hi,
i am having trouble with the barcode size.
My lable is (.5in X 1 in) Length X Width. when printing the barcode is very big for the label, is there a way i can change this?
thanks
I am having trouble with the preset label configurations, where the ribbon prints off the bottom of...
(More)
I am having trouble with the preset label configurations, where the ribbon prints off the bottom of the label. I need it to start about 1 cm higher... Can you point me in the right direction?
printing duplicate tags, the print is not in the same spot it moves 1/8 of an inch top to bottom it...
(More)
PRINTING DUPLICATE TAGS, THE PRINT IS NOT IN THE SAME SPOT IT MOVES 1/8 OF AN INCH TOP TO BOTTOM IT IS GOOD SIDE TO SIDE.
I am trying to run two 140xi iii's from Easylabel Platinum, i have one set up through a parallel...
(More)
I am trying to run two 140xi iii's from Easylabel Platinum, i have one set up through a parallel port (LPT1) and the other setup through a serial port (COM1). No problems with the printer running through the parallel , but cant get the printer with the serial cable to go (when i send a test print through the data light flashes once and then nothing). Any advice is much appreciated!!
