How can i open Maxtor one touch 4 plus external hard drive, actually i want to take out the HD out of its casing?
  • 114 Answers
If you must open it, do the following.
On the bottom of the drive there is a little round label that says warranty void if removed. Under this label is one small screw. Remove this screw, cut the lable at the seam of the case with an xactor knife or similar. You can now snap the case apart carefully using a very small screwdriver.
Lou
Posted on Aug 27, 2008
Hi there i hav ea maxtor onetouch 4 mini 120 gb.
Remove the hard drive from the Maxtor case, purchase an USB hard drive adapter case, and install the hard drive inside this case. Then you can connect this to the computer's USB port and if the hard drive is OK then this computer will detect it as an external USB hard drive, then you can open the folders and files and back them up.
Jun 29, 2010 | Maxtor OneTouch 4 Mini 120GB External USB...
I need the software to get into my Maxtor one touch 4 plus
all of the documentation and downloads for this product are now available via Seagate, as Maxtor was acquired. They are still supporting all the drives Maxtor produced for the normal periods of time.
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot4-downloads&vgnextoid=0ed72c9e46914110VgnVCM100000f5ee0a0aRCRD
Hope this helps FixYa,
Chris
Mar 22, 2010 | Seagate Maxtor 750GB One Touch 4 Plus...
Windows vista states insufficient space on Maxtor One Touch drive
You could check that the backup software settings are pointing to the correct drive. (I've made this mistake before).
Nov 03, 2009 | Maxtor OneTouch 4 Plus 500GB External USB...
My computer cannot dectect my maxtor one touch III 320GB
well, 2 options, your hard drive is not working in that case, just get a internal hard drive which is serial and open the case for the maxtor and plug the drive inside the case. its cheaper to buy the inter hard drive, then to replace the external hard drive.
Oct 29, 2009 | Maxtor OneTouch III 300 GB Hard Drive
Problem open up my maxtor one touch 500gb to retieve photos
first, recover your files. You will need to use hard drive deleted photo recovery program like Asoftech Photo Recovery, you can follow this video to recover deleted photo
http://www.youtube.com/watch?v=sNxApz_PBW8
I've had to use it many times in the past but in this case you need to plug that drive into another system as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
After you get back your files, you can then format the drive and reinstall your system.
Sep 09, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Vista is not picking up my maxtor harddriver but wheni had xp was .
Check the disk management MMC - it's likely that you have another drive letter that is conflicting with the Maxtor.
1. Right Click on the Computer Icon (or in the menu),
2. click on Managment,
3. look for Disk Management(on the left side) and click on that.
4. This will show you all the installed HD's that you have.
Your main HD is probably called Disk 0. IF there are any other HD's listed they will probably be labled "removeable", if it doesn't have a drive letter assigned to it do the following:
1. Right click on the Disk (X) that does not have a drive letter. (it should be a "Removable Drive")
2. Select Change drive letter and Paths.
3. Choose a drive letter from the list that is not used, I suggest W or Z just to be sure.
4. After you do that it should come up in My Computer as an available drive.
IF the External Drive is not listed then you need to change the USB port or try it on another PC to see if it works there.
May 30, 2009 | Maxtor OneTouch 4 Plus 500GB External USB...
When I purchased the Maxtor oneTouch 4 Plus for my Mac, they sent it to me without disk and manual. It does work, but I have some questions. What is that light on the side of the unit... when I press on...
the light is an instant backup button, you need to have the maxtor softwre installed, but when set up correctly the hard drive will create an updated backup of your mac's hd whenever the button is pressed.
Hope this helped.
Mar 04, 2009 | Maxtor OneTouch 4 Plus 750GB External USB...
Drive won't mount
i had a maxtor one touch go bad and had to open the case and take it out of the external casing and put it into my computer as an internal drive. then it worked fine. it was a single drive.
just today i had a maxtor TB drive go bad, and since i think it has two drives inside it i am very worried that i will not be able to do the same thing.
May 25, 2008 | Maxtor OneTouch II external hard drive...
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
