Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
I want to go into this wireless router so that I can configure the IP address of our LAN to it
  • 148 Answers
Using the Configuration Menu
Note: if you have changed the default IP Address assigned to the DI-624, make sure to enter the correct IP Address.
 Open the web browser
 Type in the IP Address of
the Router (http://192.168.0.1)
12 Type admin in the User Name field
Leave the Password blank
Click OK
Home > Wizard
The Home>Wizard screen will appear. Please refer to the Quick Installation Guide for more information regarding the Setup Wizard.
These buttons appear on most of the configuration screens in this section. Please click on the appropriate button at the bottom of each screen after you have made a configuration change.
.13
Using the Configuration Menu (continued)
Home > Wireless
Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
SSID-
Channel-
6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
WEP-
Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-624 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
WEP Encryption-
Select the level of encryption desired: 64-bit, or 128-bit.
Key Type-
Select HEX or ASCII.
Keys 1-4-
Input up to 4 WEP keys; select the one you wish to use.14
Home > WAN > Dynamic IP Address
DI-754
Dynamic
IP Address-
Choose Dynamic IP Address to obtain IP Address information automatically from your ISP. Select this option if your ISP does not give you any IP numbers to use. This option is commonly used for Cable modem services.
Host Name-
The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
MAC Address-
The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
Clone
MAC Address-
The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the "Clone MAC Address" button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
Enter a DNS Address if you do not wish to use the one provided by your ISP.
Primary/
Secondary DNS Address-
MTU-
Enter an MTU value only if required by your ISP. Otherwise, leave it at the default setting.15
Home > WAN > Static IP Address
Static IP Address-
Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
IP Address-
Input the public IP Address provided by your ISP.
Subnet Mask-
Input your Subnet mask. (All devices in the network must have the same subnet mask.)
ISP
Gateway Address-
Input the public IP address of the ISP to which you are connecting.
Primary
DNS Address-
Input the primary DNS (Domain Name Server) IP address provided by your ISP.
Secondary
DNS Address-
This is optional.
Posted on Aug 28, 2008
Seting router d-link airplus g+ tm 624
You can set up for that dlink router.Do this step.
Click start>open internet explorer and the address URL type http://192.168.0.1 press enter.
Username admin
password leave blank
For setting details click this link to download user manual guide http://www.dlink.com/products/?tab=3&pid=DI-624&rev=DI-624
Hope can help you.
Thanks using fixya.
Jul 11, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
Hi, I'm trying to reconfigure my Solve Your D-Link AirPlus Xtreme G DI-624 Wireless Router, but I simply can't connect with it trying the following IP (Both with cable and wifi; the router SSID can be...
You will need to be hard wired (you can't configure a router via a wireless connection...
For default IP use 192.168.0.1 and the default user name is "user" password is .
that should get you in.
Mar 07, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
Its asking password for this ip address 192.168.0.1
The IP Address 192.168.0.1 is the address of the modem.
The Manual advises to enter admin as the User name, leave the password blank and click OK.
See page 12 of the manual Product Manual (5.0 MB) - D-Link AirPlus Xtreme G DI-624
Feb 09, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
Necesito instalar el driver de este D-link AirPlus
1. after power on you can connect your device to laptop or desktop through ehernet cable or wireless mode.
2. set your network adapter on automatic IP reconize mode and after get IP address you can configure your wireless device with 192.168.1.1 Ip address.
Mar 26, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
D link DI 624. Works with a cable but not with wireless.
pls check the wireless configuration on the webinterface by typing ip address of the router on the browser
enable wireless
Nov 02, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
How can i put a password to my N router (DIR 615)?
Connect a LAN cable to the router and computer. Open your WEB Internet Explorer and your in the router's URL IP configuration address.
This will be 192.168.0.1 and the default Login = admin and the default password = (blank) just press Enter.
You can now change the default password.
Oct 21, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
How can I reconfigure my access point on my DI-624 to 802.11a?
First press reset button for 10 seconds it is in back side of router.
Then connect router to computer with ethernet cable then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then you can see configuration page.
Enable DHCP if you want to get ip from router for your LAN.
Go to wireless enable it .
Then enable wi fi security wep security then enter WEP key it is your password to connect internet .
Then save settings and restart router.
Let me know if you need more assistance.
Thanks.
Oct 01, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
D-Link AirPlus Xtreme G DI-624 - Setting Wireless Key
You don't need any software, no. All you need to do is login to the router (usually 192.168.2.1 or 192.168.1.1 for D-link) and configure the wireless security (including the key)).
May 25, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
990 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
