Question about Philips DVP5140 DVD Player
Philips DVP 5986K
Hi. does anyone have the unlock code for this DVD player. Stuck in the middle of nowhere with the wrong regions.......
  • whywhy Aug 28, 2008
    Thanks, worked fine......
  • 376 Answers
Press "Setup"
Scroll to "Preference" using the LEFT/RIGHT arrow key
Press "138931" and a pop-up screen will appear.
Use the UP/DOWN arrow key to choose the desired number ("0" for region free).
Posted on Aug 27, 2008
I bought some DVDs at amazon.com, but I live outside the region code area witch the DVDs are supposed to work. I live in code area 4. I need someone to find a code to region 1. I have a Phillips home...
This player is relatively easy to change to region free. Please complete all of the steps below to unlock your DVD player.
Please note: Unlocking any DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
Unlock sequence for the Philips DVP 3020:
1. Switch on your TV and DVD player;
2. Make sure the TV is set to the correct input for the DVD player;
3. Remove any disc from the DVD player and close the disc tray;
4. Press the "SETUP" button on the DVD player remote control;
5. Use the LEFT/RIGHT arrow keys to highlight "PREFERENCE";
6. Enter 1 3 8 9 3 1 using the numerical keys on the Philips DVD remote control;
A pop-up menu will appear on the TV screen.
7. Use the UP/DOWN arrow key and choose "0" for all regions;
That's it. You should now be able to watch DVDs from all regions on your player. It is also a good idea to switch the player to standby and then switch it back on before trying any discs.
This is a verified unlock sequence for the Philips DVP 3020. If it doesn't work the first time, switch the power off and start again at step 1. If it still doesn't work, it is likely that you have updated your Firmware to a new version and this unlock sequence does not work with your firmware version
If you need further assistance, please reply to me from within this page and let me know which firmware version you have installed in your DVD player.
Regards,
BElectric.
Jan 28, 2011 | Philips Televison & Video
Universal Remote code for the Philip DVD player
ring philips and tell them ur problem....look under customer help line...u will find in ur instruction booklet
Mar 07, 2009 | Televison & Video
Unlock region code for Philips DVP 3256
Region code hack for PHILIPS 3256 x/94
1. Go to Setup. [from remote]
2. Select the Preference Page.
3. Press 1, 3, 8, 9, 3, 1 on the Philips DVD Player remote.
--> It will show current region code [ for example 5 ]
4. Now Press the up/down key to select "0" which makes it region free.
5. Press ok and exit setup.
Probably the same would be applicable for 3258, 3268, 3986.
Good Luck!
Jan 02, 2009 | Philips DVD625 DVD Player
Unlock region code
Keep Tray in eject position
Press Setup from remot
Go to preference page
Press"138931"
Using Navigation Key chane region code to "0"
Press "OK"
OR
open tray
press 98790
Jun 25, 2008 | Philips DVP3040 DVD Player
Wrong Region message
DVD player must be made region free by unlocking it.. after that you can play all the discs you want.. for ubnlocking it you can try google//
Jan 19, 2008 | Philips DVP-3005 DVD Player
Unlock region codes
Hi All,
I am looking for the region unlock code for a Sony portable
DVD player.Model number DVP-FX720
Jan 12, 2008 | Insignia NS-PDVD8 Portable DVD Player
Region Codes
It works for NS50P, NS575 and the most models of the families NS50 e
NS500.
With the DVD player turned off(stand by), press:
TOP MENU
CLEAR
POWER
Choose option 2 and after option 4. Type:
12450 [press enter]
00000 - Then press enter and power off.
DVD will now be region Free.
Jan 07, 2008 | Sony DVP-NS50P DVD Player
Region Free Code: Philips DVP 5980
this worked perfectly, thank you!
Dec 19, 2007 | Televison & Video
Region codes
Philips DVP 3015K / DVP 3020 / DVP 3040 / DVP 3040K / DVP 5140 / DVP 5960
  1. Method 1:
  2. Open the disc tray
  3. Press SETUP
  4. Navigate to the preferences page
  5. Enter 138931
  6. Select the region using UP/DOWN
  7. Press PLAY
  1. Method 2:
  2. Open tray
  3. Press 9, 9, 9, 9, 0
Philips DVP5140 DVD Player Logo
180 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
