2010 | Dell (6T980-A01) CD-ROM Drive
Invalid systme disk. Replace the disk and press any key
its domnickr,
its so we can not install xp in model 1255 it will spoils your hard disk all you can install win98 ED 2 only..... so its wise not to try it and reinstall using win 98 install disk. if format is not possible do format using Fdisk command.
step 1 :enter dos floppy
restart ur lap enter from insulation option.
chance boot perority to floppy disk ie Shift +.
restart lap
enter fdisk in commant
format using instruction for any help mail at
Mar 21, 2009 | Compaq Presario 1255 Notebook
Instalation of windws 98
Change your bios setting to boot from cd. restart, choose start with cdrom support and follow the instruction
Mar 14, 2009 | Microsoft Windows 98 for PC
Missing hard drive space
Simple problem you made the partions using FAT 16 file system and 80 GB cannot be partition using win98 10 will limit the disk to 10 GB.
Remove all Partions And Use Windows XP to create partition during Installion.
Fix Ya
Best Of LUCK.
Jan 07, 2008 | Computers & Internet
I have a problem
why dont you re install win 98?
That will end your problems
Oct 20, 2007 | Microsoft Windows 98 for PC
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
