Question about Canon Office Equipment & Supplies
PRINTER i850. Only black color has problem. 1. Printed page has evry 4th line faded. 2. Nozzle test shows 2 horizontal black line missing. Your help is appreciated A.H. SIDAHMED e-mai. sidahmed@bellsouth.net Phone: 770/993-3062
BOUGHT A NEW PRINTER
Posted on Aug 28, 2008
Hello - my Brother DCP 330C printer is printing horizontal faded lines on both color and Black and white copies. I have changed the toner in all areas but still no change. Could the problem be with the...
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 28, 2010 | Brother DCP-330C All-In-One InkJet Printer
My Brother HL1230 printer prints with whole lines of text missing several times on a page and gets worse by missing more lines if printing several pages. It has a new toner cartridge. How can I sort this...
Good Luck
RK
Jan 28, 2010 | Brother HL 1230 Laser Printer
Prints only blank pages
Good Luck
RK
Jan 06, 2010 | Brother HL-2040 Laser Printer
Brother 420CN printer will not print black ink. Have replaced the cartridge and after several cleaning cycles, it still will not print properly. Test Print shows colors are fine but black ink is hit and...
Good Luck
RK
Dec 20, 2009 | Brother MFC 420CN All-In-One InkJet...
When printing lines are running through the sentences.I have a brother mfc440cn printer
Good Luck
RK
Dec 09, 2009 | Brother MFC-440CN InkJet Printer
Black ink in brother 240c printer does not print new cartridge
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there. Better than throwing the printer.
Good Luck
RK
Nov 20, 2009 | Brother MFC 240C All-In-One InkJet Printer
My printer is running a white streak through the center of pages
You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Next, try this printer self-test by following the steps given below:
1. Turn the power to the printer "off."
2. Press and hold the "Paper Feed" button.
3. Press the "Power" button once while continuing to hold the "Paper Feed" button.
4. Keep holding the "Paper Feed" button until one sheet is cycled through.
5. The test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know.
Oct 01, 2009 | Lexmark Z715 InkJet Printer
A faint line shows up down the middle of the page, when printing a photo
from cnet review of the product
  • Unfortunately, as with the Z1420, fast print speeds come at the cost of print quality with the Z1300. Black text prints, though nicely dark, were beset by obvious jaggedness. The color graphics print had a slightly faded look to it and color blocks showed graininess and faint horizontal striations. Barcode-style patterns were muddled, too. For our tests, we printed color 4x6 photos with the standard black and tricolor cartridges, as Lexmark did not include photo ink tanks with the test unit. The colors were dull, details were hazy, and again, the entire print was marred by graininess and faint horizontal lines. That said, nobody buys a $25 printer to print photos for framing or to create displays for a classroom science project. A $25 printer is a convenience item for occasional reference prints, and as such, the Z1300 does its job.
Inkjet printer quality
(Longer bars indicate better performance)
b.gif Photo b.gif Graphics b.gif Text Canon Pixma iP1800
Good Good Good Lexmark Z1300
Fair Fair Fair Lexmark Z1420
Fair Fair Fair
Sep 15, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Black ink
You may want to do the ff. just to make sure your printer is physically functioning.
1. Disconnect the printer cable that is connecting printer to the computer.
2. Turn the printer ON by holding down the POWER button for about 3 seconds.
3. Load A4 or LETTER size paper in the sheet feeder on the back of the printer. Press the SETUP button to enter Setup Mode.
4. Press the Up or Down arrows to select NOZZLE CHECK. Press the OK button,
then press OK to print a nozzle check.
5. The printer will print a pattern displaying a number and a nozzle pattern with black & color. Examine the nozzle check pattern that has printed. Each staggered horizontal line and straight vertical line should be complete.
6. To exit the SETUP mode, simply press the COPY mode so that it is illuminated or the copy options appear in the LCD.
If the Nozzle Check Pattern page does not print, prints out with gaps in it or some of the colors do no appear, then there is an issue with the printer. That means that troubleshooting is required on the printer prior to using printer on the computer.
If the Nozzle Check Pattern page prints correctly and completely, the problem may lie within your software settings, the interface cable, or your computer.
according to the manual, goodluck!!!
Apr 26, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
old marine
old marine
