Question about HP DeskJet 3550 InkJet Printer
Cable problem As soon as you try and connect an extension usb cable to the printer cable itself, the system (XP Pro) doesnt recognise the printer. When connecting only the printer cable without extension, it works fine. We have tried this on different pc's, with different extension cables?
  • anni47 Sep 06, 2008
    printer does not accept the print command from laptop which has vista as OS.
    Master:
  • 397 Answers
If you are talking about a USB extension over 15 or 16 feet in length then you will need something like this:
http://www.cyberguys.com/templates/SearchDetail.asp?productID=17940
I am sure you can buy a signal booster just to plug in the line but I can't find any at the moment.
Posted on Aug 27, 2008
  • HP Master
  • 19,396 Answers
Usb extension cables may give you troubles, buy a longer usb single cable, possibly a well sielded one (ask seller) long usb cable can give you troubles due to the bigger signal loss on a longer wire.
Print job goes to print queue but does not print
Un install the drivers.
Connect through usb cable observe system recognised the printer?.. if recognised, reload the drivers & chk for the prints.. if not issue with formatter..
Insert net work patch cable., print configuration page., verify the ip address., load the drivers as network printer., chk for the prints., if not printing., ping ip from system... chk withnamother cable.., fotmatter issue..
Apr 04, 2014 | HEWLETT-PACKARD LASERJET PRO P1606DN...
Yamaha i425: usb midi driver issue
The USB cable may be defective
May 25, 2013 | Yamaha Music
My pc doesnt recognise my865 dvr
The fact of the matter is that your vivitar comes with software that works with your computer. Supposing that you have the normal windows operating system, then you should be able to have your camcorder recognised. You must have the Snap and Share video pro and Video Express that comes with it. On connecting you camcorder the computer should recognise it if it does not then the cable you are using could be the problem if you already changed the cable then the usb socket on the camcorder could be damaged. If your cable and camcorder socket are ok then you could use a USB card reader to transfer your video to the computer.
Oct 09, 2011 | Vivitar 865HD Digital Video Recorder
When printers USB cable is plugged in it is not recognised. Driver installs ok butcomputer does not communivate with printer.
Unless your printer main board has failed, the only reason that a USB connection would not communicate is if your printer is turned off or if the USB printer cable or connection is faulty. Try connecting other equipment with the cable and see if that gets recognised by your computer also try connecting to a different USB socket on your computer.
Hope this helps.
Jan 22, 2011 | Xerox Phaser 3150/B Laser Printer
I have an intermittant fault when I insert the USB of the Pro 9000 I am advised that the 'USB device is not recognised'. I have installed the software again but this still happens and the camera will not...
How long you've been using this? you may have a loosed cable connection going to your device, try to clean the USB ports where your device was plug, if still it will not work may be the cable itself has some areas that where cut-off. If that is the case it time to replce your device.
Dec 09, 2010 | Logitech QuickCam Pro 9000 Web Cam
Hp4580 not recognised on XP 64 bit
Try changing USB cable. Your USB cable might have got corrupted.
May 26, 2009 | HP J4680 Office Jet All-In-One Printer
N72 problem
it is the problem with usb data cable or with ur phone point which we connect the datacable. when u find this problem expand the cable for a max. distance from the pc when u connect both of it.
Jul 25, 2008 | Nokia N72 Cellular Phone
HP DiskJet Drivers
Dear AJP82
As soon as you start the printer when your computer workin. the computer should recognise . If Yes recognising then you can down load the compatible driver from Win xp CD or from HP website. Else try changing printer cable with other cable. Or if printer allows parallel or USB try either of them.
Regards
Rafique
Feb 10, 2008 | Office Equipment & Supplies
HP Laserjet 3100 all in one USB driver / cable
http://www.hp.com/#Support
Follow the link and get the correct driver and get installed
Also try with another USB cable, If you are using a long cable, just try with a short one.
Dec 17, 2007 | HP LaserJet 3100 All-In-One Printer
HP DeskJet 3550 InkJet Printer Logo
56 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
