Question about Canon MP610 Photo All-In-One Printer
MP610 Scanner Not Working
All cables are attached.  Other functions working fine.  Whenever I select scan and press the "start" key (the two buttons on the right-hand side, one says "black" and the other says "color"), nothing works.  After selecting "scan", I receive the prompt to "place document on platen glass and press (insert button symbol)", but when I press the button -- either the one for black, the one for color, or both of them together -- nothing happens.
TIA for any help.
  • 8 more comments
  • PapaZulu Sep 21, 2008
    Same problem here and on-line manual will not open at all .
  • florian2 Sep 23, 2008
    exactly the same problem (windows xp). have the newest drivers but it still doesn't work. any ideas?
  • scantrell540 Sep 27, 2008
    I just hooked mine up today and have the same problem! Have you figured out what to do yet?
  • comnomad
    comnomad Oct 02, 2008
    Same problem but with Mac OS X. Maddening. I can see the scanned image on my Screen using Image Capture, but the [Scan] button on the Mac is grayed out and no button on the printer/scanner will make anything happen. It just sits there. I went to Canon's website and downloaded the latest driver for my OS, but that didn't do anything.
    Also, this same error appears on the Apple site and it hasn't been answered there either. Very frustrating!
  • shanemc Feb 05, 2009
    Same problem for mac OS
  • Anonymous Mar 25, 2009
    Having exactly the same problem as the original poster describes.
  • Anonymous Mar 29, 2009
    exactly the same problem.
    nothing helps....
  • Anonymous Apr 25, 2009
    I had the same problem and thanks to this website I got the solution. Canon could of been a bit more useful in their instructions.
  • p-wallis1 May 14, 2009
    Exactly the same! Nothing happens when I try to scan
  • Anonymous May 19, 2009
    The issue for me is that my computer doesn't even recognize the scan driver... I can print, so the printer is definitely connected, but it won't scan
I was having the same problem as the original poster of this thread, where nothing was happening, and this was what i did:
using a mac, i:
- spotlight searched "image capture" (that's what it's called) and opened up the app
- it somehow "woke up" my printer, aka connected the printer to the app, and it would scan the overview, but not scan the final selection that i made. see comnomad's post if you don't know the difference between overview vs. scan.
- so i restarted my printer
- i then did the overview, selected the parts that i wanted, and scanned it again
tada!
Posted on Feb 20, 2009
I had this same problem too. It took me a while to figure it out - not to mention surfing the web for a bunch of sites all with people writing about the same problem. I downloaded the latest driver, checked all the cables, hit every support website I could find, etc. Nothing worked. Then I did +one little thing+ and it worked. I'm assuming that you figured out the problem by now, it's kind of silly.
When you open Image Capture it projects an image from the scanner to your screen. But *YOU* still have to go to the image and select what you want to scan. When you place your cursor on the image and then click and drag, you're capturing the area that you want scanned. When you do this you will see all the dimensions of the scan area captured in the Scan Setup box to the right of the image. You can manually go in and change the dimensions to match the material your scanning (8x10, 4x6, 8.5x11, etc) as well as adjust the resolution or increase or decrease the size.
Once you get it figured out it works pretty slick. Unfortunately the directions aren't very obvious and the interface on the printer is a bit misleading. Hope this works for you (and anyone else who suffered this issue).
Posted on Oct 02, 2008
  • mattdriver Dec 10, 2010
    I had the same problem.Canon Pixma MP 610 the scanner just stopped working..Usually I chose Microsoft Scanner
  • mtnclimber06 Feb 07, 2011
    I did all that I could. It won't wake up and scan. It print, copies, but won't scan. I hit the start button and nothing. Time to move on. POS
This seems to be a USB issue. I had exactly the same problem, switched to a different USB port, and everything worked perfectly.
Posted on Mar 17, 2009
    New Friend:
I had the same problem. The solution is to go into Control Panel, then select Devices And Printers, then select the Canon Inkjet icon, then select Scan Photo Or Documents. This worked for Windows 7.
Posted on Apr 11, 2013
  • Carolyn Cornie
    Carolyn Cornie May 16, 2017
    I want the scan sent to an email...will not work.
Connect 6180 MFP scanner to Toshiba laptop
Press the document to be scanned on the Platen glass. Press the Scan button, an Utility will appear. Select required size and resolution. Upon scanning document, save it in compatible format and attach it to email.
Jan 08, 2014 | Xerox Phaser 6180 MFP/N Letter-Size Color...
Problem with 5300 scanner
the inner parts may not receive proper power supply thats why you are not able to scan .......
Aug 19, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
I HAVE THE X47850 SCANER HOW DO I SET THE SCANER CODE SO I CAN SCAN?
Hello.
