Printers
Problem for HP Printers
Generic problem for all HP Printers
The solution offered last time
By hmaund on Aug 27, 2008
The solution offered last time has failed. The sign has reappeared "Ink system has failed.
I have turned off the power for 10seconds, and turned off power, removed cartridges, turned on power and replaced them. Still no good.
Help
Hugh
Comments:
Aug 27, 2008
- It is a D 7300 Serial No. Q7057B
Aug 27, 2008
- Its a D7300 Serial No. Q7057B
Aug 27, 2008
- D7300 Serial No Q7057B
Aug 27, 2008
- ModelHP Photosmart D7360. Ink system failed again and I have gone through the procedures outlined before to no avail.
Aug 27, 2008
- I have reinstalled the hardware. I could try new cartridges or take the printer back to the supplier.
Aug 28, 2008
- Still no joy. I have tried all the solutions you have suggested but no good.
Aug 28, 2008
- I think you have the wrong model. There is no right side access and there are no buttons you specify.
Aug 29, 2008
- I was forced to go back to the supplier who provided me with a new printer
Best Solution
posted on Aug 28, 2008
Very Helpful)
creativemind
Rank: Wiz
Rating: 79%, 103 votes
u have to with a professinol repairer
Was this helpful?
Yes
No
Solution #2
posted on Aug 27, 2008
Somewhat Helpful)
The Machine
Rank: Wiz
Rating: 83%, 378 votes
There is a chance that there is something physically wrong with your printer. Maybe a gear is broken or came off, or maybe a pump or tube is clogged. But most of the time a cold reset will sold the ink system failure error. Here's the procedure for the cold reset:
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconect,by pulling gently, the flat ribbon cable off the main circuit board that is the smaller of the two.
4- Plug in power source and turn printer on. Wait till you hear no more movement from inside from unit booting up.
5- Press both cancel and power button at the same time.
6- Message on printer screen will be, "Enter Special Key Combo".
7- Push keys; Left-Ok-Right.
8- When printer screen changes, scan through and look for "System Menu" and push "Ok"
9- Scan agan and look for "Clean Derivative" and push "Ok". [WAIT FOR 1 MINUTE].
10- Scan agan and look for "Clean Firms" and push "Ok". [Again WAIT FOR 1 MINUTE]
11- Press "Cancel" 4 times
12- Turn off power and unplug from power source. [NOW WAIT FOR 2 MINUTES].
13- Reconect the flat ribbon cable by aligning and carefully pushing into the conector on the main circuit board.
14- Plug in power source,and turn on power.
15- When printer boots up, answer the questions on the printer screen for your area.
16- The printer will cycle the ink from the cartridges to the print head and back.
If this doesn't clear your error then there may be something broken inside your printer. If you still have warranty then I would have the unit replaced. If you don't have warranty then it might be cheaper to buy a new printer that has warranty.
Comments:
Aug 28, 2008
- Sorry about that. I've found another procedure for resetting the print. Hold the "print" and "power" buttons. The printer may ask for a key, just power off then back on. The printer should reset and if there is no physical problem the printing should resume. I found this answer here: http://www.fixyourownprinter.com/forums/printer/39471
If your print quality is bad after the reset then there is something wrong with the ink system and I would recommend replacing the printer. Let me suggest the Epson RX680, my favorite printer.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
Somewhat Helpful)
Junoon007
Rank: Wiz
Rating: 82%, 394 votes
Dear Sir/madam,
Try to reset the printer again and again it will be worked. After holding down OK, Cancel, Black and Color buttons while turning it off, I turned it back on, it turned itself off and I turned it back on again, it started off doing the calibration and it took about 5 minutes, but when it was finished I had a working printer again.
An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer. thanks
good luck
Was this helpful?
Yes
No
Solution #4
Somewhat Helpful)
ginko
Rank: Guru  Computer Hardware  Expert
Rating: 89%, 5219 votes
I gave you the solution, it had been refused, don't know what else to do, your printhead is failing, replace cartridge, if it still does not work , you need to do some maintenance on printer hardware.
I already gave you broad directions on that.
Was this helpful?
Yes
No
Solution #5
Somewhat Helpful)
micromaster
Rank: Wiz
Rating: 82%, 787 votes
model of your printer please, and the problem that you have in your device..thanks
Was this helpful?
Yes
No
Solution #6
Somewhat Helpful)
coolguy008
Rank: Wiz
Rating: 83%, 601 votes
hi,
Can you please give the make and model no. of your printer
Was this helpful?
Yes
No
Solution #7
Somewhat Helpful)
gopi20
Rank: Wiz
Rating: 80%, 282 votes
what is your model number ?
Was this helpful?
Yes
No
Solution #8
Not Rated)
techexpert12
Rank: Wiz
Rating: 73%, 54 votes
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the D7360 off. Keep holding the buttons down until the printer shuts off and the turn it back on. You will have to turn the printer off twice and then it will recalibrate. Make sure you have new cartiges in the printer so that it can reset. Good Luck!
Was this helpful?
Yes
No
Solution #9
Not Rated)
s4u311
Rank: Wiz
Rating: 83%, 458 votes
u have to go witha good printer technision
Was this helpful?
Yes
No
Solution #10
Not Rated)
ohms
Rank: Wiz
Rating: 83%, 796 votes
as i posted : change the ink cartridge (no guarantee if it is the printer or the carts that is faulty, you still end up spending on ink)
or since it is still fairly new, call HP tech support (they can't fix it on the phone), you might receive free carts to try or replacement.
Comments:
Aug 27, 2008
- accept the fact that hardware do fail.
Was this helpful?
Yes
No
Solution #11
Not Rated)
marked
Rating: 86%, 962 votes
Sorry if the last solution did not work try this :
Remove the ink cartridges and with the computer and printer turned on uninstall the software Reboot and install the software according to the instructions...
Hope this fix it now...
Comments:
Aug 27, 2008
- Afte you replace the cartrdges and still have the same problem the next step here is to replace that printer since it has alot of issue...
Aug 27, 2008
- After you replace the cartrdges and still have the same problem the next step here is to replace that printer since it has alot of issue...
Aug 28, 2008
Was this helpful?
Yes
No
Popular Solutions for Printers
Questions and Unsolved Problems for Printers
Answer
Is a DELL 1700 LASER PRINTER a decent printer, and how much should I be willing to pay, is this a... (More)
Answer
I've read that inkjets are best for home photos. But I really want a color laser printer ( fax not... (More)
Answer
My HP Officejet 6310 will no longer initialize. When I try to print a document the printer goes... (More)
Answer
ready light (green) and alarm light (red) both flashing
Answer
trying to connection MFC 440 printer via bluetoot, but on pc I cant find the printer through... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
