Question about Canon BJC 80 InkJet Printer
Have Toshiba laptop with XP and Canon BJC-80; can these work together?
I am putting two old pieces of equipment to work and do not have a driver to install that is suitable for XP. I wanted to use the two together so would not have to lug other laptop when at alternative site. Is there a driver to update the Canon BJC-80 bubble jet printer to work with Toshiba with XP? R. Diket
    Brigadier General:
  • 6,966 Answers
To my knowledge, appropriate drivers for the Canon BJC-80 printer are built-in to the Windows XP SP2. To manually, set it up, pls click on Start, Printers & Faxes, Add Printer, and follow on-screen instructions.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 27, 2008
  • Canon Master
  • 19,396 Answers
There is no driver available from Canon for Windows XP (see here).
There is no driver available for your printer on Windows XP, the only drivers on google are either viruses or spyware software, do not install any of them.
Trying to hookup bjc 80 to acer aspire 4730z running vista, don't have disc but am hooked up via usb.
you need the printer driver for vista in order to be able to print out. But Canon does not offer drivers for XP and Vista for bjc-80, however you can manually install the driver for BJC-85 and get the printing function going, but the scanner cartrige does not work through USB.
BR
Bruce
Oct 23, 2009 | Canon BJC 80 InkJet Printer
Canon BJC 80 New Cable Required
You Can Get Them At Radio Shack, Circuit City Or Best Buy Maybe Even Wal-mart
Jan 07, 2009 | Canon BJC 80 InkJet Printer
What does disabling bidirectional support mean
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} USB to Parallel conversion requires translation by XP and Vista's 'hardware interleave' software as well as the USB device manufacturers driver. The software package just doesn't work well with older peripherals that use legacy parallel or serial com ports. Too many sloppy layers.
THE BEST WAY to add an LPT printer port to your laptop is to use a PCMCIA to Parallel adapter card.
The PC Card slot provides access to the laptop's data bus, and the PC Card adapter easily sets up as a native LPT port within almost any OS.
There is no delay, or connection problems as I've seen in so many complaints about USB to Parallel or Legacy Serial adapters. Printing is Instant.
PCMCIA is a mature standard, and works seamlessly with XP and Vista, and almost any other OS.
PARALLEL is the old standard fast data protocol. IEEE 1284 ECP mode up to 1.5 Mbps.
The BJC-80 and the BJC-85 have the same print speed. The BJC-85 just added USB.
INFRARED is ver 1.0 on the BJC-80, and printing is a bit slower at 115.2 kbps. Even the BJC-85 with its higher IRDA transfer rating and a laptop's built-in IR port, the XP print spooler has problems with it, and can hang if printing more than one page, and especially with more than one document. It will not scan.
I use IR for printing single pages only with either the BJC-80 or BJC-85.
USB to IRDA adapters work fine, and are less expensive $5-6 than
PCMCIA to Parallel adapters, $20-25.
I have tested and used several PCMCIA adapters from different manufacturers, and they all work perfectly as a hot-pluggable, instant LPT and/or Legacy Serial port for my laptops.
TIPS:
After installing the PC Card driver, check Device Manager for the LPT port number.
Install the printer manually from the list of printers, and select the proper LPT port.
Most laptops have two PCMCIA slots. If you change slots, the adapter card driver may reinstall, and assign the next available LPT port, LPT2.
To scan with the BJC-80, you must have an LPT port.
The PC Card adapter also allows the use of the IS-12 scanner cartridge within XP or Vista.
Within Vista, set the Canon ISScan software to run in Windows 98 compatibility mode, to allow use of the TWAIN driver.
Jun 12, 2008 | Canon BJC 80 InkJet Printer
Canon BJC 2000 question-1284 to usb
TIPS:
Jun 05, 2008 | Canon BJC 80 InkJet Printer
BJC 80 Won't Print
Try disable bidirectional support
Jun 02, 2008 | Canon BJC 80 InkJet Printer
Canon bjc 85
Vista driver for this machine comes stnadard with vista but will not work when old xp drivers are present (or were when upgraded to vista) , remove old driver from system, connect printer,  vista should auto reconise and install.
Here is a canon link explaining Vista with BJC 85
http://www.usa.canon.com/consumer/controller?act=SuprtKnowledgeBaseAct&fcategoryid=230&modelid=6620
Oct 31, 2007 | Canon BJC 80 InkJet Printer
Time consuming
Try installing the latest driver: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=230&modelid=7998
Aug 23, 2007 | Canon BJC 80 InkJet Printer
Printer problem
here is the link for the driver download for the i250 for xp (hope you didn't mean you threw the printer itself away) http://software.canon-europe.com/software/0023758.asp?model= Here is the link for the bjc 80 scanning driver for xp; http://software.canon-europe.com/software/0018984_0000424.asp?model= but unfortunately canon does not seem to have a driver for printing in xp for the bjc80, it doesn't seem to be compatible - contact canon and they might have plans to release an xp driver this link has dos drivers for the bcj80; http://alpha03u.c-wss.com/inc/ApplServlet?SV=WWUCA900 Hope this helps - other option would be to go back to windows me/2000 or get an xp capable printer - if you get a new one make sure it can deal with windows vista as well in case you upgrade in the future :)
Mar 18, 2007 | Canon BJC 80 InkJet Printer
Canon BJC 80 InkJet Printer Logo
116 people viewed this question
old marine
old marine
