Question about Samsung DouCam VP-D5000i Mini DV Digital Camcorder
Connecting analong camcorder to computer
How Can I Connect My Analog Camcorder To My Computer?
    Master:
  • 473 Answers
The only Analog camcorder that has a USB Connection for transferring pictures or video is the SC-L770. The SC-L770 can transfer video (live or recorded) and still photos through the USB connection. You can also transfer audio using the audio cable provided. After installing the driver and software, you can begin transferring data using the software provided. Connecting to a PC 1. Connect a USB cable to the USB port on the PC. 2. Connect the other end of the USB cable into the proper terminal on the camcorder. (USB jack) 3. Connect the audio cable to the Line input jack of the PC. If the PC has no Line input jack, connect the audio cable to the MIC input jack. In this case, however, a noise may be produced depending on the PC. Notes: * If you disconnect the USB cable from the PC or the camcorder while transferring, the data transmission will stop and the data may be damaged. * If you connect the USB cable to a PC via a USB HUB or simultaneously connect the USB cable along with other USB devices, the camcorder may not work properly. * In this case, remove the other USB devices from the PC and reconnect the camcorder. Some other Analog Camcorders have a snapshot mode which allows you to take a still photo with your camcorder. However, you cannot transfer these to a computer unless you purchase additional hardware such as a capture card. Some capture cards have analog a/v inputs which will allow you to use the a/v outputs on the camcorder to connect to your pc and transfer images and video. You can purchase a capture card at most computer and electronics stores. Samsung does not support capture cards.
Posted on Sep 06, 2005
How can I transfer from my JVC GR-FXM40EK to PC?
JVC GR-FXM40EK is analog camcorder that can not be connected directly with computer because computer needs digital video format to save the file so connect USB 2.0 Video Capture Device in computer and plug camcorder AV wires in that device that will digitize the AV signals of analog camcorder and computer will save it in your selected folder on hard disk.
Hope this will help.
Aug 07, 2011 | JVC GR-FXM40EK Camcorder
Trying to find a cable for my sony hI8 model number ccd-trv68 to go from my camcorder to my computer?
This is an analog camcorder - not digital. Therefore, the only cables you can use are the RCA types for audio and composite video. The computer must have an adapter board or allow RCA inputs (analog).
Nov 13, 2010 | Sony Handycam CCD-TRV68 Camcorder
I need a usb cable to connect my sony handycam model#ccd-trv138 to my computer
CCD-TRV138 is analog camcorder that can not be connected directly with computer by usb cable, this camcorder does not have any usb port to hook it to computer.
Only digital camcorder/ camera can be connected with computer.
Hope these info will help you.
Thanks.
Nov 06, 2010 | Sony Hi8 CCD-TRV138 Camcorder
Sony Handycam CCD-TR517 8mm Analog Camcorder
you can do that with EASYCAP usb2, a camcorder video capture card card " USB Convert VHS Tapes CAMCORDER to DVD Capture 0" , on ebay from wanghaostore. 10$. works perfectly, useful to digitalize VHS tapes too.
Jul 22, 2010 | Sony Handycam CCD-TR517 Camcorder
When listening to playback just on camcorder i can get sound but when i plug into computer or tv there is no sound. How do i get the sound to play?
Aw, this is very rare. Both digital and analog connection no sound? First, make sure with analog connecting cable working, must be the original JVC A/V cable and 2nd, when connecting to PC, use the software provided (CyberLink) for playing and editing videos. Good Luck
Mar 14, 2010 | JVC Everio GZ-MG335 HDD Camcorder
Hi8 Video to DVD
CCD-TRV37 is analog video camcorder and can not be hooked directly with computer because camcorder video-audio out is analog and computer needs digital format.
You can hook camcorder with DVD Recorder and burn a DVD. Now you have data in digital format and can transfer in your computer.
Jan 23, 2009 | Sony Handycam CCD-TRV37 Camcorder
Camcorder hookup to computer.
Dear Tudi
I just wanna share lil-information about Sony camcorders that if its model number starts with CCD-XXXX, it means its analog camera and it doesn't have capability to connect to Computer by USB cord. If its model starts with DCR-XXXX, it means its digital camcorder and can be connected with Computer. In 1997, all camcorders were analog and there was no digital camera in market.
May 25, 2008 | Sony Handycam CCD-TRV68 Camcorder
Connecting analog camcorder to HP Computer
You will need whats called a video capture card on your computer, then a DVD burner also. You can then hookup the audio and video from the camcorder to the computer. Playback a tape into a file and record the file to DVD Good Luck
Apr 06, 2007 | Quasar VM-D51 Camcorder
Can I connect my VHS-C Palmcorder® Camcorder to my computer?
No. Since VHS-C Palmcorder Camcorders feature only analog outputs, it is not possible to connect the camcorder directly to a PC unless your computer video card is equipped with analog inputs. The only way to transfer images from the camcorder to a PC is by using an external device capable of analog/digital signal conversion.
Sep 06, 2005 | Panasonic AG-185 Camcorder
Can I connect my VHS-C or S-VHS-C camera to my computer?
Since VHSC camcorders feature only analog outputs: it is not possible to connect the camcorder directly to a PC (unless a computer video card is equipped with analog inputs). The only way to transfer images from the camcorder to a PC will be using an external device capable of analog/digital signal conversion. JVC has released a capture device model, GV-CB3U which has the capability of video capture of a single frame in either Bitmap or JPEG format. The GV-CB3 can be connected to any video source through a standard video or S-Video connector and download single image to a PC using serial port (RS232C communication port). The JLIP Video Capture software necessary to transfer images to the computer as well as connecting cables are supplied with this product. You can also use 3rd party hardware (Video Capturing device) to send information from your camera to a PC. Visit your local PC or Office store for more information on other video capturing devices.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Samsung DouCam VP-D5000i Mini DV Digital Camcorder Logo
743 people viewed this question
Top Samsung Video Cameras Experts
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
