Question about Dell Inspiron 5160 Notebook
Powers on Immediately poers off
I pulled the battery out and tried to turn it on but since it had no power nothing happened other than the power light and the battery light flashed very faintly. I plugged the power cord in and tried to turn it on but nothing happened there either. while the power cord was plugged in without the battery the power light and the battery light blinked every couple of seconds. when I put the battery back in with the power cord plugged in, the battery light did not turn on...normally it would be green or yellow (when charging).
    Genius:
  • 2,028 Answers
This could be a bad memory chip or slot problem. remove the memory and try one chip at a time in each slot. If this doesn't work then the problem will most likely be in the power management system on the motherboard. This will require professional diagnosing in order to track down the exact problem component.
Posted on Aug 28, 2008
Acer aspir 5600, i pluged in and doesn't come on? power is on, just it is not take any power i guss
if the poer light turns on but nothing happens on the system possible the power supply on the motherboard which distributes the power to all the components of your laptop. and this means that you will need to have you system motherboard replaced, if I may have you tried removing the battery ans turning the system on using the adaptor only ? try it it the system turns on possibly the batter is causing the motherboard some issue on distributing the power to the system and may need to be replaced, try the batt first before going to the option of replacing the motherboard ^_^
Jun 06, 2010 | Acer Aspire 5600 Series 5630-6951 Laptop
Try to turn Dell Inspiron 6000 laptop and nothing happens. No lights, no sounds, nothing. Power chord is good and has output voltage of 19.5.
remove battery and then insert power cord and power it up. if it powers, then insert battery while laptop is on. otherwise, if it doesnt, get the battery charged from else where and insert it just to confirm that the power supply unit isnt spoilt.
Regards
Feb 13, 2010 | Dell Inspiron 6000 Notebook
My Dell laptop d600 suddenly shut off and will not power back up....led light on adapter blinks when plugged in...I have tried re-inserting RAM modules but this or nothing else seems to work.. thank you...
Unplug your battery and then plug in AC adaptor and see if laptop powers on. I assume you power button doesnt turn on at all? If so, your motherboard seems to have a power issue. Unfortunately, you have to replace motherboard. If laptop. powers on withour battery then you then battery needs replacement.
Nov 25, 2009 | Dell Latitude D600 Notebook
Power light on, nothing happens
Try holding down the power button for several seconds. This will shut down the PC. You should then be able to reboot the system.
Sep 10, 2009 | Toshiba Satellite A135-S4527 Notebook
MSI K9A2 CF motherboard powers up, but nothing happens
try to get into the bios and see if the function of the power switch assigned differently. there are MB that use the a hotkey in the keyboard to power-up the system. It should be there in bios. Read the MB's manual too. On OFF state, try typing "O" and "N" then hit enter
Aug 10, 2009 | MSI K9MM-V Motherboard
Acer 5580: No lights, No turn on, no power up.
restart u r laptop and press f8 button when u r laptop start in starting press f8 and then restore u r system and again install u r driver after uninstalling
Oct 18, 2008 | Acer Aspire 5580 Notebook
Powers on immediately powers off
ok well there is somwhere to start i would see if you can get it to take a charge ok and if it does than try to start it without the ac power on and see what it does if it wont take a charge your battery may be bad or your charging circuit may not be connected correctly ok lrt me know best regards mike
Aug 27, 2008 | Dell Inspiron 5160 Notebook
It won't turn on!
Could be a power board problem. Anyone home at that time alone, possible internal damage due to spillage???? Pull harddrive, reseat memory and pull battery and try again.
Jul 05, 2008 | Gateway MT3705 Notebook
Power on after HD replacement.
If you changed nothing apart from the hard drive I would remove it and then try restarting the laptop. If you get an OS not found message then check the pins on the hard drive (and caddy if there is one).
Sep 06, 2007 | Sony VAIO Z1RA Notebook
Dell Inspiron 5160 Notebook Logo
156 people viewed this question
Alun Cox