You don't need a scanner code (pin ?) to scan. Here are the steps from Lexmark Support:
Step Action 1 Make sure the printer is configured to scan over a network. 2 Load an original document face down on the scanner glass. 3
From the control panel, press pattlnk_1182007_1150-uparrow.gif or pattlnk_1182007_1146-downarrow.gif repeatedly until Scan is highlighted. 4
Press pattlnk_1182007_1151-selectbutton.gif. 5
Press pattlnk_1182007_1150-uparrow.gif or pattlnk_1182007_1146-downarrow.gif repeatedly until the computer you want to scan to is highlighted. 6
Press pattlnk_1182007_1151-selectbutton.gif. 7
If you set a PIN during network setup and are being prompted for it:
  1. Enter the PIN using pattlnk_1182007_1151-leftarrow.gif and pattlnk_1182007_1152-rightarrow.gif to select a digit location and using pattlnk_1182007_1150-uparrow.gif and pattlnk_1182007_1146-downarrow.gif to select a value for that digit.
  2. Press pattlnk_1182007_1151-selectbutton.gif.
8
Wait until the printer has finished downloading the scan applications list. 9
Make your selections using the control panel buttons. 10
Press the green Start button (pattlnk_1182007_1144-scan%20start%20small.gif).
Hope this helps.
May 27, 2011 | Lexmark X4270 All-In-One InkJet Printer
Hello am using sharp ar165 m copier machine .and am installing my pc also but scaner is not working please help me.
How are you doing? In order for scanner to work in all multi-functional printers, you must install all functions. While installing printer Sharp Ar165m, it will ask you if you need to install scanner and you must select that box otherwise it will install printer alone. Also there is an option where you are to configure the button keys on scanner function, please configure the buttons while installing. This will allow you to press scanner key on the copier to start scanning without necessarily selecting from the computer otherwise --- will appear and nothing happens. So insert the software CD and remember to select scanning option.
Dec 15, 2010 | Sharp Office Equipment & Supplies
How to tell what the buttons do?
The HOLD key lets you freeze the scanner on an active channel. For instance, if the scanner stops on channel 3, and there's a lot of action there. you can press HOLD to lock the scanner on that channel until you press the SCAN key. Repeatedly pressing the HOLD key will manually advance the selected channel.
SCAN releases a HOLD asnd will also take the unit out of PROGRAM or SEARCH modes and start it scanning the frequencies that you've programmed.
FUNCTION selects the secondary (lower) function of a key. For example, pressing FUNCTION and then the E (ENTER) key will switch the scanner to Pgm (Programming) mode - which lets you enter and store frequencies into the unit's memory so that you can scan them later.
All keyboard functions are explained in detail in the scanner operating manual, which you can download/print here:
http://www.uniden.com/pdf/BC92XLTom.pdf
For a comprehensive database of active frequencies in your area, along with a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B
Apr 11, 2010 | Uniden Nascar BC-92T Scanner
My uniden bc80xlt handheld scanner has lost all button functions. The radio still scans and picks up frequency broadcasts, but NONE of the buttons work. What is going on here?I have no" manual" function, I...
Sounds like you may have accidentally pressed the "LOCK" button. If there's a "key" icon showing, press the LOCK button at the bottom left of your keyboard, and hold it in until the icon disappears. In case you need it, here is a link to the operating manual for your scanner:
http://www.uniden.com/pdf/BC80XLTom.pdf
Nov 22, 2009 | Uniden BC80XLT Handheld Scanner
My copier and printer work just fine but cannot get the scanner to work at all...I have followed the instructions precisely. Isobel
Okay so the copy and print function works, but you can't scan to your computer?
Are all the drivers installed?
all the drivers etc are available at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=2613&modelid=15603#DownloadDetailAct
To test scanning, follow these steps
press start and select run to open run menu OR
hold down windows key and press R to open the run menu
in run type: mspaint and press ok
in the paint program that just opened click File and select from scanner or camera, scan a page and get back to me with results.
make sure the drivers are all installed. If you can copy with the printer (without the use of a computer) then the printer is perfectly fine and it comes down to settings or missing drivers on the computer.
Ekse
May 14, 2009 | Canon PIXMA MX310 All-In-One Printer
Printer shows offline/Scanner has no destination list
You must program the email addresses in the machine address book, so that you will have a destination list to scan to email.
You can also try to scan by pressing the Scanner button to access the scanner function and input the email address manually by selecting manual, and then press the Start button to scan the document.
Joe
Dec 18, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
Imagerunner 5000s scanning problem
run the network scangear utility from the start menu. Click "discover scanner", when the discovery is finished select your copier and then click apply.
May 28, 2008 | Canon imageRUNNER 5000 Copier
Canon mp610 scanning problem
The readme says that some USB hubs have an issue.
I was having problems and was connected via a hub. I removed the hub and connected the printer directly to the back of the PC and voila scanning is all good.
ALex.
Apr 20, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP610 Photo All-In-One Printer Logo
9,070 people viewed this question
old marine
old marine
