Question about Dell Inspiron 5160 Notebook
Powers on immediately powers off
I can't tell if you got my previous response so I'll try again.
I pulled the battery and turned the laptop on but nothing happened other than the power and battery light blinked very faintly. I plugged the power cord in without the battery and tried to turn it on but again nothing happened. I did notice that while the power cord was plugged in without the battery the power and battery light blinked every couple of seconds. I thne put the battery back in with the power cord plugged in and I noticed the battery light doesn't come on...normally its green or yellow when its charging.
  • Dell Master
  • 3,051 Answers
Ok well there is somwhere to start i would see if you can get it to take a charge ok and if it does than try to start it without the ac power on and see what it does if it wont take a charge your battery may be bad or your charging circuit may not be connected correctly ok lrt me know best regards mike
Posted on Aug 27, 2008
SOURCE:
Hp 2000 363nr Powers on with a blank screen and then turns off almost immediately
Try cleaning the laptop out. Use a vacuum cleaner on the exhaust vent on the bottom of the laptop.
May 27, 2013 | HP 2000-363nr 15.6" Inch 2.4gI3-370m 4gb...
PT Cruiser will not start or turn over....previously was overheating HELP!
I would start by getting a wiring diagram of the starting system or a repair book.
There is a 30amp fuse that powers the ignition switch and the starter relay in the fuse box. You should be able to jumper that relay and make the starter crank the engine. If so, check for power from the key switch to the relay and proceed with the rest of the circuits.
Aug 09, 2012 | 2002 Chrysler PT Cruiser
Hp G56-129wm won't boot. Powers up but doesn't show any screens, and then dies!
2 Suggestions:-
1) Did you tried to connect External Monitor? Tell me the status
2) Remove all Power Adapters and battery. Push the Power Button for 15seconds. Again Connected the battery and Power Adapter. Check if its working or not. If not then Must be Motherboard Problem.
Jul 24, 2012 | HEWLETT-PACKARD G56-129WM Laptop PC
I have an Acer Aspire One D150, and it keeps shutting down, when I try to restart it will only power up about 8 secs. It is previously working. I aleady tried the static discahrge and battery check and...
Hello.
The mo
st common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
If not an apparent hardware issue, since you replaced the RAM, then we'll turn to software.
Try System Restore. Boot your system to Safe Mode (press F8 repeatedly when powering on). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, all your updates will roll back to that date. Follow the process.
Hope this helps.
Oct 02, 2011 | Acer Aspire One D150-1587 Netbook
Power Turs on then turns Off
pull battery, plug it into the wall, and try again.
if that still powers off immediatly, then you have am motherbaord problem
Feb 26, 2011 | HP Pavilion dv9000z Notebook
Toshiba laptop won't turn on
Have you tried this with the battery removed, with just the power adapter? If it still just turns off than it could be a number of things. The CPU fan may have died, or the hard drive, either one of those issues can cause this problem.
Aug 19, 2009 | Computers & Internet
Powers on Immediately poers off
This could be a bad memory chip or slot problem. remove the memory and try one chip at a time in each slot. If this doesn't work then the problem will most likely be in the power management system on the motherboard. This will require professional diagnosing in order to track down the exact problem component.
Aug 27, 2008 | Dell Inspiron 5160 Notebook
Power on immediately powers off
ok i see can u tell me what happness if you take out the battery and try to start it
Aug 26, 2008 | Dell Inspiron 5160 Notebook
It won't turn on!
Could be a power board problem. Anyone home at that time alone, possible internal damage due to spillage???? Pull harddrive, reseat memory and pull battery and try again.
Jul 05, 2008 | Gateway MT3705 Notebook
Dell Inspiron 5160 Notebook Logo
235 people viewed this question
Ekse
Clive
Clive
