Question about Miele Revolution 600 Bagged Canister Vacuum
We have a 4 year old Meile vacuum cleaner. It keeps cutting out when we are using it. The bag has been replaced and the suction tube is clear of
debris. Sometimes it can run for a minute, sometimes it can be every few
seconds. I think the motor is okay. It seems to happen when you are moving it like a loose connection on the suction tube side but cannot find anything to check as the tube fits into the main body via a round hole plus
a push fit 3 spade socket which seems okay and the spades look to be clean. Any ideas?? Thanks
  • 4 more comments
  • kirkt Aug 29, 2008
    Definitely the Power Head! When we open the bag compartment the power rises to maximum again. Similarly if we disconnect the hose completely the motor power increases immediately
  • kirkt Sep 02, 2008
    Yes the light goes back to the off setting on the handle and you
    have to push the buttons to get it up to speed again. sometimes it will work for a while after that sometimes it goes straight off again
  • suzylucia Dec 11, 2008
    I have the same problem and have been told I need a new hose which will cost $380.00 I don't know why it can't be replaced with a new hose without the computerised power on the handle. I think if they have been faulty they should be replaced free of charge.
  • Pheline Mar 12, 2009
    I have/had the same problem - the repair shop told me it was the "motor mounts"- ?? I opened it (easy, just take out screws), found sparking by the motor brushes, replaced those but I think it was just a connection that was out of the motor brush unit since one came with the old (not worn out) brush. Now I have everything in working order- but I can't get the top back on and get the plug from the power cord to plug into the plug on the cover , on the *bottom* of the cover, that is. IOW- I'd have to take the plug out of the bracket, plug it in, assemble the top and bottom and leave the plug rattling around in there by the cord reel. Doesn't sound like a good solution. A diagram or picture of the assembled bottom motor/cord reel set up would be very helpful.
  • Rob Ristin May 11, 2010
    But you're saying that the power rises again? That would indicate that the main canister's motor is changing speeds, not the power head motor.
    When it "cuts out," do the lights on the handle where you can change the power drop to the lowest light position? (Off?)
    Is it just the powerhead cutting out, or is it the main canister motor?
  • 97 Answers
This is a problem with the hose, and unfortunately it will require replacement of the entire assembly.
The SES-125 hoses produced in the general vicinity of late 2002 had a tendency to start building up static and kicking the motor off after a few years. The problem was rectified, and the more current hoses do not have this problem.
Head to your friendly neighborhood Miele dealer and get a new hose, and this problem will not occur again.
Posted on Sep 03, 2008
  • Rob Ristin Mar 05, 2009
    $380 is a bit high: I believe the MAP price of that is somewhere around $160-180.
    You can't replace it with a different hose because the electrical connections back at the canister are different.
    Miele's 2 year hose warranty is far superior to any other company's hose warranty. While it's unpleasant to have to replace it, can you think of any company on Earth that would replace a part that's 5,6,7 years old that worked fine prior to that?
My cleaner keeps cutting out and now won't start
You can get a replacement hose from a vacuum store
Jan 04, 2014 | Miele Revolution 600 Bagged Canister...
How do you read the "full bag indicator" on a Meile S7260?
typically if your vacuum is loosing performance it is time to replace the bag depends on how fine of dust some really fine dust will clog the pores at a 1/4 full
Apr 14, 2013 | Miele CatAndDog700 Bagged Canister Vacuum
Popped the lid open to change vacuum cleaner lid won't close. It's stuck at 90 degree angle. Is a button to release it?
Hi bndennis,
Please check the spring on your lid, it may be keeping the door open. Miele vacuum cleaners mainly use a spring concept for keeping lids open - merely pushing it down will lock it at the bottom.
Kind Regards :-)
* If this solution helped you, please rate it
Jul 23, 2011 | Miele S4210 Antares Bagged Canister Vacuum
Miele vacuum cleaner keeps overheating and shutting off. It is only possible to use for about fifteen minutes at a time
Hi Lauren, how do you know if it is the circuit board? (the speed control buttons still work).
Mar 13, 2011 | Miele Vacuums
Dust bag was full and have changed it but not getting proper suction since bag change - why?
The extension tube is probably blocked. Check for suction with all the tubes off - if there is suction now then the tubes are blocked - be carefull not to damage them if you poke things in the unblock them.
