Question about Samsung DouCam VP-D5000i Mini DV Digital Camcorder
Using USB Transferring A Digital Image Through A USB Connection
    Master:
  • 473 Answers
Before transferring digital images through the USB Connection, you must install the driver and software that came with your camcorder. The software may vary by model. Please view the attached instructions and system requirements for installing the software. Instructions for transferring images through DVC media are provided on the disk as well. For newer models, you can use Windows Explorer to transfer still images. After installing the driver as instructed in the attachment, follow these instructions. 1. Connect one end of the USB Cable to the Camcorder. 2. Connect the other end of the USB Cable to the PC 3. Power on the Camcorder. (You will notice a green arrow appear in the lower right hand corner of your monitor indicating the device has been detected by your PC) 4. Right click the 'Start' button and choose 'Explore' 5. The Camcorder will appear as a 'Removable Disk' with a drive letter. 6. Click on the Removable Disk and two folders will appear. DCIM and SSMOV. DCIM will contain still images. (SSMOV will contain mpeg's) 7. Double Click the DCIM folder 8. Double Click the folder named 100SSDVC 9. All pictures on the memory stick will appear. 10. You can highlight any (or all) pictures you would like to transfer and move or copy to them to the folder of your choice. (You can select a folder in the left window pane of Windows Explorer and drag and drop files as well) 11. When you are through, you must 'Safely Disconnect' the camcorder by right clicking the green arrow in the lower right hand corner of your screen. (Follow the on screen instructions. Failure to do so may result in flash memory loss)
Posted on Sep 06, 2005
SOURCE:
Getting photos from zoombrowser to email that are rejected as errors
this happen when transferring images using the Direct Transfer Menu, you attempted to select an image with corrupted date or an image taken with another camera.Check the menu
God bless you
Jul 27, 2013 | Canon PowerShot A495 Digital Camera
Photos not transferring
Please try deleting the drivers , then reloading.
It will look for the connection again, and hopefully find it this time.
Jun 20, 2008 | Nikon COOLPIX L10 Digital Camera
What leds do i need to hook up to my pc
Usually almost all MP3 players can be connected to a computer via USB connection , using the usb cable or by directly connecting the unit to the computer USB port and from that you can do the transferring of songs from computer to the MP3 player.
May 28, 2011 | Audio Players & Recorders
I want to put mp4 in my Nw-A806 sony walkman..
install the walkman launcher first.. (it is in the cd-rom that is included in your walkman)
Connect the player to your computer using the supplied USB cable.
Insert the connector of the USB cable into the player with the mark facing up.
When the connection is started, WALKMAN Launcher starts up.
On WALKMAN Launcher, click [Video] when transferring videos
Click [Add to the List] on the left of the screen.
The 'Add to the List' screen appears.
Select a video or that you want to add to the 'To be Transferred'
list, and click [Open].
The selected video or photo is added to the 'To be Transferred' list.
You can also drag and drop a video and photo to the left side on the screen to add it to
the list.
Select the model name of the player (NW-xxx) from the 'Transfer to' list at
the top right of the screen.
Select videos or from the 'To be Transferred' list on the left of the
screen, and then click to start transferring.
The transferring window appears. If the data is not in a playable file format required
by the player, it will be transferred as it is being converted automatically.
The transferred videos or photo are added to the 'Transfer to' list on the right side of
the screen, and deleted from the 'To be Transferred' list on the left side of the screen.
taken by digital still camera to your computer, and transfer them to the player using the
supplied Image Converter.
akuma_ryu21 i hope this helps..
dont forget to rate.. thanks..
Apr 27, 2011 | Computers & Internet
I'm transferring files and after a few files are transferred, maybe a gig. The transfer gets hung up and when I push the try again button, it freeze explorer. This happened when I first bought the item...
It sounds like your transfer is hanging up in the middle, if you are transferring over a network (without wires) you are loosing your connection. I would recommend that you try and transfer a small amount of the files at a time instead of many gigabytes. If you are transferring in the above manner, I would strongly recommend that you try and connect your device directly to the computer you are transferring from. If it is connected and you keep dropping connection. It may be some kind of RAM (random access memory) shortage in your transfer PC or a problem in the connecting wire. I would try transferring from another PC so that you can isolate the problem. If the connection keeps getting lost it may be a problem with your my book.
Mar 07, 2011 | Western Digital My Book Essential 1TB...
Sony cybershot P200 says 'File Error'
The LCD screen may display a FILE ERROR message when trying to view a still image on the camera if the image was rotated, modified and overwritten using editing software on a computer. To play images you have taken on the camera, it is recommended that you do not make any changes to the original image files. I suggest that you transfer the images from the Camera to the computer and check if it works. After transferring the images, get the Memory formatted from the Camera and start capturing new images. The edited images will not get displayed in the Camera again. Please try not to edit the images in the Computer without transferring it.
Thanks.
KenSolutions
FixYa
Sep 12, 2010 | Sony Cyber-Shot DSC-P200 Digital Camera
X 20 dimage minolta
Greetings,
Let us hope that the only display controller or the LCD is malfunctioning, take a shot and try transferring the image to a computer (memory card or usb).
No matter what the result is, that camera is service bound.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 07, 2008 | Cameras
Transferring pictures
A couple of things you can try:
1. Insert the Camera's USB cord to another USB port of your PC;
2. While disconnected from the PC, verify that the pictures are still inside the camera's memory;
3. Reset the camera (power on/off);
4. Check the camera's batteries;
5. Reboot your PC with the camera attached via the USB;
6. Remove the memory card from the camera and try uploading using a card reader;
7. Uninstall all instances of your USB in your PC's Device Manager, reboot and allow the PC to auto-detect  and auto-install necessary drivers; and
8. Verify that the software/drivers for your camera are installed correctly with no yellow or red markings.
Hope this be of some help. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 02, 2007 | Cameras
Connecting analong camcorder to computer
The only Analog camcorder that has a USB Connection for transferring pictures or video is the SC-L770. The SC-L770 can transfer video (live or recorded) and still photos through the USB connection. You can also transfer audio using the audio cable provided. After installing the driver and software, you can begin transferring data using the software provided. Connecting to a PC 1. Connect a USB cable to the USB port on the PC. 2. Connect the other end of the USB cable into the proper terminal on the camcorder. (USB jack) 3. Connect the audio cable to the Line input jack of the PC. If the PC has no Line input jack, connect the audio cable to the MIC input jack. In this case, however, a noise may be produced depending on the PC. Notes: * If you disconnect the USB cable from the PC or the camcorder while transferring, the data transmission will stop and the data may be damaged. * If you connect the USB cable to a PC via a USB HUB or simultaneously connect the USB cable along with other USB devices, the camcorder may not work properly. * In this case, remove the other USB devices from the PC and reconnect the camcorder. Some other Analog Camcorders have a snapshot mode which allows you to take a still photo with your camcorder. However, you cannot transfer these to a computer unless you purchase additional hardware such as a capture card. Some capture cards have analog a/v inputs which will allow you to use the a/v outputs on the camcorder to connect to your pc and transfer images and video. You can purchase a capture card at most computer and electronics stores. Samsung does not support capture cards.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Samsung DouCam VP-D5000i Mini DV Digital Camcorder Logo
297 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
