Question about Lexmark E232 Laser Printer
Not running we moved printer from on desk to another at work and now the toner light is blinking and the error light is solid. the engine doesnt even turn over when reset..
  • Anonymous Sep 08, 2008
    I have the same problem -
    the toner
    light is blinking and the error light is solid. the engine does turn over when reset though.
    Genius:
  • 2,035 Answers
Apart from these error do you see any other error light blinking like ex 92XX light ,please let me know to help you...
Posted on Aug 28, 2008
Solid red light on this symbol <...> also
first change the black toner cardrige and try to run the printer most of the time the problem is gon after the change.
Apr 19, 2011 | Samsung CLP 315 Laser Printer
Tip
Printer error (orange or blinking light)
<b>Printererror (orange or blinking light)</b> After your printer has completed its initial startup you shouldhave a solid green light. If the light indicator is blinking or orange oftenthis is an indication of a printer error. For example, this could indicate a paperjam, issue with the ink or toner cartridge, or other serious error. Because there is no standard to what a blinking light or orangelight means if you're getting either of these we suggest referring to theprinter documentation for troubleshooting steps or methods of determining whatthe status indicator is reporting.
on Mar 31, 2011 | Office Equipment & Supplies
The orange light is blinking. Above the light is a triange with an exclamation point in it. I have tried deleting and reloading the printer and that doesnt work.
Do you have a new toner cartridge loaded? The red/orange light will blink when toner is low, even if everything else is working fine. Try printing out a test sheet and see what that tells you about your toner level. (Test sheep prints by holding the orange button down a second or two and releasing.)
Since I'm mainly printing drafts for my own use, I've just let the light blink while I eke out whatever I can from the remaining toner (occassionally removing the cartridge and shaking it -- being careful of clothes and surroundings -- to re-distribute the toner on the inside.
Oct 17, 2010 | Samsung ML-2510 Laser Printer
The top light of the two is flashing green/red back and forth very fast and the light on the bottom is a solid red. how do I fix this so that way it will work normally
The steady lower light indicates the unit needs a new toner cartridge, MLT-D108S. Did you previously see this light blinking or blinking rapidly? (Those indicate the toner being low.) Replace the cartridge and check for any other error lights. Turn off the machine and let it cool. Then open the front cover and pull the old toner cartridge. Open the package with the new cartridge, remove the packing tape and paper that protects the cartridge and gently shake it (avoid touching the blue or green parts of the OPC drum). Press the cartridge into the slot until it is fully seated. Close the front cover.
The green/red blinking power light is not one I'm seen before. The printer indicates a non-toner failure (open cover, no paper, LSU failure, etc.) with a steady red light.
Aug 02, 2010 | Samsung ML-2240 Laser Printer
Samsung printer ml 1510 red light flashes after self test
Red Error Light Stays On The following conditions can cause the On Line LED to glow solid red:
  • Printer paper is jammed inside your printer.
  • A cover is not be closed properly.
  • The toner cartridge is not inserted properly and needs to be reinstalled.
  • The toner cartridge is running low.
  • There is no paper in the paper tray.
  • The paper inside the paper tray is not be installed correctly.
Red Error Light Blinks If your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced. On Line and Error Light Blink Simultaneously
If your printer's On Line and Toner Save LEDs blink simultaneously, your printer requires service.
You can go to samsung online service request http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
Mar 21, 2009 | Samsung ML 1510 Laser Printer
Dell 1720dn toner error
You have to reset the drum count on the printer after you replace the drum. Call dell tech support they will not charge you for help resetting the drum even if you are not in warrenty.
Nov 16, 2008 | Dell 1710n Laser Printer
Error Light
The error is "toner cartridge error" you could try cleaning the contacts inside the printer (with the power off, of course). If that doesn't work you will need to try another cartridge.
Jun 14, 2008 | IBM Infoprint 1116 Laser Printer
Toner light doesnt go away in our printer and the printer doesnt print. We changed the cartridge please help us
The HL-2070N gets jammed in a toner end-of-life error condition. Perform the following to clear (I have 120 in the field so I know it works!):
With paper loaded, new toner in,
  1. Open front door
  2. Turn off printer
  3. While holding down the GO button, turn printer back on
  4. When all four LEDs light up release GO button. All LEDs will turn off
  5. Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
  6. Press the GO button 5 times
  7. Paper light will be blinking
  8. At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Mar 11, 2008 | Brother HL-2070N Laser Printer
IBM infoprint 1312 toner and error light.
If both Lights are solid, it means that the top cover is still open and the toner is low. Please make sure the top cover is closed all the way. If the toner light is blinking and the errror light is solid, it means there is a toner cartridge error. Please try a new cartridge. If that solves the issue, then you should return the damaged one.
Mar 10, 2008 | IBM Infoprint 1312 Laser Printer
Toner light blinks and error light shows
1- you either got a bad toner ( the chip on it is telling it it is bad)
happens sometimes with recycled toners.
Return it and tell them it is defective.
The chip needs to be replaced.
Try this but doubt it will work,
open front door hold down go button, all lights will flash in sequence wait for it to stop turn off and on and close door.
Oct 24, 2007 | Lexmark E220 Laser Printer
Lexmark E232 Laser Printer Logo
257 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
