Question about Acer Computers & Internet
How is the Optical Drive removed from the Acer Aspire 1680?
  • 1,114 Answers
Hi - Remove by releasing the catch on the base of the unit:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Posted on Aug 27, 2008
2 Suggested Answers
  • 359 Answers
SOURCE: removing metal slug to install an optical drive on an Acer deskto
It will have to be bent until the metal gives. It is like those old toys that come in the grid that you have to bend and snap off.
Posted on Apr 09, 2009
Reset bios password acer 1680
The one that can access the bios password is the last one who reformat your unit. If you can not reached the said person?... Only some certified Acer aspire technicians can remove the bios password.
Feb 01, 2014 | Aspire Computers & Internet
Removing cd rom
The optical (CD) drive on your Acer laptop connects to the side of the device and is accessed via the underside of the computer.
If you are having problems with the optical drive on your laptop you should address it as soon as possible, and one thing you may need to do is remove it.
The good news is that even if you aren't particularly tech savvy, you'll find that the process of removing and replacing your optical drive is relatively easy.
Turn your Acer off and remove any power cables that may be attached to the side of the unit. Turn your Acer upside down.
Slide the battery out of its compartment on the underside of the computer.
Locate the circular optical drive retaining screw on the underside of your laptop.
It is located just above the square WiFi compartment in the middle of the computer.
Use your Phillips screwdriver to remove the screw and set it aside.
Grip the optical drive by its edge on the side of the computer and gently pull to remove it from the computer.
Slide a new optical drive into the computer, making sure the disk opening is facing out of the laptop.
Replace the optical drive screw.
Replace the CD Drive on an Acer Aspire 5000
The CD drive of the Acer Aspire 5000 is designed like most other laptop optical drives.
The CD drive is on the right-hand side of the computer and is attached with screws from the back of the case.
All you need to complete the task is a screwdriver.
To avoid electric shock or damage to the laptop, always ground your tools by touching them against a metal object like a table leg before using them on the computer.
Turn the Acer Aspire 5000 laptop off.
Unplug the power cord from the electrical outlet. Remove the power cord from the power supply in the side of the laptop.
Flip the laptop over so you are looking at the bottom of the case.
Slide the battery pack off the top of the case.
You'll see the CD drive on the left-hand side of the laptop when you are looking at the bottom of the case.
Unfasten the screws that are holding the CD drive onto the laptop with a screwdriver. Slide the drive out of the case.
Slide the new CD drive into the case and secure it with the screws.
Place the battery pack in the laptop and turn the computer back over so it is sitting on its base. Plug the power cord into the power supply in the side of the laptop.
Plug the other end of the cord into the electrical outlet.
Sep 06, 2013 | Acer Aspire 5610-4648 Notebook
How can i down acer acer aspire 5742Z-4200(LXR4P02002)PC
to tear down the laptop, kindly turn it off, remove the cables and battery then remove the hard drive , then remove the optical drive then remove the screws on the side of it then remove the keyboard.. Then you can have the motherboard shown on your laptop to check if it is in good condition..
Oct 05, 2011 | Acer Aspire 5742Z-4200 Notebook
How do I remove acer aspire 9810 keyboard,I have removed the base cover and screen assembly but I cant fugure out how to remove the keyboard Thanks in advance Peter
to remove the keyboard, remove the screws at the back of your laptop. Then remove the Hard drive, then remove the Optical drive then remove the video card, and then power supply. Then remove the fan from the motherboard and you may remove the screws on top of the keyboard. Finally you may replace the keyboard.
Jul 15, 2010 | Acer Aspire 9810 Notebook
Pc doesn't boot stops at set up
Your computer is having some problems at POST. Try removing one of the memory dimms you have installed. In case you have one leave it like that and remove Hard Drives, optical drives, any usb devices on the back and try again. In case it boots start attaching the hard drive and try again.. if it boots, add the optical drive and so on until you get the failure.
I hope this helps.
May 06, 2010 | Acer Aspire™ T180 PC Desktop
Replace the optical drive on Acer Aspire m1201
based on the images i've looked on for the Aspire m1201, you don't need to remove the front panel in order to remove the optical drive. if there are screws holding the drive in, remove them and then slide the drive forward. if its held in by sliding latches and not screws, then slide then in which ever direction necessary and then push the drive forward to take it out.
Sep 23, 2009 | Acer Aspire M1201 Athlon X2 320 Gb PC...
Removing metal slug to install an optical drive on an Acer deskto
Apr 09, 2009 | Acer Aspire M1201 Athlon X2 320 Gb PC...
For Acer Aspire 1680
i want to audio driver instllation
Jul 09, 2008 | Edirol UA-4FX External Sound System
Removing old/Installing new optical drive?
hi chris, best thing is to get hold of a manual but since NEC's support is not that good they don't provide them on their websites for download. but not to worry, generally you got 2 options from my experience i can confirm that the first one is the old drive is secured with a screw located in the back of the laptop underneath the drive itself if that's the case just unscrew it and release the old drive , the other option is you might need to strip the laptop down and unscrew the drive from inside the laptop i guarantee you these are the only ways manufacturers secure optical drives to laptops. hope this helps
Aug 19, 2007 | Acer Aspire 5003WLMi Notebook
Computers & Internet Logo
43 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
