Question about GE JVM2070 Microwave Oven
How to access touchpad
Touchpad buttons are loose. how does one remove the cover of the panel to access the touchpad area. i was able to reach in from behind and maneuver them but they are loose and fall back down if i press any of the buttons.
  • GE Master
  • 9,098 Answers
1. Unplug it from the outlet.
2. Remove any screws and unlatch any tabs in the vent grille.
3. Pull up and/or out to remove the grille.
4. Remove the screw now revealed at the top of the control panel assembly.
5. Lift up and/or swing down the control panel assembly.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you still have trouble, please reply back with your model number.
We repair these control panel assemblies.
Posted on Sep 01, 2008
  • William Miller
    William Miller Sep 06, 2008
    The little plastic retainer tabs may have broken off.
    If so, you can use hot glue or epoxy to tack them in place where the tab(s) used to be.
    I happen to be waiting on parts to fix one of these right now.
Microwave will not run a cook cycle. Touchpad functions until door is opened or start button is pressed. When door is opened display goes dark. When door shuts display lights all characters and then says...
BEFORE DOING ANYTHING DISCONNECT OVEN FROM POWER. I do NOT recommend doing repair by yourself, if you NOT are really very familiar with electric repair, or have at least basic training in electric device repair and maintenance.
"When door is opened display goes dark. When door shuts display lights all characters and then says "touch clock"."
Obviously, by opening door, oven gets disconnected form power line.
This is mostly caused by loose connections on wiring socket, and can be anywhere inside. Check security micro switch on door latch. This switch normally disables only running the oven when door is open, for security reasons. In your case, it seems that opening door disconnects oven from input power. Sometimes the switch is loose, or wires are not firmly pushed in the socket. If the power line wiring is loose, and by opening door looses contact with socket, it can touch metal housing inside, cause short, electric shock, serious even mortal injury and fire. This is dangerous high voltage switch, and to access it one must open oven from the back and take off the cover. I do not recommend doing it by your self.
Rem: Replacement micro switch is couple dollars.
Oct 24, 2014 | Microwave Ovens
MICROWAVE DOOR SAGS CAUSING IT NOT TO OPERATE
I just repaired a different brand of microwave a few weeks ago with the same problem and all it ended up being was some loose screws on the bottom hinge. Take your plate out and then turn your microwave on it's back and see it there are screws in the hinge area and make sure they are tight. If they are, then it might be the upper hinge that is loose and you would have to take off the outside cover to reach those screws and more than likely you would need a special torx screwdriver to get those screws out. If you have access to that kind of screwdriver, just be careful when you take the cover off and put it back on that you get all of the clips back in the right place so that the cover goes back on correctly. Always remember to unplug your microwave if you are going to take the cover off.
Feb 03, 2014 | Sharp R-1405 / R-140 Microwave Oven
Timer stops after 60sec when preheating. Eventually after pressing several individual minutes it reaches preheat temp then will cook for whatever time I want
follow this steps and fix it. God bless you
  1. Main control boardIf your microwave runs for a few seconds and stops, the first thing to check is the main control board to ensure that a shortage has not occurred. If the part is defective then it will need to be replaced to prevent continual shut offs. If this is not the issue, the next step would be to check for a faulty touchpad.
  2. Touchpad/Control panelIf the control board is not the issue and your microwave continues to shut off after running for only a few seconds, the next thing to check is your touchpad, which is also known as a control panel. Although uncommon for this issue, symptoms are usually that the display and some buttons are working properly; however, when selected some buttons are not functioning. If this is the case the touchpad will need to be replaced.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#7#ixzz2Zb4tZMmz
Jul 20, 2013 | Microwave Ovens
In oven the start button is not working
see the details and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Nov 15, 2012 | Whirlpool Microwave Ovens
Maytag microwave keypad
see this causes and fix it. God bless you
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Oct 01, 2012 | Maytag MMV4205 Microwave Oven
Sharp carousel microwave touchpad start button is failing
may have to get a membrane switch........could be starting to fail, become intermittent...i've had to replace these on occasion.
Jul 22, 2012 | Microwave Ovens
How can I find my fuse on my Sharp Carousel R-1471A
your fuse holder appears to be behind the control panel area. you may be able to just remove the grill above the door and control panel to access the screw that holds the control panel in place, then swing that down and see the fuse and holder.
you may however need to lower the unit from its mounting place to remove the outer cover to access this fuse..
hope this helps,
best of luck,
ttfn
Oct 30, 2009 | Sharp Microwave Ovens
GE Microwave-Touch pad/controls fail unless you hit side of oven
I can only toss you some ideas, but likely but not always, you might have what are called security screws holding the cover on the microwave - they typically have a little pin in the center and you need to buy a special tip to remove the screws including any on the side - then pull and slide the cover off the microwave - Needless to say with the power unplugged!
Then you should take a close look even with a magnifying glass, at any of your connections - many are spade connectors pushed onto flat blade-like pins - you may find that you have an over-heated one, or a loose one. If it is overheated, you will have to cut off the bad connector, get a new one wherever, strip the wire(s) back and crimp on the new one. If the connector is simply loose, take a pair of needle nose pliers and close up the connector so that it goes back on tightly.
Now this is where you need to (sorry to swear), but use common sense - plug in your microwave with the cover off, and try you touchpad to test whatever repair you did - If it is fixed, then unplug and put the cover back on and back to Zip-Zap and Ding Suppers
Eric
Oct 14, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Buttons for light and fan
I had the same problem with the three buttons pushed in.  Here's how I fixed it:
1. turned off power at breaker or pulled plug 2. Unscrewed two screws on top of unit 3. Removed exhaust vent cover/grill by sliding it to the left and out 4. Unscrewed single screw above LCD control panel 5. Removed control panel assembly by sliding it up and out and rested it on a box so wires wouldn't pull out 6. The control board behind the three buttons had dislodged from the clips 7. Secured the control board with the clips and added a little superglue to clips and extra foam padding to keep it from moving. 8. Screwed the control panel back in, powered up, and tested 9. Reattached the exhaust vent and screwed it back in
Dec 01, 2006 | GE JVM2070 Microwave Oven
GE JVM2070 Microwave Oven Logo
290 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
