Question about Dryers
How to install plug in on my new dryer - Dryers
  • 639 Answers
ngfam1 here for you!
I am happy to be of assistance!
For this problem you will need to use factory service!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
Posted on Aug 28, 2008
Put a plug on a 220 wiring. the plug has melted
buy a new power cord with plug on it, remove back of dryer, undo screws on old cable one at a time and install new wire: example---remove a red wire from old cable and then put on the new red wire , move to the next color and repeat. put on back, then plug in. Done...
Jan 08, 2014 | Dryers
Dcvh515ef0ww no power no light
probably the door is not activating the "door closed" safety switch,
Dec 24, 2013 | GE Dryers
I moved my Cabrio electric dryer to another room. A new outlet was installed in the new room. When first plugged in, the dryer runs and tumbles but will not generate heat. Suggestions?
Your electric dryer uses110vac to run the motor which makes the drum turn. It uses 220vac to run the heating elements. I'll assume you had a qualified electrician add the new outlet. If not, I'm betting whoever did the install used the same electrical phase for both 110 sides of the plug. You can't use an electrical tester to test this as both sides will read the same. Manually trip the breaker (should be a double breaker) and then check the outlet. The wiring to the hot leads should be black on one phase and red on the other. Let me know what you find out
Oct 18, 2013 | Whirlpool Cabrio WED6400SB Electric Dryer
Schmetic for roper dryer - need drawing showing set up for installation '
Are you trying to connect your power cord to back ? Dryers are all about the same. But all new dryers are designed for 4 wire plugs .. If you have a three wire plug or cord the white connection and the green ground connection go togather on the center ground wire to your 3 wire plug.
May 30, 2011 | Whirlpool Dryers
How to connect a new dryer plug
Yes you can reconnect it to the original place and everything will be fine...
Feb 24, 2010 | LG DLE2532W Electric Dryer
New installation, dryer won't run
Check your circuit breaker and wall plug for proper voltage. If o.k., contact the warranty service company.
Feb 21, 2010 | Kenmore Dryers
Got a used dryer and there is no electric plug. Previous owners pulled it out. Where do you install a new plug. It's a Heavy Duty 20.
should be in the back of the dryer,there should be 3or 4 screws that you have to hook to.lots of the time when you buy a new plug the instructions are on it,if not ask someone who knows
Jan 11, 2010 | Magic Chef Dryers
Frigidaire GLEQ2152ES Dryer Won't Power UP
IF you find that you have only a 3 wire feed for this dryer (and the reason for the 3 prong receptacle)...then you can not properly install a 4 prong dryer cord to it. You now have 2 choices....either rewire (assuming that it is a 3 wire supply) the entire run from the dryer breaker to the outlet location with 4 wire (typically a run of 8/3 with ground having a black, red, white and bare ground)and install a 4 prong dryer receptacle to match the configuration of the new dryers cord.....OR - you can remove the 4 wire cord and replace it with a 3 wire the ground strap - IF it is still in place.
Jul 11, 2009 | Frigidaire Dryers
How many prongs are on amana NED5100TQ electric dryer? I have a new one being delivered today and currently have a 3 prong hookup
Generally you have to purchase the cord separate from the actual electric dryer. Therefore, call the company and tell them you have a 3 prong outlet, that way they can install a three prong plug. Many times, they bring both plugs with them and do the plug install on site. Enjoy your new dryer!
May 01, 2009 | Dryers
Dryers Logo
69 people viewed this question
Top Dryers Experts