Feb 13, 2011 | Miele Revolution 600 Bagged Canister...
How to take apart to replace power cord
In order to access the cord on the Miele S183 upright, you'll need to first remove the handle from the vacuum cleaner. There is a large screw that holds the handle in place that is located under neath of the lower cord wrap hook. Simply remove this screw, and slide the off the vacuum by pushing the handle towards the back of the machine.
Once you have the handle removed, now ope the bag door as if you were going to replace the vacuum bag. You'll see two screws directly above where the bag fits inside of the machine. These two screws will open up the switch and cord housing and give you access to the electrical cord.
You'll see that there are two screws that secure the cord as it comes into the vacuum from the back. Remove both of these screws so that the cord is no longer secured. I think the easiest way to replace this cord is to simply cut the cord (MAKE SURE THE VACUUM IS UNPLUGGED) so that there is about 4-5 inches of the cord jacket (rubber coating around the cord) remaining. You may now just pull this cord jacket off of the cord, along with the paper insulation so you have two bare wires of the old cord. Now take your new cord and push it into the back of the vacuum so that it comes through the switch housing. Instead of having to re-secure the cord with the two screws, I've found that if you tie a small knot in the cord, this works just as well at preventing the cord from pulling through the back of the vacuum.
Simply strip the wires that are left from the old cord, and simply wire nut the new cord after tying a knot (or re-securing it with the two screws), and reassemble the vacuum cleaner. Test the vacuum only after putting the switch housing cover back into place.
If you have any questions about how to do this repair, please feel free to use the clarification request form here on the Fixya repair page. If you found this helpful, please be so kind as to rate my repair as helpful by clicking on the 4 thumbs up icons in the top right hand corner of the repair. This is what keep Fixya's repair professionals continue leaving free repair advice on this site.
Here's a link to a blown up parts diagram to help you visualize how the vacuum comes apart.
Feel free to check out our website for any Miele supplies that you need:
Miele Vacuum Bags, Filters & Belts
Thanks again for rating my repair,
Chris J.
Apr 07, 2010 | Miele S183 Powerhouse Bagged Upright...
Why does my miele 700 revelution hoover keep cutting out? The bag is not full just loses power?
  1. i have a miele revolation hoover, it doesnt pick up. it has hardly no sucktion. where and how do i get the filter out to clean it??? it was given to me working. ive changed the bag so thats not the problem. and checked the hose. still no joy. need sucktion.. Thankyou jacqui
Jan 01, 2010 | Miele Revolution 600 Bagged Canister...
Buying spares Meile 250i
Hello Dave,
You'll want to contact Miele directly and they can direct you to your nearest shop
Miele Dealer Locator (vacuums)
(888) 785-2828
Monday-Sunday: 24 hours
Sep 05, 2009 | Miele S251i Plus Bagged Canister Vacuum
Miele Revolution Vaccuum cleaner manual
Under the download section is the owners manual. This is for the same series Miele that you have so this manual will have most everything you need to know. The black filter is a charcoal filter, this is good if you want to control the odor but don't have allergies. If you have allergies you might wont to get a HEPA filter. I would recommend changing the filter every 6 months to a year. You need to use the empty filter when you want to use it as a blower. The hose will not fit into the opening with the HEPA or charcoal filter in place. I hope this helps.
Jan 06, 2009 | Miele Revolution 600 Bagged Canister...
Ive got a miele revolution 5000 power plus and its just cut out the green power button on the handle is on but the orange button on the body does not come on it just flickers unless i open it up, any...
Generic problem for all Vacuums
I’ve got a Miele revolution
Posted by rowler on Jun 02, 2008
I’ve got a Miele Revolution 5000 power plus and it’s just cut out the green power button on the handle is on but the orange button on the body does not come on it just flickers unless i open it up, any ideas?????
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I am not familiar with the light system on the Miele Revolution 5000 Power Plus
But it has something to do with the electronic hose assm or the circuitry in the vacuum itself. I have listed the factory phone # listed below for your further information. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Customer Service, Repairs, Parts 1-888-785-2828
Mailing address listed below:
Miele, Inc
9 Independence Way
Princeton, NJ 08540 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 02, 2008 | Vacuums
Miele Revolution 600 Bagged Canister Vacuum Logo
656 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
