Question about Car Audio & Video
No display The front panel still opens and closes and accepts and ejects cd's dut there is no display on either the open or closed screen. Neither cd's or the radio works. some of the buttons are still beepimg. I have replaced the cable but it still does not work. any help? Ciaran I INSTALLED THHE STEREO, BYPASSING THE FACTORY AMP IN A 96 CHRY SEBRING LXI. VERY HARD TO GET ANYTHING TO PLAY, AND IF YOU DO YOU NEVER KNOW WHAT IT WILL BE. 1) THERE IS NO VISIBLE DISPLAY ON THE FRONT FACE, EXCEPT FOR THE RED OUTLINES GLOWING AROUND THE BUTONS. BUT THE BIGGEST PART IS: 2) WHENEVER YOU DO GET SOUND FROM A CD YOU HAVE JUST INSERTED, ANY TIME YOU TRY AND TURN THE VOLUME KNOB, IT MAY INCREASE OR DECREAS VOL IF YOU SPIN IT VERY FAST, OTHERWISE IT WILL CHANG YOUR CD TRACKS UP OR DOWN, SWITCH YOUR RADIO STATION TO DIFFRENT CHANNELS. THE FWD CD OR FWD SEEK BUTTON WILL USUALLY FUNCTION---THE BACKWARD SEEK OR CD TRACK BACK BUTTON NEVER HAS WORKED...THIS IS THE 2ND FACE I HAVE TRIED....HELP ME....WHAT CAN I DO???? SCOTT OLSON scottchoc@live.com
My cd plays fine but the display is dead inside and outside any help
Posted on Sep 16, 2008
    Scholar:
  • 55 Answers
Did you install the unit with the correct wiring harness, or cut-and-splice the wires from the factory line to the stereo lines? This could be a problem.
Posted on Aug 30, 2008
How do I have to restart my eclipse avn52d car audio cd drive after I changed my car battery ?
You must be inside the Eclipse in order to unlock the radio's security system.
Insert the key in the ignition. Turn it clockwise one notch so some of the car's controls turn on, but not the ignition.
Press the radio's "On" and "Screen/Text" buttons at the same time and hold both down until "SEC" appears on the radio's screen. After two seconds, the screen will change to read "DISC."
Press the "Open" button on the front of the radio. The front panel should open it.
Insert the Key CD into the CD slot. The message "SEC" appears. You should have received this CD when purchasing the car. If you don't have this CD, contact your Eclipse retailer for an extra one.
Eject the Key CD by pressing the "Eject" button and close the front panel of the CD player.
Jan 27, 2018 | Eclipse Car Audio & Video
Artisan 730 keeps ejecting CD/DVD tray?
Possibly the the eject switch is stuck, open the case carefuly check and rectify.
Mar 25, 2015 | Epson PRINTER,ARTISAN 730
CD stuck in my Honda Odyssey CD changer
Turn van off. Open & close drivers door, wait for everything to power down. Turn van back on and push button to close CD/Nav opening. It will close. Having an issue with CD player also.
Mar 19, 2012 | 2008 Honda Odyssey EX-L
My JVC TH-G30 gives me a locked message when I try to open the load tray what should I do?
hello Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Mar 29, 2010 | JVC TH-G30 Theater System
Open/close doesn't work
When you press Eject CD button, do you see CD display blinks as if its preparing to be ejected? If its true then eject switch is working and cd mechanism is stuck, requires service. Also check loading belt in mechanism.
And if unit shows no response on pressing CD Eject button then switch is bad, replace it.
Jun 30, 2009 | Aiwa NSX-A115 Shelf System
No display
HI THE FLEXI RIBBON IS FAULTY MAKE SURE YOU HAVE THE CODE AS YOU WILL NEED THIS TO MAKE THE STEREO WORK AGAIN
IF YOU DONT HAVE THE CODE THEN
LOOK ON THE BOTTOM OF THE STEREO YOU WILL SEE A SQUARE SECTION MISSING INSIDE THIS 4 BLOBS OF SOLDER JUST SOLDER THE FOUR BLOBS TOGETHER AND THIS WILL WIPE THE CODE OUT ALTOGETHER
THIS DOES HOWEVER MEAN THERE WILL BE NO SECURITY ON THE STEREO
HOPE THIS HELPS
Aug 05, 2008 | Sony CDX-M800 CD Player
CD drawer will not open
Try manually opening the drawer. There's a little hole on the front, Insert a pin or bent paper clip in the hole with the machine "on". Should open for you.
Jul 16, 2007 | Teac GF-650 Turntable
Sony CDX M8800 Front Panel Problem
u need 2 replace the ribbon that goes to the panel to the unit.i had the same problem with mine then i went on to ebay and found the ribbon there (cdx-m8800 repair kit)hope this helps
Dec 17, 2006 | Sony CDX-M8800 CD Player
Locked dvd tray.
To unlock, manually press and HOLD the open/close button & the stop button simultaneously, and HOLD them both down until the lock picture disappears.   The DVD will eject when you press the open/close button.
To lock the DVD inside the machine, repeat the same step, and it will lock it inside.
Apr 07, 2006 | Panasonic DVD-A110 DVD Player
Car Audio & Video Logo
188 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
